Arborwear
Author Topic: TF Wiring Question (vertically behind a post)  (Read 395 times)
Offline jb9
« on: January 24, 2017, 11:33:34 PM »
Hello,
I searched the forum and didn't find the answer I was seeking so I will ask a question here.  I know it is common to put a strip of 5/8" strapping on the outside of a post so that a SIP panel can allow a 1/2" sheet of drywall to slip in behind the post.  I am planning on running romex behind my posts horizontally and using a baseboard to hide my horizontal runs of wire.  I am however curious to know if I can run romex vertically on the back of a post up to a 2nd floor location.  I know it's not a huge cavity and I don't know if it could be planned out during the SIP installation but I thought I would ask.  I am aware of the code requirement for staples at a specified length but I wasn't sure if that was for horizontal runs only.
I have attached a picture that hopefully describes what I am asking.
Thanks.
Offline ljohnsaw
Re: TF Wiring Question (vertically behind a post)
« Reply #1 on: January 25, 2017, 01:54:02 AM »
I think you might run into problems.  Code might dictate that you have nailing strips/protection.  Steel covering the wires so that they don't get hit when you are nailing the SIPs in place.  I'd probably make a bit of a groove in the back of the post (1/8"+/-) so that I could place a 3/4" conduit with sweeps on the ends.  Then you could slide wires in after the SIPs are in place and before the drywall goes up.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline logman
    • M&K Timber Works
« Reply #2 on: January 25, 2017, 08:11:43 AM »
I did that on both timber frame homes I've built for ourselves with no problems.  Both passed electrical inspections.  I wired them after the sips were on so there was no danger of hitting the wires with screws.
LT40HD, 12' ext, 5105 JD tractor
M&K Timber Works
wiring question
Started by Dan_Shade on General Board
Last post January 08, 2009, 05:34:35 AM
by Dana
Wiring question??
Started by Josh3760 on Sawmills and Milling
Last post January 10, 2016, 08:25:15 PM
by dean herring
Storing a hydraulic log splitter vertically?
Started by Warbird on General Board
Last post October 23, 2007, 03:36:30 PM
by breederman
Winch wiring question for trailer
Last post September 24, 2005, 02:01:55 PM
by rebocardo
