Author Topic: CANT HOOK or LOG PEAVEY for turning logs  (Read 4277 times)
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: CANT HOOK or LOG PEAVEY for turning logs
« Reply #20 on: February 10, 2017, 08:35:46 AM »
When I ran the manual mill and had to frequently turn logs on the mill, I used a cant hook because I sawed a lot of good quality, furniture grade, walnut, cherry, etc., and the cant hook does not mar the cant to the extent that the sharp point on a peavy does.  People won't buy boards with holes in them.  It all depends on your plan and strategy.
I imagine your customers will be disappointed to hear that you are no longer sawing "good quality, furniture grade, walnut, cherry, etc.".  ;D
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #21 on: February 10, 2017, 09:57:16 AM »
Gotcha!   :D
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #22 on: February 10, 2017, 08:16:59 PM »
Yes, I have had to rely on some Mississippi sawn lumber.  Well sawn, though.
Offline alabama
  • "Wannabe Chainsaw Miller"
« Reply #23 on: February 12, 2017, 08:51:43 PM »
I'm looking at the Stihl products and placing an order on a cant tomorrow and see how it works out. From reading it appears that the size makes a difference. So I'm uncertain which length to go with. I'll be using it for general purposes of saw milling and on the land. I have a John Deere tractor with a grapple so for me picking up the logs will be a breeze but I need something to turn the logs on the sawmill.
John 15:13
Greater love has no one than this: to lay down ones life for ones friends.
Offline btulloh
« Reply #24 on: February 12, 2017, 08:58:25 PM »
48 works pretty good for me.  Not big enough for real heavy or big logs but I find it's better to use the fel or winch for those.  I have a 36 that i use a lot, but not for turning logs on the mill.
HM126
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #25 on: February 12, 2017, 09:01:48 PM »
I have four; a 60", two 48's, and a 24".   If I were limited to only one it would be the 60".
Offline alabama
« Reply #26 on: February 12, 2017, 09:13:49 PM »
For now I'll be limited to one and if that is the case I'll go with the 60. You guys are always great and thank you for the pics that really helped!
John 15:13
Offline btulloh
« Reply #27 on: February 12, 2017, 09:45:12 PM »
Nice variety MM.
Alabama, you should get a hookaroon as soon as you can. They are worth their weight in advil.
That 60" cant hook will guarantee you some leverage. Keep an eye out for a short one at flea markets, etc.  A wood handle won't get you in too much trouble with a short one.
I bet you'll get hooked on sawdust.
HM126
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #28 on: February 12, 2017, 09:56:55 PM »
The wood handled ones are a waste of your time.
Offline btulloh
« Reply #29 on: February 12, 2017, 10:00:47 PM »
Why so, Jeff?  I don't put enough umph on ghe short one to break the handle.  Just curious.
HM126
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #30 on: February 12, 2017, 10:09:07 PM »
It ain't the umph, it is the log gripping ability.
Here is what I was using before I got my 60" Logrite.  I had never realized how much better that better was.  Logrite's hooks are arched correctly and maintain their sharpness so that they grip and hold rather than loose their grip, slip, and bust your cookie.  It did not take me long to increase my Logrite arsenal to the present level.  One more 60" is on my want list.
Offline btulloh
« Reply #31 on: February 12, 2017, 10:22:03 PM »
You're right about that.  They do grip better.
Would you rather have just the one 60 inch Logrite, or the 60 inch Logrite plus a an old 30 inch you found in your friend's barn?
HM126
Offline WDH
« Reply #32 on: February 13, 2017, 07:33:15 AM »
I have turned many a log, and if I only had one, it would be the 60".  Even on a hydraulic mill, you sometimes had to help a big misshapen log go from the loader arms on the mill, so my Logrite 78" megahook makes that easier to do.
Offline Jeff
  • Fearless Leader
« Reply #33 on: February 13, 2017, 08:28:38 AM »
The one I found in a friends barn would go on the wall.   I have a hammer. If I found a rock, I wouldn't put it in my toolbox so I had another hammer.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #34 on: February 13, 2017, 10:59:43 AM »
I could always use these......not.   ;D
Offline Upper
« Reply #35 on: February 13, 2017, 11:27:40 AM »
My son bought me this 60 incher,but I am having a little trouble with it...
Stihl 661
Alaskan 36 CSM
36" guillotine splitter powered by a GMC V6
I like to build stuff
LT35HD Wood-Mizer
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #36 on: February 13, 2017, 11:49:50 AM »
That's made for the backwoods logs.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Jeff
  • Fearless Leader
« Reply #37 on: February 13, 2017, 12:11:40 PM »
Must have been a mix up at the factory. That has a New Zealand hook on it.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #38 on: February 13, 2017, 12:38:25 PM »
I think that they are shipped like that to fit in a smaller box
lots of dull bands and chains
Offline Tam-i-am
  • Sponsor
  • Gender: Female
    • Logrite
« Reply #39 on: February 13, 2017, 12:40:32 PM »
In order to fit in the box we have to reverse the direction of the hook.  On the hook is a sticker that tells you to change the direction of the hook.  On the directions and warranty sheet it tells you to reverse the direction of the hook before use.
moving big logs - peavey vs. cant hook
Started by rebocardo on General Board
Last post July 24, 2006, 03:46:13 PM
by rebocardo
Cant Hook, vs Peavey
Started by Nate Surveyor on Sawmills and Milling
Last post December 03, 2007, 11:07:10 PM
by Dave Shepard
Peavey-cant hook ???
Started by Beaudeane on Sawmills and Milling
Last post January 20, 2013, 07:21:17 PM
by SwampDonkey
Cant Peavey Hook
Started by 4x4American on Sawmills and Milling
Last post July 30, 2015, 08:02:01 AM
by Magicman
