Arborwear
Author Topic: Mobile Dimensions 127 "Restore to Glory"  (Read 1600 times)
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Mobile Dimensions 127 "Restore to Glory"
« Reply #20 on: January 29, 2017, 11:15:35 AM »
Not a terrible price by today's standards, but quite a bit more than back in the 80's when I could pull an engine in the morning, rebuild it and drive tha car the same afternoon.
1992 LT40HD
Offline yukon cornelius
« Reply #21 on: January 29, 2017, 11:42:41 AM »
UNSTUCK!!! 8) 8) 8)
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Offline ljohnsaw
« Reply #22 on: January 29, 2017, 12:04:12 PM »
It only hangs over the end of the trailer 13 feet ...
Oh, so it is a portable mill ;) :D
Nice find and will be fun to watch.
UNSTUCK!!! 8) 8) 8)
Whooot Whoot! 8)
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
« Reply #23 on: January 29, 2017, 04:52:15 PM »
I have no compression on 3 cylinders and 90 ish on 1. I popped the valve covers off expecting stuck valves but instead I am thinking maybe lifters??? I can open the valves with a small prybar and the close back. The rocker arms are not rocketing. Maybe the rockers are froze up. Either way it won't run today and needs parts to fix it. Maybe a complete overhaul is in order.
Offline Darrel
« Reply #24 on: January 29, 2017, 05:06:08 PM »
My guess is that you can tear it down, clean it up and put it back together and it will run great. Same amount of work as a rebuild but costs way less.  Good luck!
1992 LT40HD
Offline Brad_bb
    • My timberframe blog
« Reply #25 on: January 29, 2017, 05:28:09 PM »
So it's a circle mill?  I don't see the blade? did you get one with it?  What diameter?
« Reply #26 on: January 29, 2017, 07:24:24 PM »
Brad, it is a circle mill.  30" blade with two 12" edger blades. The head unit travels above the log on a track. It can make two boards per pass.
Offline plantman
« Reply #27 on: March 18, 2017, 01:20:29 PM »
You've got yourself the grand daddy of portable mills there. Pick yourself up some Rooto professional drain opener which is pure phosphoric acid to remove the rust prior to painting.
I paid about $13 for a quart but it can be diluted quite a bit. Otherwise look for Rust Mort in a autobody supply.
http://www.bing.com/images/search?q=rooto+professional+drain+opener&qpvt=rooto+professional+drain+opener&qpvt=rooto+professional+drain+opener&qpvt=rooto+professional+drain+opener&FORM=IGRE
http://www.mobilemfg.com/contact-portable-saws.html
Watch the video !
http://www.mobilemfg.com/portable-saw-videos.html
