Arborwear
Author Topic: Mobile Dimensions 127 "Restore to Glory"  (Read 1694 times)
Offline yukon cornelius
« on: January 10, 2017, 09:45:26 PM »
Today I went with "Truman The Miller" to look at this mill he put me onto. it has been sitting for a number of years since the previous owner passed. I met with his wife who was a wonderful lady and headed out behind the shed. It seems a bit rough in places and I think the motor is stuck. Not knowing anymore I was willing to make an offer taking all the risk into account. she quickly said yes and said she would be
  happy to have it gone. I gave her the money and now am planning how get it home.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Re: Mobile Dimensions 127 "Restore to Glory"
« Reply #1 on: January 10, 2017, 09:51:15 PM »
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #2 on: January 10, 2017, 10:43:32 PM »
Looks exciting to me. This restoration will be fun to watch!
1992 LT40HD
Offline hacknchop
« Reply #3 on: January 11, 2017, 12:18:19 AM »
If you need help let me know ,I have many yes experience and would love to help.
Often wrong never indoubt
Offline 47sawdust
« Reply #4 on: January 11, 2017, 06:34:01 AM »
"FearlessYukon"
 Good to have a project.Take plenty of pictures before you take it apart.The camera has a better memory than my brain.Good luck to ya.
Mick
Offline goose63
« Reply #5 on: January 11, 2017, 06:48:06 AM »
Yukon it's to bad I'm so far away I have a 48 Ft flat bed you could use to get the mill home with ;)
goose
thank you to all the vets
« Reply #6 on: January 11, 2017, 07:38:37 AM »
I believe it will fit on my trailer. lift up one end and back under it then use a winch to pull it on the rest of the way. it must wait until after our rain and ice storm we are getting Friday unless I can get my orders filled and my wife lets me out early for good behavior  ;D
Offline bandmiller2
« Reply #7 on: January 11, 2017, 08:05:06 AM »
Very good find my friend. I would get a small angle grinder and some cup wire brushes and a lot of time. I'am not a fan of sand blasting as you always drive grit into every crevasse and joint. After brushing use that rust killing coating with phosphoric acid, prime and rustoleum. It will be interesting to compare it to your band mill, let us know. Frank C.
Offline sealark37
« Reply #8 on: January 11, 2017, 08:50:02 AM »
What a fine project!  Please keep us informed on your progress.  Regards, Clark
« Reply #9 on: January 28, 2017, 07:42:20 PM »
it is home. we took the sides off of my  trailer and winched it up the ramps. it only hangs over the end of the trailer 13 feet  :o
I got a two manuals with it. It was number #79 built in 1974. more to come...
Offline Darrel
« Reply #10 on: January 28, 2017, 07:58:27 PM »
Now that's exciting!
1992 LT40HD
Offline barbender
« Reply #11 on: January 28, 2017, 08:49:16 PM »
Nice Dodge, too! ;)
Offline Chop Shop
« Reply #12 on: January 29, 2017, 03:25:17 AM »
Nice!   Looks long?  24 feet?
Offline ozarkgem
  • age 65 yrs old
« Reply #13 on: January 29, 2017, 06:50:54 AM »
Your trailer lights work as good as mine. I will have to buzz over and check out the progress.
« Reply #14 on: January 29, 2017, 07:21:51 AM »
I just noticed they don't seem to be working. I just put new led lights on it yesterday and they were on when I left with the mill.....typical  :D come on over and check it out.
It is 24 feet long. I don't even know where I am going to put this thing.
Today I will remove the spark plugs and get oil in the cylinders to get the motor unstuck. Oh yeah, I also need to get something more than just my hands on the pulley to see if it really is stuck or if I am just too weak to turn it by hand.
Offline DanG
« Reply #15 on: January 29, 2017, 08:15:16 AM »
If the belts are on it you should be able to turn the engine easily with the blade.  ;)
« Reply #16 on: January 29, 2017, 08:48:10 AM »
The first plug I pulled had wet rust on it....ouch. The other 3 look fine. I also noticed a cracked hole in the (what I believe to be) governor. It probably wont be running today but not a loss at all.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #17 on: January 29, 2017, 09:05:54 AM »
You might want to pull the head. Turning the engine
over with a rusted cly. wont be good on the rings.
Some people say dumping water down the rusted hole
will loosen it up. I never wanted to try that one.
I like PB Blaster my self. I have used a grease gun to
move a rusted piston. Wish I was there to help.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Darrel
« Reply #18 on: January 29, 2017, 10:27:33 AM »
VW engine that can't be turned by hand is stuck.  On the bright side, they are very easy to o work on and back in the day when I was a Volkswagen driver, they were inexpensive too. Hope they still are.
1992 LT40HD
« Reply #19 on: January 29, 2017, 10:58:19 AM »
I have been looking up parts. 4 new cylinders with pistons,rings and a few other things $140 including shipping. 2 new heads $300 with shipping. If I went all the way through the motor I might have $600 or less. I have a $500 budget. Time to sell more firewood  :D
