Fixed head versus dangle head
Started by deastman, January 22, 2017, 04:32:51 PM
deastman
Samsung 130 LCM-3 with Fabtek 4-roller and Cat 554 forwarder, Cat EL 180 excavator, Cat D3C dozer, Cat D7E dozer, '92 Ford LTL 9000 dump, Easy-2-Load 25 Ton tag-a-long, current project under construction: '91 Peterbilt 379 with a Hood 8000 w/extenda-boom loader
sawguy21
wannaergo
I have run tracked machines with both fixed and dangle, and we recently bought a rubber tire machine with a dangle, and in my honest opinion, it's the only way to go. Way smoother, faster, and more comfortable. I will honestly say I will never run another fixed head.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
chevytaHOE5674
I run a rubber tired dangle head machine with a 30 foot reach boom. I can reach and cut a lot of wood without very much driving around, this is a lot easier on the ground and allows you to cut in places a tracked machine can't go. Its also quick on the ground and easy to move and drive around in, jobs that are close to one another you can just drive there.
As for the head itself a dangle head can cut some big timber once you know what your doing. In smaller wood you can put some serious wood on the ground in a hurry.
deastman
Thanks for the info, I run a fixed head but the dangle heads seem to get a lot more production. How do they work in medium to large hardwood?
wannaergo
I cut a steady diet of medium to large hardwood, and I think a bigger dangle head is the way to go. I can notch and cut a 30"+ hardwood and process it. Bigger dangle heads can do even bigger. It takes a lot of finesse, but I think it's quicker and safer than a chainsaw, even in really big stuff. My Ponsse H8 is just an animal in bigger hardwood
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
chevytaHOE5674
The vast majority of what we cut is hardwood thinnings with a good bit of 20"+ sawlogs. For the most part anything 24-28" and smaller I cut with the machine, larger than that I hand cut unless I know for sure its pulp then I will hack it to the ground. And this is all with a 20k hour machine with a 21" bar.
Here's a 21" hard maple being dropped with the machine.
All these logs are processor cut.
Mike_M
In the Pacific NW the dangle heads are by far the most popular, with Log Max, South Star and Waratah being the most popular. The guys that run them put out a lot of wood on a daily basis. We run TJ 608 with a TJ 762C head and a squirt boom and it works real well for us. It sure is a lot better than cutting and processing by hand.
wannaergo
I think that the southstar head would be fantastic for big hardwood. I demoed one and thought it was great.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
BargeMonkey
 Any of you guys seen or used one of the "Timberheads" ? I think they only make 2 models right now. I watched a 7000XT dangle on a new Cat last spring down the road from me, CTL isn't common down here. After 30mins watching this thing in 28"+ nasty spruce I walked back to my truck feeling like a kid who had just watched his dog get run over  :D   I do "ok" with the typical "buncher/grapple/delimber/slasher" but this thing was nasty to watch, I saw where he had cut real nice large HW logs with it, without issue. I can't get away from a buncher because of some of the clearing jobs I'm chasing, but I think a dangle head is the way to go.
snowstorm
Quote from: wannaergo on January 22, 2017, 11:27:14 PM
southstar was started by some guys that used to work for warthar . last i heard southstar sold to quadco
snowstorm
dose milton cat still have that big tracked machine with the 870 keto? that would handle any tree that grows in this state
deastman
I haven't seen anything in there with a keto head on it.
snowstorm
Quote from: deastman on January 23, 2017, 07:15:16 AM
maybe they sold it. the head was new and big very big
deastman
Quote from: chevytaHOE5674 on January 22, 2017, 08:43:56 PM
What size machine do you run and what head do you have?
1270d
I'll cast another vote for dangle head.   It's the only type I have run but find them very effective for almost any type timber in the size class chevytahoe mentioned.    Very accurate measuring as well.
I'm running a Ponsse scorpion King with H7 head.
Chevy runs a Ponsse ergo with h73 head I believe
chevytaHOE5674
1270D is correct a 6 wheel Ergo with an H73E head, think the machine is around 40k lbs.
barbender
I haven't run harvester very much, but I can tell you what I see being used up here. There used to be a few Fabtek fixed heads around, and a few Timbco fixed heads. There's still a few Timbco and Timberpro dangle head setups, and a number of 703 Deere dangle heads. But the fact is we cut mostly pulp, with some pine bolts and sawtimber, and most hardwood that isn't pulp or firewood goes for pallet logs. The rubber tire dangle heads are quuckly taking over, a big track carrier and fixed head is just not needed in our conditions. I will say, cracked butts can be a problem with the dangle head if the operator isn't being careful, I throw a lot of butts that would make saw logs into the pulp pile because they are cracked. But that is more operator error than anything, IMO. Don't get me wrong, with a hardwood with a big crown getting it on the ground and not on top of the cab is the primary concern. These processor operators that cut a lot of HW could tell you better. Would a quick back cut keep the butts from cracking? Anyways, it's becoming rubber/dangle all the way up here.
snowstorm
your not that far away. come try mine if you want. 500 keto
chevytaHOE5674
Quote from: barbender on January 29, 2017, 11:11:08 PM
Depending on the size of the tree I need to cut a majority of the front of the tree out, then spin the head around the back and clip the holding wood in the back then flop them over. (On a tree without much lean I will cut out 70+% of the frontside), If I just try and cut from the back then I really can't cut fast enough as the tree will start to move and split or barber chair on the way down.
1270d
Quote from: snowstorm on January 30, 2017, 05:55:37 AM
Keto makes all the way up to a 1000 model don't they?
snowstorm
1270d
I viewed another video as well, that things an animal.
snowstorm
i met the owner inventor of keto at the bangor show 2 yrs ago. his English wasnt that good and i dont understand finish
deastman
Quote from: 1270d on January 30, 2017, 06:42:08 PM
Thanks snowstorm, I'd like to see yours work sometime
