Arborwear
Author Topic: Chainsaw Milling Help  (Read 1808 times)
Offline richhiway
  • Rich
Re: Chainsaw Milling Help
« Reply #20 on: January 31, 2017, 01:13:52 PM »
Nice rig and a great stack of nice logs!
Logosol M-7
New Holland 35 hp tractor
International T-6 Dozer
Takeuchi mini excavator
Stihl Chainsaws
Offline alabama
  • "Wannabe Chainsaw Miller"
« Reply #21 on: February 01, 2017, 12:08:58 AM »
@richhiway, they no longer make the esol7 and now it is the 8 and at a cost of $2,500 plus shipping $300. I noticed that you have a DJI on your videos and I have an inspire 1 that I use to check the land and livestock without and believe it or not I can herd up the sheep with it. Works better than the dog! :)
John 15:13
Greater love has no one than this: to lay down one’s life for one’s friends.
Offline richhiway
  • Rich
« Reply #22 on: February 01, 2017, 07:39:36 AM »
I bought mine used on craigslist for $1,100.00. And the 046 used on craigslist for $300.00.
Believe it or not my drone got away from me in the wind the other day and it and my go pro are among the missing!
Logosol M-7
Stihl Chainsaws
Offline kjudd
« Reply #23 on: February 01, 2017, 10:31:59 AM »
Logosol makes the m8 farmer that's $1800 but it generally can be found cheaper. I was considering that before I found the Procut plans.
Online YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #24 on: February 01, 2017, 05:41:28 PM »
I'm quite sure there are owners of each of these mills here on the FF that would recommend them.  If we know your approximate location, might even be someone near you to let you see and use one.
I'm in north Alabama and have both.  I might even let you have my Alaskan mill, minus the chainsaw, of course ;D
I started with one, many years ago, and ran it a decent bit, until I wore out an expensive Stihl 440 (I think it was).  I called it the "puker" as I would run it until I got stomach cramps, then call it a day.
On second thought, if you drive here, I'll let you have the durn thing, one FF member to another.
HobbyHardwoodAlabama.com
Offline alabama
« Reply #25 on: February 03, 2017, 01:21:37 AM »
I'm in north Alabama Talladega county. If anyone has a M7-M8 for sale I'd be interested. I placed my order on a M661and should be here next week. Thanks for the offer shoot me a pm. Thanks for all the help everyone!
John 15:13
Offline alabama
« Reply #26 on: February 03, 2017, 01:25:33 AM »
@richhiway-  by any chance have you found your birdie? I assume you didn't have a GPS located on board or can you check your log files like I can on the inspire 1? I know how you feel it is an empty feeling inside.
John 15:13
Offline SwampDonkey
  • Large Tooth
« Reply #27 on: April 20, 2017, 04:31:06 PM »
I get a kick, if it were, out of some of this fellows milling around and harvesting, projects and yes.......weaving. I think he is quite intelligent about it, but he does ramble a lot about this and that. :D
Immigrant chest
200 year old loom
Dirty Harry
Offline mad murdock
« Reply #28 on: April 21, 2017, 01:58:33 AM »
Alabama, my start with chainsaws began when I worked in the woods full time, my brother and I  messed around with one of those little lumber makers I think it was a "beam machine". Later on we did quite a bit of milling by helping on a circle handset mill that one of our friends had and milled up some of our own logs. After several years of haiatus, I got back into milling with a Grnberg Alaskan MK III. I have milled much with it on my Hsqvqrna 372XPW. I progressed to a Logosol Timberjigg which worked ok, then I found an old bumblebee sawmill which I used quite extensively. I had toyed with the idea of a BSM, but for the effort I really wanted to go
With a circle mill. I wanted to retain the extreme portability a chainsawnpowered mill offers and get much more efficiency at the same time, which is why I bought a Turbosawmill warrior M6. I am very impressed. I have it powered by a Husqvarna 395XP and it is doing awesome!  Do what you can with the CSM until a better method becomes clear to you. You can do a lot with a chainsaw,2 or 3 is better). I had one set up with the Alaskan, another with the Timberjigg and yet another with a homemade "minimum copied After the granberg style. This was the best. Because you could open up a log with the MK III then edge with the mini mill or the Timberjigg and then get to slicing boards rather quickly. Also having a saw for each task spreads the wear and tear and really speeds things up as you are not having to stop and readjust for the next cut all time or flipping logs which saves the old back.
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline ToddsPoint
  • Stockmaker and Carver
« Reply #29 on: April 21, 2017, 05:39:59 AM »
I've been milling for 5 yrs. with a Logosol M7 ($1200 used on Craig's List) and a Stihl 660.  I make gunstocks and have milled a lot of walnut into blanks.  I cut the walnut 11/4.  Milling gunstocks is about the most wasteful thing you can do with a log so the small extra waste from the chain kerf don't amount to much.  If I was wanting to make dimensional lumber I'd buy a Wood Mizer for sure.  My CSM is slow, but I'm retired and I'm slow too.  I have a 28" bar for most logs but also have a 36" for crotches.  I mounted 2 removable wheels on the Logosol and can tip one end up and roll it in and out of my barn, or onto my trailer for a mobile job.  CSM fits my needs okay for gunstock blank making.  If it didn't, I'd already have bought a bandsaw.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Offline theonlybull
  • no comment eh
« Reply #30 on: April 25, 2017, 06:50:05 PM »
i'm pretty new to the milling scene... other then a stint in a big comercial mill in my younger days.
i've reciently built a chainsaw mill,  and electric one, with a bed, and carrige, similar to the bsm.
i'm running a 5hp 3450rpm electric motor, and a 24" bar, with a rip chain.  all i have cut sofar, is poplar (easy to get, i've cut around them for years, and left them standing).  an 8' 2x8 takes just about 65 seconds to cut.  a 14' x2"x12", is more like 3-4 minutes, depending on how sharp things are.  i do need to play with my chain a little bit, i could handle far more agressiveness with the electric motor.
so far, i've cut about a dozon logs(pretty green myself)  but i'm happy with it.  it's been giving me a good cut(as nice, or nicer then a bsm) and everything is nice and true.
not sure if this will work,  but i'm one instagram as "theonlybull"
https://www.instagram.com/p/BTMWdCWli07/
look up snik electric sawmill on youtube, to see a really sweet electric csm
Keith Berry & Son Ltd.
machine work and welding
chainsaw milling
Started by gginseng4 on Sawmills and Milling
Last post November 08, 2013, 08:28:12 PM
by Gasawyer
chainsaw milling
Started by 76gmc on Sawmills and Milling
Last post January 02, 2012, 01:20:45 AM
by Brucer
Milling with chainsaw
Started by plantman on Sawmills and Milling
Last post March 12, 2017, 12:41:58 AM
by Brucer
Chainsaw Milling
Started by iain on Chainsaws
Last post March 10, 2006, 10:00:43 AM
by beenthere
