TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: 12" boards from 6" Peterson  (Read 1110 times)
Offline ButchC
« on: February 27, 2017, 08:43:31 AM »
More sawing from the sawmill rookie, dont be afraid to critique.
I had need for 12" wide x  1" thick limber to rebuild our 2nd floor staircase.  I selected an Ash log that came from the woods as they seem to have much less built up stress as compared to fence row trees. Double cutting looks quite daunting when reading the manual but actually isn't too bad. A person needs to keep his head about him because operating habits gained from single cutting are hard to break. I differed from the manual a bit as this works easier for me when working by myself. Boards are 12" x 1 1/4"
First cuts are same as single cutting. Left side waste removed
Then swing the blade to vertical and shut down the engine for safety. Measure from left cut to blade to set board width. Here the cut has already been made at 12"
Right side waste removed. Had there been enough wood left to make a narrow board there would have been additional vertical cuts.
Full 6" cut on right side. This is where I differ from Peterson's instruction, just worked easier for me.
Now back to left side. First left side cut was 5" leaving  about 1" of wood to hold the board up off the blade. I then wedged the board to hold it up off the blade and cut the last  inch.
And a 12" board. Wide boards are a little bit intensive on the swingmill as compared to a band mill but the staircase lumber is stacked, sticked and drying, about a year from now we will take it to the wood shop and build mom a staircase.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline Percy
  • Resident trouble maker
Re: 12" boards from 6" Peterson
« Reply #1 on: February 27, 2017, 09:45:00 AM »
Nice....dont look like a rookie to me ;D
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #2 on: February 27, 2017, 09:59:50 AM »
Don't look like one to me either.  8)
1992 LT40HD
Offline drobertson
« Reply #3 on: February 27, 2017, 10:34:11 AM »
Happy for you! Looks like you got it going
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #4 on: February 27, 2017, 10:48:22 AM »
Looks like double cutting to me. Good job. How much of a little ridge down the center?
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline ButchC
« Reply #5 on: February 27, 2017, 11:02:45 AM »
Less than 1/8" Id guess?  For the first try I didn't bother with shimming the lead for double cutting as per the instructions. Actually I have yet to fine tune the saw at all and running it as received. Still learning how to run it, then I will tweak it.
Morbark chipper
Case W11B
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #6 on: February 27, 2017, 05:44:37 PM »
Well done ButchC,
The double cut feature is sure handy on the Peterson,
D
Offline tjhammer
« Reply #7 on: March 01, 2017, 03:57:19 PM »
butch does a Peterson saw have an adjustment to adjust the inside plane for the double cut it will eliminate the line in the middle of the board I just got thru cutting some 16in head boards for county dump trucks out of oak its a job for one man doing the cutting
tj
hammer
Offline enewick
  • Member*
« Reply #8 on: March 01, 2017, 06:23:39 PM »
You can adjust the "lean-in" of the blade to remove the step, which is obviously exaggerated when double cutting, but a quick trick is to put a bottle cap on the lean-in adjustment screw, and it should be enough to get rid of it.
Offline ButchC
« Reply #9 on: March 01, 2017, 08:42:33 PM »
Yup, the manual suggests shimming the stop. We will take the time to figure that out next time we have double cutting to preform. As it was the additional  waste from the small ridge will be minimal to none depending on which way tbe boards warp when drying.
Morbark chipper
Case W11B
Spectacular customer service, all together now say "Peterson Portable Sawmills"!
Started by JimBuis on Sawmills and Milling
Last post December 03, 2007, 05:39:55 PM
by revnell
Building a shed with "new boards"
Started by theboman on Drying and Processing
Last post October 29, 2009, 03:23:36 PM
by Tom
"MagSwitch" feather boards??
Started by Warbird on General Woodworking
Last post August 10, 2009, 02:40:52 PM
by Modat22
8 2"x10"x 16' trailer deckin boards Near W MI
Started by johncinquo on Wanted
Last post September 10, 2008, 04:41:41 PM
by oakiemac
