Failure due to over greasing
Started by 4x4American, January 19, 2017, 09:08:19 PM
4x4American
Go easy on the clutch pivot grease fitting on your wood-mizers.  I gave it to it and it blew the bushings apart and snapped the cotter pin right off and I had a heck of a time getting it back together.  Had to take it all apart, remove the excess grease for it to go back together.  I didn't realize the grease was holding it, so I had a clamp on it trying to draw it back together, and broke one of the ears off the bronze bushings.  And it never happens at a convenient time...
Boy, back in my day..
A guy that I know really, really, really well :) had a failure due to being stupid.  He wrecked the outboard blade guide arm, knocked it off the roller bearings and bent the chain sprocket that is powered by the electric in-out motor to move the blade guide in and out :-[ :-\ :'(.
When you bring the head back in reverse, it comes back at one speed.  The speed of light.  If you are cutting a short cant and are using the drag-back, and if the short board comes off the cant and falls into the sawmill frame and wedges in a fraction of a millisecond, and if the head is traveling back at the speed of light, and if the board wedges in the frame as previously stated, and if the end of the boards raises up into the outboard blade guide assembly, and if the head, moving at the speed of light, slams the board into the frame on one end with the other end of the board in contact with the blade guide assembly, and if the board is persimmon, the head is stopped in a fraction of a millesecond with a million tons of enertia and very bad things happen.  Something gives, and it ain't the persimmon  smiley_smash.
What happens next is that the operator is hopping around in circles trying as hard as he can to kick himself in the butt for being so stupid as to do that.  After that, remorse sets in.
Just think how dangerous I he can be with a grease gun  :-\.
If it had not rained yesterday that would not have happened.   smiley_headscratch
That person did mine too.  Different circumstances but the exact same results.
terrifictimbersllc
Since the head travels back faster than signals reach the brain, it wouldn't have mattered even if he were not stupid.  If it's any consolation.
DMcCoy
And they fail from not enough grease, sounds like we need "the three little bears of grease"
GAB
Quote from: WDH on January 20, 2017, 07:52:14 AM
Sounds to me like someone experienced an OH NO MILLISECOND!!!
Gerald
It happened to me him so fast, that it was over in less than a millisecond  :)
Andries
Sounds like 'over greased' lightening going on down there in Georgia.
:o
Hang in there Danny - as a wise man on this forum once said:
"The only SERIOUS accident, is the one that money won't fix."
LT40G25
Ford 545D loader
Stihl chainsaws
POSTON WIDEHEAD
Quote from: WDH on January 20, 2017, 04:05:38 PM
It happened to me him so fast, that it was over in less than a millisecond  :).
It don't take long does it POP..... :D :D :D :D In the blink of an eye.  ;D
The only thing slow about it is when you stand there with your mouth open wondering how that could have happened that fast.  You were probably alone.  I had two bystanders.   ::)
POSTON WIDEHEAD
Quote from: Magicman on January 20, 2017, 07:21:07 PM
......and your first thought is, "This is a bad dream".  :D
esteadle
I have noticed how grease under pressure acts a lot like a hydraulic ram. Pushing out bushings and seals and all kinds of stuff....
Usually I do those things in front of other people too... customers, bystanders, smart-alec kids..
4x4American
Yea, for sure.  Grease is used to tension tracks on dozers and excavators too, so it it's good enough for that it's good enough to put a hurting on a cotter pin.
That sounds like a miserable time Danny!  Was that recent?
Kbeitz
Grease is used to push a stuck piston out of an engine block by making
a spark plug grease fitting adapter and pumping the cly. full of grease
Love machine shop work
and Wood work shop work
And now a saw mill work
Seems like those moments last a looooooooong time. And it seem like you can't move fast enough to make whatever is just about to happen,not happen.
Brucer
Something I learned a long time ago at a maintenance seminar put on by Shell -- unless the manufacturers' instructions say otherwise, only use one shot of grease. You're not trying to fill the bearing with new stuff, you're trying to move along the grease that's in the system.
Of course if you don't grease as often as you're supposed to, this isn't going to work so well.
Bruce    LT40HDG28 bandsaw
4x4American
 :D  When I grease the backhoe I'll use 1.5-2 tubes of grease, the tractor will use one.  I pump til I hear or see grease coming out.  But thats also on pins that are taking alot of abuse
D-U-G,
It happened to me him on Wednesday.
Yes, alone.  Would not have happened if a certain someone could control the weather better.
paul case
I would have swore that you were talking about another forum member that has chimed in here. He told me a story very simular to yours and he actually finished the job without the arm. He didn't lack much and when you saws and leaves you gotta finish if you can.
PC
pc
Nothing like a little magic  :D.
MartyParsons
Hello,
   Yea I have see the cotter pin sheared off the clutch pivot. But I have also seen the dust fall out of the pin and the grease worms eat the pin almost 1/4 the way though. Keep on greasing !!  The last few service jobs I had were to say the least pretty bad. Lots of torch work to get things moving again.
You can use a bolt and a fender washer to pull the bushing back in place and keep it straight. If you try to pry it and it gets angled it gets much harder and breaks the flange off the bushing.
Marty
4x4American
Thanks Marty,  I should have gave you a call.  I called up Indy and the guy told me to jack up the engine to get the psi off the head.  So I hooked a chain to the engine hoists and lowered the head down to get psi off.  Still couldn't get it to draw back in, talked with James in Orgeon and he told me to reverse connect the turnbuckles and itd be easier.  Did that and ended up taking it all apart to see why it still wouldn't go back together.  Saw that the tolerances are tight and the grease was holding it hydraulically.  Cleaned it out and rubbed grease lightly on the innards and it was great.  Schaeffer's 238 Moly Supreme grease is tough stuff
Kbeitz
Quote from: Brucer on January 21, 2017, 01:46:19 AM
I think he is dead wrong. That's true with certen sealed bearings.
I also went to a maintenance seminar in Georgia and the instructor
said older bearing you grease until you push the dirt and grinding out.
He said all bearings make there own dirt and you need to push that out.
Also any tractor type pins you need to grease until it come out clean.
When I grease a sealed bearing I pump real slow until I see grease pushing the seal.
4x4American
I agree with Kbeitz, but I want to add, they're probably using metric grease and grease guns up there so the ratios are probably completely different.
terrifictimbersllc
Quote from: 4x4American on January 21, 2017, 09:40:32 AM
This humor needs to be taken with a milligram of salt.
