Arborwear
Author Topic: TF Scale models before actual construction?  (Read 1901 times)
Offline ljohnsaw
Re: TF Scale models before actual construction?
« Reply #20 on: February 18, 2017, 11:28:45 PM »
Yeah, a little busy.  I probably could have gone with shorter braces but was worried about the leverage it provides when too short.  On the plus side, it proved to be a very stiff frame in the engineer's dynamic modeling software used to evaluate wind and earthquake tests.  I have to have seismic stability, usually accomplished with plywood shear walls.  I don't have ANY plywood in my build! 8)
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline D L Bahler
  • Hopp Schwyz!
    • Traditional Swiss Carpentry
« Reply #21 on: March 13, 2017, 05:33:41 PM »
The bracing arrangement makes this frame look solidly low German. Just put some bricks between those timbers, and it would fit right in in Northern Germany!
Forestry machineries scale models
Started by Clark 666 C on General Board
Last post October 06, 2005, 03:14:32 PM
by Clark 666 C
moved
MOVED: Forestry machineries scale models
Started by Jeff on Forestry and Logging
Last post August 15, 2005, 04:06:26 PM
by Jeff
question
LT40 SW UP/ DOWN OUT OF SYNCHY WITH SCALE RULER SCALE
Started by Daniel on Sawmills and Milling
Last post March 02, 2012, 10:32:26 AM
by Magic Smoke
Log Scale/Board Scale question
Started by Ugly Tree on Sawmills and Milling
Last post October 29, 2015, 07:11:50 PM
by Peter Drouin
