Author Topic: Home made sawmill mods.  (Read 3976 times)
Offline gww
Re: Home made sawmill mods.
« Reply #40 on: March 18, 2017, 08:50:39 PM »
Clover
Yea baby!
Cheers
gww
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #41 on: March 19, 2017, 10:30:15 AM »
That looks very heavy-duty Clover.  Nice work.  How'd you cut the slots in the mounting plates?
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Clover
  • I'm newish
« Reply #42 on: March 19, 2017, 10:48:54 AM »
I first welded the plates together then laid everything out on it. Once I had my layout marks set I drilled 1/2" holes at the ends of the slot locations. Then I cut them with a zip wheel on my grinder. Woke up tasting that stuff in my mouth. The gearbox I drilled 7/16th and tapped the holes for 1/2". Going into the frame I already had two 1/2" through bolts but added three more for torsional strength. The last three I tapped into the frame.
Home made 30 hp sawmill all hydraulic, stihl 026, 170, pioneer 65, John Deere 955 with home made forks. And a whole slew of other tools
Offline Clover
  • I'm newish
« Reply #43 on: March 22, 2017, 08:47:16 PM »
Did some dialing in of my mill last couple days. Had some thick white oak slabs and 5 or 6 pin oaks to cut up. Took a bit to get the governor set right and for awhile I was worried I got the Pulley sizing wrong as the rpm's were dropping to low for my liking. Much improved cutting speed now and the head movement up and down with hydraulics is great.
Here are a couple boards I cut today.
Notice anything missing?
Home made sawmill
Started by Michaeljp86 on Sawmills and Milling
Last post April 23, 2006, 07:47:46 AM
by mike_van
old canadian sawmill, home made.
Started by weisyboy on Sawmills and Milling
Last post February 24, 2011, 09:55:02 AM
by isawlogs
home made sawmill blade tracking adjustment
Started by steve phillips on Sawmills and Milling
Last post February 08, 2012, 09:14:21 AM
by steve phillips
Didn't re-invent the wheel, but made some mods to my LT-10
Started by francismilker on Sawmills and Milling
Last post March 23, 2013, 08:10:34 PM
by francismilker
