TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Thinking about buying a spare Lt40 but have to decide on a new engine.  (Read 965 times)
Offline just_sawing
  • Making Split Rails Shingles and Sawing
Friend has a 2006 LT40 which the Cat has laid down on. Have to put a new engine on and was wondering on what others have done in this situation and which you like the best.  It is a LT 40 with accuset and hydraulics.
You can follow me at
www.http://haneyfamilysawmill.com
Online slider
  • sawyer,trucker,tree service
Re: Thinking about buying a spare Lt40 but have to decide on a new engine.
« Reply #1 on: February 24, 2017, 07:25:07 PM »
Depends on the extent of damage to the engine.The 3024c's were prone to head gasket failure.If that is the case it may be a simple fix.
al glenn
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: February 24, 2017, 08:23:23 PM »
Depending upon which Cat engine, the current replacement shows to be either a Yanmar 35 or 47 hp.  LINK  It's time to give WM a call.
Offline drobertson
« Reply #3 on: February 24, 2017, 08:26:13 PM »
Wmz told me the cats came from two separate sources, one   forged, the other cast cranks, if you want or need a good one, I know of one, as to head gaskets not sure bout this issue, never seen it,
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #4 on: February 24, 2017, 08:58:37 PM »
Hello,
   Can you describe the engine failure?
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline paul case
  • Original wearer of the PCM.
« Reply #5 on: February 24, 2017, 11:11:53 PM »
3 phase electric no less than 15 hp.
PC
pc
Offline ozarkgem
  • age 65 yrs old
« Reply #6 on: February 25, 2017, 06:33:03 AM »
PC
X2
Offline just_sawing
« Reply #7 on: February 25, 2017, 08:31:35 AM »
This engine has 6000 hours on it and appears to have a crank bearing going. It will start but sounds like a riss pin  or bearing.
Offline barbender
« Reply #8 on: February 25, 2017, 10:40:19 AM »
I'd start by tearing that one down and determining whether it can be repaired.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #9 on: February 26, 2017, 06:52:16 AM »
All the perkapillar  talk lately has me frightened.
Mine started to leak a little oil and it appeared to be coming from the base gasket, so I tightened the bolts a little.
Now it leaks worse.
cant get the base off without raising the engine.
I cant tell if the front seal is leaking or not.
Looks like repairs are too much for me to handle
Thinking about taking it to Hannibal to address this.
Marty's opinion is that all such engines should have the head gaskets checked and the crank support installed.
It seems that WM installed engines that are prone to problems and us owners are in the barrel for any major engine failures.
WM no longer uses the perkapillars.
I think Cooks uses Perkins which may or may not be the same engine.
You dont hear of such problems with the other diesels.
The major auto mfgrs usually issue recalls for such stuff or offer replacements.
a case in point was the early GM  diesels, I had a 79 olds that broke the crank at 50,000 miles and after much back and forth GM stood for a new short block.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline red
  • we will never forget
« Reply #10 on: February 26, 2017, 09:02:06 AM »
If you buy a new GMC 6000 Truck with a Catapilar Diesel . The warranty on the diesel is with  Catapilar not GMC.
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #11 on: February 26, 2017, 10:00:15 AM »
That was a real issue with my mill. Mine came with a defective exhaust manifold, and the local CAT Store refused to fix it, or even look at it. WoodMizer paid another CAT dealership to fix it and said they would fight with CAT over the warranty.
Buying a new saw- can't decide between 385 and 390
Started by Blue Duck on Chainsaws
Last post January 04, 2007, 10:12:25 PM
by parrisw
Im thinking of buying?
Started by nathan87 on Forestry and Logging
Last post July 25, 2011, 04:07:47 PM
by nathan87
Thinking of buying my 1st mill
Started by LaneC on Sawmills and Milling
Last post November 24, 2013, 12:43:09 PM
by LaneC
thinking of buying a kiln
Started by beav39 on Drying and Processing
Last post June 13, 2008, 09:59:57 AM
by OneWithWood
