Author Topic: How long can a log stay a log  (Read 2184 times)
Online moodnacreek
  • Sawin by the notches
Re: How long can a log stay a log
« Reply #20 on: February 17, 2017, 07:15:15 PM »
after sawing for 37 years I have experience with decayed logs here in s.e. n.y. when I get to the bottom of pile the logs are always better.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #21 on: February 17, 2017, 09:05:14 PM »
Moody,
   What kind of logs are you talking about anyway? Your experiences seem to be different than mine. I wonder what is different about the kinds of wood we are used to working with.
Online moodnacreek
« Reply #22 on: February 17, 2017, 09:24:01 PM »
any kind of log I can think of. it's all about heat and the lack of it. many mills water their logs in  summer. some use sun switch like street lites have to turn off the water. also perforated cloth kept wet.
Offline Rhodemont
  • Logging and milling just a hobby
« Reply #23 on: March 02, 2017, 08:10:08 AM »
With white pine will sawing cants to allow them to start drying and storing them for future use prevent the grubs from destroying the log?
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #24 on: March 02, 2017, 08:54:52 AM »
Most likely because removing bark is always helpful. I'd still keep the cant off the ground.
1992 LT40HD
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« Reply #25 on: March 02, 2017, 10:02:18 AM »
The cants will tend to check and also split along the sides, leading to degraded lumber when sawn. Best to mill into lumber and properly stack and sticker to begin the proper air drying process.
Good Luck!
Herb
How long should my blade stay sharp???
Started by aatkins on Sawmills and Milling
Last post June 11, 2014, 02:05:37 AM
by backwoods sawyer
How long will quartersawn white oak kiln dried to 6% stay at 6%???
Started by Jim Spencer on Drying and Processing
Last post August 30, 2010, 10:52:48 PM
by Carpenter
How long can my tops stay on the ground? Black cherry and red pine.
Started by grandgourmand on Firewood and Wood Heating
Last post November 12, 2014, 08:09:08 AM
by grandgourmand
Saw won't stay running
Started by JohnnyF on Chainsaws
Last post October 21, 2006, 08:36:24 PM
by PineNut
