Author Topic: 6x10 Longleaf pine beams for a pole barn  (Read 445 times)
Offline Kerrymr
  • Learning to mill with Norwood LM29
« on: February 23, 2017, 09:42:28 AM »
Just got my first mill to process a bunch of trees that fell on our property during a storm. Milling beams 6x10, 6x8, and 6,6 for a pole and beam barn. The logs are 75 year old longleaf pines. In the deep south with high humidity. How long should I air dry the beams before I should use them to build the barn? I have heard everything from 1 year per inch to build it green. I am using hole through metal plates to connect the timbers not mortise and tenon- not old school enough to tackle that yet.
Newbie to personal sawmilling- grew up in sawmill and pallet industry- Using Norwood Lumbermate LM29
Offline GeneWengert-WoodDoc
Re: 6x10 Longleaf pine beams for a pole barn
« Reply #1 on: February 24, 2017, 07:06:14 AM »
I would think that 30 days is plenty long, as they will dry in place as well.  The main thing is that air drying reduces the weight.  Plus air drying lets you know how much twist or other warp you might have in an individual piece.
If this is indeed longleaf, you will likely find that sawing the logs into flatsawn pieces of 4/4 or 5/4 will generate enough money so you can buy beams from other southern pine species (loblolly) and have money left over.  You might want to file a notarized letter indicating that your longleaf is from windblown trees.
Longleaf Pine for timber frame beams?
Started by ShowMeSawyer on Timber Framing/Log construction
Last post January 02, 2007, 02:43:50 PM
by FrankLad
Help with beams for a pole and beam barn
Started by Kerrymr on Sawmills and Milling
Last post March 01, 2017, 11:14:41 AM
by Kerrymr
Longleaf Pine
Started by Magicman on Ask The Forester
Last post March 27, 2016, 07:12:17 PM
by Texas Ranger
smiley
Longleaf Pine article
Started by DanG on Forestry and Logging
Last post January 09, 2004, 04:35:18 PM
by Stan
