BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Sizing Hydraulic Flow Control Valves  (Read 684 times)
Offline Rougespear
  • Salmon Arm, British Columbia
« on: January 10, 2017, 11:08:04 PM »
Anyone know much about sizing hydraulic adjustable flow controls?  I see flow controls capable of between 8 and 30 GPM.  My system is 3-4gpm.  Does it matter if I use a flow control rated at 16gpm, or should I choose one closer to my system's flow rate?  I ask because I am unsure if the flow control's adjustable flow is proportional to it's orifice diameter or simply the incoming flow to the valve.  My thinking is that is I use a large flow control, I will have less of an adjustable range, but I'm not sure!  Thoughts?
Custom built Cook's-style hydraulic bandmill.
Offline redprospector
Re: Sizing Hydraulic Flow Control Valves
« Reply #1 on: January 11, 2017, 02:19:23 AM »
The rating of the valve is for maximum flow, you can shut the flow completely off. So you won't loose anything (other than a few bucks) using an oversized flow control.
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
Offline ozarkgem
  • age 65 yrs old
« Reply #2 on: January 11, 2017, 05:38:46 AM »
Not sure of your application but a flow control restricts flow in one direction only and a needle valve restricts flow in both directions.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: January 11, 2017, 08:35:30 AM »
With the bigger one you will probably need to reduce the connection
fittings.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Rougespear
« Reply #4 on: January 11, 2017, 10:19:31 AM »
Thanks guys.  I'm controlling the feed speed of my mill.  I understand flow is controlled only in one direction.
I'm concerned about the fine-tune adjustability of the flow.  Most descriptions of one-way adjustable flow control valves suggest "flow is proportional to orifice diameter", and I would assume the orifice diameter of a given valve increases as the GPM rating increases.  So for example given my fixed flow of 4 gpm, an 8 gpm flow control set at 50% open would pass 4 gpm, and a flow control with 16 gpm set at 25% would pass 4 gpm.  So what I'm thinking is I will have less of a range of adjustability with the 16 gpm (0-25%) vs the 8 gpm (0-50%).  And less adjustability would mean less control over the carriage feed speed.
Am I just babbling or making sense?  I'm no hydraulics expert by any stretch!!
Offline bandmiller2
« Reply #5 on: January 11, 2017, 03:42:13 PM »
I would use the same size as your valve and hoses. You want needle control for feed and full flow for gig back. I used a 1/2" valve for my feed, or what ever is close for metric. Frank C.
Offline Brucer
« Reply #6 on: January 13, 2017, 01:25:03 AM »
Flow control valves are most accurate at the high end of their range.
Avoid the pressure-compensated type unless you expect to see a wide variation in pressure while you are sawing.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
hydralic control valves?
Started by treefarmer87 on Forestry and Logging
Last post February 16, 2013, 10:38:30 PM
by treefarmer87
Pneumatic control valves???
Started by Dave Shepard on General Board
Last post April 26, 2008, 07:44:28 PM
by Jeff
Max. gpm through LT40 hydraulic valves?
Started by Dave Shepard on Sawmills and Milling
Last post March 30, 2014, 07:54:58 PM
by Dave Shepard
Understanding 12v Solenoid Hydraulic Valves
Started by Rougespear on Sawmills and Milling
Last post May 22, 2015, 09:11:05 PM
by Don_Papenburg
