Author Topic: 1963 Farmall 706  (Read 1088 times)
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
1963 Farmall 706
« on: February 04, 2017, 06:40:02 PM »
I understand the terms  :)
While taking pictures of the forwarder I decided to sell the 706 too.  It's 1963 model.  It runs, smokes some, starts hard, has one almost new BKT rear tire, the other is round and holds air.  Front tires are good.  The head gasket is blown.  It's an external leak on the back corner of the block.  I've heard they were known for this.  No oil get's in the coolant, no coolant gets in the oil.  It'll miss until it warms up.  We ran the Corley with it a year ago last fall.  It did very well.  All the glass is good in the cab and the cab is solid.  It has a heater but it's rotted out.  2 point fast hitch and I have the adapters to make it a 3 point.  Shifters a bit loose like they all are but it works.  Torque Amplifier does work or it did.  I rarely used it round baling but it did work.  I tried to save it ;) ;D  We used it a few years haying but retired from that a while back.  I've got a 10' pull type Bush Hog that I used behind it a couple years.  I've got the side panel and the grill in garage.  The split wheel weights don't go with it but I'll throw in two pairs of solid weights.  The tires don't have fluid in them.  It's really too big for what we do know so it can go down the road.  Make me an offer I can't refuse  ;D ;) :) 8)  In a week I'll list it on Craig's List.
Farmall 706 1963
Started by Corley5 on For Sale
Last post June 01, 2018, 10:45:31 PM
by Corley5
Restoring a 1963 Cancar
Started by longlegger on Forestry and Logging
Last post June 15, 2016, 11:44:01 PM
by customdave
1963 Mcculloch 740 air filter
Started by skynard33 on Chainsaws
Last post April 23, 2015, 03:43:40 AM
by skynard33
moved
MOVED: Restoring a 1963 Cancar
Started by chet on General Board
Last post June 09, 2016, 12:07:53 AM
by chet
