Arborwear
Author Topic: The best clearing saw / brush cutter  (Read 9597 times)
Offline SwampDonkey
  • Large Tooth
Re: The best clearing saw / brush cutter
« Reply #40 on: July 29, 2017, 02:41:41 PM »
Amick's in North Carolina sells both the 8" (200mm) Maxi Blades and the 9" (225 mm) Maxi Blade. They advertise as "Windsor" brand, but there is a note saying "It will be labeled Carlton, Oregon or Windsor, all are from the same manufacturer." THese have the 25mm/1" arbor hole. Both are described as Swedish steel.
Yes, they are all the exact same blade from same place.
Stihl "Maxi" is Japanese steel.
Some people will file them down to hardly any tooth left. I never go that far with them, they won't cut as good past a certain point, especially in 4"-6" hardwood or spruce. Way more productive to reach for another blade. I'd rather spent $25 to make an extra $300, then to loose $300 production to save $25. :D
Dirty Harry
Offline John Mc
« Reply #41 on: July 29, 2017, 04:24:52 PM »
I couldn't find the Stihl Maxi on the Stihl USA web site.
Offline SwampDonkey
  • Large Tooth
« Reply #42 on: July 30, 2017, 01:25:34 AM »
And Stihl Canada doesn't either. And you really have to dig on their site to find the chisel and scratcher tooth blades.
Windsor Maxi  Not available though. They sell them here at Husqvarna shops.
Dirty Harry
Offline AnvilRW
« Reply #43 on: August 01, 2017, 01:50:33 PM »
We have a Stihl 560 and using their chisel toothed blades it will wack through a 3" to 4" gambel oak in one slice if they're green.   You kinda' have to work on your technique, but you just swing at them from left to right and it will pop right through in one stroke.  If find it too cumbersome and slow to actually put the blade up to one and try to saw through it conventionally.  We use it for the trail clearing, but like a chainsaw, you hit one rock or too much dirt and you'll spend a lot of time sharpening the blades.  It's an invaluable tool for spot clearing but I've found that an ATV with tow behind trail cutter is much better and faster if you can manage the terrain.  If I can drive the ATV over it, the trail cutter will cut it.
"A man with any character at all must have enemies and places he is not welcome—in the end we are not only defined by our friends, but also those aligned against us."
moved
MOVED: The best clearing saw / brush cutter
Started by chet on Forestry and Logging
Last post January 31, 2017, 11:42:16 AM
by chet
Brush cutter
Started by dancan on General Board
Last post June 05, 2006, 02:43:59 PM
by submarinesailor
brush cutter blade info
Started by isawlogs on Forestry and Logging
Last post November 16, 2011, 05:33:50 PM
by SwampDonkey
Need a Professional Forestry Brush Cutter
Started by WDH on Ask The Forester
Last post April 15, 2007, 01:30:48 PM
by SwampDonkey
