Author Topic: Leveling the head on an MP32  (Read 668 times)
Offline kelLOGg
« on: January 27, 2017, 07:44:21 AM »
I usually don't think about checking the level on the head but when I do I usually find that it is off maybe 1/16 to 1/8". I check it by placing a spacer between one of the feet and the main rail and lowering the head until I make contact. (see pic) I remove the spacer and check the other side. There is usually a difference. Has anyone observed this? My mill is 15 years old so I don't think it is uneven wear on the lift chains. My latest thought is that there could be difference in buildup of sawdust/debris on the overhead sprockets. One side could pick up more debris between the cogs effectively increasing the apparent radius of the sprocket and that side would be higher than the other. What do you guys think?
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
WM LT15 or Cook's MP32
Started by Woodman12 on Sawmills and Milling
Last post May 09, 2012, 07:54:23 AM
by MotorSeven
Inside out sawing on an MP32
Started by kelLOGg on Sawmills and Milling
Last post June 21, 2012, 01:22:05 PM
by qbilder
Inside out sawing on an MP32 - part 2
Last post June 25, 2012, 06:30:15 PM
by beenthere
a few questions about cook's mp32 mill
Started by T.J. on Sawmills and Milling
Last post February 19, 2009, 05:57:25 AM
by kelLOGg
