Arborwear
Author Topic: Borax and bugs  (Read 2327 times)
Offline Don P
    • Calculator Index
Re: Borax and bugs
« Reply #20 on: March 19, 2017, 12:01:06 AM »
The recipe longtimelurker posted is one I've seen from an old navy spec. It did call for heat, I believe around 150 degrees F. When combined and heated with water it makes DOT, the chemical in all of the wood preserving borate mixes. Plantman has posted that recipe in one of these many threads recently. I've never used that recipe, seemed too hard to do in the field. I buy DOT directly, you can buy Timbor the listed chemical for the use. Just add water and stir, when the milky color turns clear you are ready, warm water mixes faster. I buy Solubor, listed for ag use as a boron amendment, chemically identical to Timbor. You can get this wettable powder from a real farm supply, last I bought was around $90/50lbs. Beau-ron is the same thing from another manufacturer and comes in 25lb sacks which is a little easier, I usually make 25 gallons or so at a time.
So there is my recipe, for a 10% solution mix 1 lb of powder to 1 gallon of water and you have a Timbor solution, suitable for green wood. Add 1 gallon of antifreeze per 5 gallons and you have Bora-care for dry wood. That concentration is stable down to below 40 degrees. 1.5 lbs/gal is a 15% solution, use immediately, it will begin to make rock candy on the surface of the bucket pretty quickly depending on temperature. Thoroughly rinse any spray equipment if you apply that way, it will clog if left.
 Understanding that the glycol is simply a wetting agent helps temper your antifreeze use. If you read and saw the test pics in the UPenn paper, glycols make a worthwhile difference in penetration. Basically if you see white crystals on the surface you aren't going to get any more in, a layer has dried and crystallized within the surface of the wood. Do get that off before you finish with a wet rag or sanding, with a mask. I left it on the old cabin I talked about above. They didn't want a finish on the historic cabin and so I left the light crystallizing remaining as my telltale. We decided that when those crystals leach away we would hit it again. I believe that was in '02 and last time I checked we don't need to do it yet. The house has overhangs and walls don't really see that much water.
I don't typically treat pine here, nothing wrong with doing it, I just don't see that much beetle damage to pine locally, they hit many of our hardwoods hard. Borate only works on insects that ingest the wood. Carpenter bees are our problem in pine and they are simply nesting not eating the wood so it is a waste to use it for them. They are in our CCA treated pine fascias, proof enough they aren't swallowing.
The cedar is naturally bug resistant so I wouldn't worry about it. I'd dip the aspen and it is up to you whether to do the pines. Borate also stops decay fungi, that might help you decide. I saw the comment somewhere that borate is also used as a fire retardant, it is, you are not going to be able to get to those levels in the field.
Edit, I see plantman has moved some of his links to this thread, I mentioned some of those in this post. We've about whipped this poor horse to death  :D
Edit... again. Plantman, if you want to try to duplicate Carnell's experiments with glycol, glycerin (floral supply) and sugar, Terro ant bait is DOT and sugar
Offline ljohnsaw
Re: Borax and bugs
« Reply #21 on: March 19, 2017, 02:50:42 AM »
Don,
Where is "here"?  You don't list your location in your profile. ;)
In the above link describing the tests done in the 1980s with the text of Dave Carnell's article, it was talking about using high amount of glycol to aid in the penetration, especially in wet (green) wood and subsequent stabilization. The discussion is fascinating.  His assertion was the glycol is very hygroscopic so it tends to pull into green wood better.  That recipe was this:
Home-Brew Glycol Solution of Borates: 50% glycol antifreeze, 28% borax, 22% boric acid. To make a stable solution you mix the ingredients and heat till boiling gently. Boil off water until a candy thermometer shows 260°F. (This removes most of the water of crystallization in the borax.) This solution is stable at 40°F and has a borate content of 26%. With antifreeze at $6/gal. and borax and boric acid prices as above, this costs about $15/gal.
Regarding the percentages - that must be by weight, correct?  Also assuming the borax and boric acid are powders?  I see him using the high amounts of glycol for wood stabilization - something that interests me greatly.  Your use of glycol is a much lower percentage and also no cooking!  Has that been working well for you?  Do you see a reduction in checking or are you not aiming for that?
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Don P
    • Calculator Index
Re: Borax and bugs
« Reply #22 on: March 19, 2017, 08:24:22 AM »
Here is southwestern VA.
My main goal has been to keep insects out of the wood or to remove them from existing buildings I'm working on. The navy spec is by weight. The powders I am using are the DOT that the navy mix will create. It is made to tank mix for agricultural spray rigs... that is way to go IMO, ask for solubor in the wettable powder at your farm supply.
Yes it does work to keep beetles at bay. My starchy woods especially tulip poplar and sweet birch are quickly riddled if left untreated. They may try the surface but the wood is not thoroughly tunneled out the way it is if left untreated. During a hatch I can see them as clouds in the air and they will hit untreated wood overnight. I'm adding enough glycol to keep the wood wet looking when I'm working on an old building vs quickly drying. Once you see the wood dry it doesn't seem to accept any more borate, you are trying to dissolve a tough crystalline film. For that use I'm using a cheap pump up sprayer and flooding it on, multiple passes, this isn't fancy perfume, get as much into the wood as you can. At the mill without glycol I'm dipping. For timbers I usually rough notch my mortises and tennons and then dip. I usually roll those around in the homemade dip tray while I work on the next one, they can be in there for an hour or overnight. Interestingly black locust turns the solution a nice yellow, looks like a possible dye.
So to glycol, I'm cheap and use enough to keep a wet edge. I am interested in learning more about it as a wood stabilizer. Our little group of woodworkers is getting into slabs and big timbers and every woodworker dreams of stable wood. I'd like to think I've seen positive results in that regard but that would be seriously anecdotal. Carnell's experiments are closer to science, I've never done side by side experiments or high loadings of glycol. Keep searching for tests, test yourself and holler back. So, does borate work, yes, does glycol work to reduce checking, I suspect so. When we would travel around building log homes I would tell the homeowner to go ahead and put on a finish if the logs were green even if the finish was going to fail prematurely, it did visibly reduce checking by moderating drying conditions. Flood made a product back then called seasonite that helped there. That experience helped form my opinion about playing with the drying gradient. Best luck, off to finish mucking out an 1820's log barn.
Offline cwimer973
  • I'm new! Wood-Mizer LT10 - Please Help Me Learn
    • Wimer Hardwoods
Re: Borax and bugs
« Reply #23 on: March 19, 2017, 09:11:51 AM »
When using for furniture will these solutions cause issues with glue ups, stain or finishes taking properly?  I have two walnut benches 1/2 done and I noticed a little powder below one a few months back but nothing since.  Thoughts?
Your Fellow Woodworker,
- Chris
Offline plantman
Re: Borax and bugs
« Reply #24 on: March 19, 2017, 10:08:24 AM »
The focus of Dave Carnell's research with ethylene glycol was around wood stabilization. I believe what he found was that EG was effective because it had small molecules which penetrated well and  had a strong affinity for clinging to water molecules. This pulled the EG into the wood filling voids which would ordinarily occur as the wood dried. The EG would not evaporate like water and would thus keep the wood saturated and resistant to warping, cracking, shrinking, etc. While borates certainly help to kill fungus and insects perhaps the EG is effective enough on it's own to do the job. Perhaps the borates decrease the EG's ability to penetrate the wood by clogging up wood pores ?
http://forum.woodenboat.com/showthread.php?186402-Ethylene-glycol-(auto-antifreeze)-treated-wood-safey
Offline Don P
    • Calculator Index
Re: Borax and bugs
« Reply #25 on: March 19, 2017, 04:26:14 PM »
I think he was just like us, interested in stabilization, rot, insects. He seems to have experimented with various and many goals.
I think West System has papers on borate treated wood and their epoxies. I've used epoxy and it's fillers and thinners on wood after using a glycol borate mix and all I can say is it seemed to stick to punky wood I was rebuilding that probably would have been better replaced. That's more of a Bondo use than a glueline that needs to take some stress. I've glued and finished borated wood and it seemed to work. I'd say talk to the manufacturers 800 line and see if they have tested with borate or bora-care.
The only problem I've had with finishes is if a piece is very well treated, crystals have showed up under the finish at times. I've injected individual holes with a syringe and borate solution, that depends on which wood eating insect you have.
I wouldn't be surprised if ethylene glycol alone kills bugs when applied, beyond that and with the other claims, I'd like to see more research. I'd like for it to be so, but that doesn't necessarily make it so  :)
Offline ozarkgem
  • age 65 yrs old
Re: Borax and bugs
« Reply #26 on: March 20, 2017, 07:47:12 AM »
Those big wood bees love my cedar. Pretty much ruined my older stacks. I plane some
and almost always on the last pass I uncover a channel in my wood and about 6 bees inside.
Offline Don P
    • Calculator Index
Re: Borax and bugs
« Reply #27 on: March 20, 2017, 09:51:42 PM »
Yup, they're tough. Since they are just nesting and not eating the wood borate doesn't bother them. They can't bite through a tough paint film and I do have some Drione dust I hit the holes with on my buildings but that just moves them over. They are kind of neat in one way, they bore in, turn 90 and head down the grain. Next year they go in that hole to the end, turn 90 and then head down the grain again, I've found some pretty long tunnels in fascia boards before.
I went over to the Forest Products Labs website and searched Ethylene Glycol and mostly got PEG hits. There was one paper that is over my head but in it they are talking about modifying wood with EG. From my take they were having an effect on mechanical properties. The S2 lamella they are talking about in sections is really where most mechanical properties come from. Start with the conclusions if you read this one;
https://www.fpl.fs.fed.us/documnts/pdf2009/fpl_2009_jakes002.pdf
Then just to be more of a bummer, I found a report from '69. They had dipped boards in PEG to try to control checking, it made it worse. PEG is not EG though. It sounds like the increase in checking had more to do with the slow diffusion of PEG than anything;
https://www.fpl.fs.fed.us/documnts/fplrn/fplrn0204.pdf
Adding Borax to my timber finish?
Started by gullydweller on Timber Framing/Log construction
Last post October 21, 2014, 08:37:19 PM
by WDH
Borax/Boric Acid treatment fire retardant?
Started by DMcCoy on Drying and Processing
Last post January 08, 2018, 08:56:02 AM
by DMcCoy
Bugs in my ERC What are they?
Started by ozarkgem on Sawmills and Milling
Last post September 30, 2016, 08:28:47 AM
by ozarkgem
Bad Bugs
Started by Bill Gaiche on Forestry and Logging
Last post February 04, 2011, 10:44:52 PM
by Bill Gaiche
