Author Topic: Home made sawmill mods.  (Read 3951 times)
Offline Clover
  • I'm newish
« on: February 27, 2017, 10:26:52 PM »
I'm doing some changes to my mill and I thought I'd share them with the forum.
To give some background info I built the mill about 9 or 10 years ago. I ran it for about 20 hours then did some major mods to it and ran it for another 20 before basically abandoning it until this winter.
It's got a 13hp hydraulic power pack and a 30 hp Kohler engine. I've almost got 90 hours on it now and I'm doing some more upgrades. The drive pully is 3" and the driven is 12 with a 21" trailer tire for the wheels. The band speed is a bit lower than recommend and that 3" pully makes it hard to properly tension two B belts. So I've ordered a 5" driver and a 16" driven pully set to help out in that speed and tension department.
I'm also putting hydraulics to raise and lower the head and tension the motor. I will also have a switch that will run a solenoid for the throttle and turn the lube off and on.
This will make the machine much faster as I'm using a winch currently and it can be aggravating to set the proper cut on the log scales. It's also slower and I need to shut the blade down manually.
Here are a few pictures to start one is of the old handle to engage the belts and the others are of the hydraulic cylinder to tension the belts.
Tomorrow I install the solenoid for the throttle.
Sorry if they are not upright tomorrow I will remember to hold the phone correctly LOL
Home made 30 hp sawmill all hydraulic, stihl 026, 170, pioneer 65, John Deere 955 with home made forks. And a whole slew of other tools
Offline gww
Re: Home made sawmill mods.
« Reply #1 on: February 27, 2017, 11:10:50 PM »
Cool, more pictures tomorrow.
Cheers
gww
Offline Clover
  • I'm newish
« Reply #2 on: March 02, 2017, 09:31:57 AM »
I've got a few more things done to the mill. My new drive pulleys are on and also the new throttle solenoid installed. Removed the winch that was used to raise and lower the head and started to mock up the new bearing locations for the lift chains and hydraulic motor.
Old throttle
New solenoid
New pulleys
Old winch
New bearing block
Offline Clover
  • I'm newish
« Reply #3 on: March 02, 2017, 09:38:22 AM »
Since I'm going to be able to get more tension on my pulleys I've been thinking about that upgrade that woodmizer has. It's the flange bearing that mounts on the engine to take some stress off of the motor crank shaft and bushings. Does woodmizer make one for the Kohler engine? It would be easier than making one and quicker as I'm making everything else up. I'm a bit concerned about loosing my engine to bearing failure and the work and cost to repair it.
Offline Rougespear
  • Salmon Arm, British Columbia
« Reply #4 on: March 02, 2017, 07:38:16 PM »
May I ask what you used for a throttle-up solenoid?  I am thinking of a similar mod... I can't tell from your pictures the setup.  Thanks, and you'll be very happy with the new chain lift you are fabbing.
Custom built Cook's-style hydraulic bandmill.
Offline Clover
  • I'm newish
« Reply #5 on: March 02, 2017, 08:21:59 PM »
It's a Kohler throttle solenoid made for the 18 to 25 hp engines. Mine is the 30 but I think it's just a little bigger carb. It went on just fine. It took a couple hours as I've never done one before and the instructions were not worth the paper they were written on. Messing with governors can screw up an engine fast so I was extra carful. I also trimmed the bracket with a zip wheel as the governor arm hit it. The instructions said to bend the arm but it would not have worked as I saw it. All my parts are done to start the chain lift so I will have more pictures tomorrow.
I'll see if I can find the part number for the solenoid
Offline DDW_OR
« Reply #6 on: March 03, 2017, 03:21:51 AM »
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Clover
  • I'm newish
« Reply #7 on: March 03, 2017, 08:35:10 PM »
Made some more progress today. Lots of drilling and tapping I'm not welding anything on. Those cordless drills can almost rip your hand off drilling into quarter inch steel.
This is the lower idler/takeup sprockets and brackets.
This is the hydraulic motor and drive shaft for the #60 chain lifts.
Offline Clover
  • I'm newish
« Reply #8 on: March 03, 2017, 08:53:07 PM »
Hopefully my calculations for the head speed is correct. I'm actually worried it will be to slow.
I will also be changing the final drive sprocket for the head carriage travel speed. It's currently a 19 tooth sprocket I'm going to 22 to speed up the return rate.
Offline DDW_OR
« Reply #9 on: March 03, 2017, 11:01:44 PM »
put a flow control on the feed to the feed motor
Left lever is carriage movement.
first rotate flow control (Feed speed) to zero, then push lever left lever all the way forward, now rotate the flow control to move the carriage forward.
when the cut is complete leave the flow control where it is pull the left lever to move the carriage back to the start location
Offline Clover
  • I'm newish
« Reply #10 on: March 04, 2017, 08:32:37 AM »
Thanks for the pictures DDW. How is the flow control plumbed? I've got a flow control on my mill but it will slow the flow of oil in both directions. I was going to just remove it as it is always wide open and I just feather the control valve to get the best cutting speed. On the return I pull back all the way.
Offline Clover
  • I'm newish
« Reply #11 on: March 04, 2017, 06:30:39 PM »
More progress today. Tomorrow I'm going to pick up my hydraulic hoses. This is going to hurt, four hoses at 64' each. I still need to wire in my solenoid and lube pump to a switch and solenoid setup. I'm going to also wire in a master off switch. I need the solenoid switch to be spring loaded so if I go to far with the hydraulic cylinder to declutch the motor it won't get damaged.
Offline Clover
  • I'm newish
« Reply #12 on: March 04, 2017, 08:25:55 PM »
Once I'm done this upgrade I'll start putting together parts for a chain turner. I have a claw turner/clamp now but having that extra "hand" on the mill will make life that much easier. It's either that or a set of two plane clamps.
Offline thecfarm
« Reply #13 on: March 04, 2017, 09:29:43 PM »
Clover,you are a busy guy
Hey can I help you out with the pictures??  ;D
Notice the "white" space between the pictures that I posted? I hit the enter key 3 times to bring the picture down and leave some white space,than I hit the Preview key to make sure it looked good.
Not being picky,just easier to look at.  :)
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #14 on: March 05, 2017, 08:10:33 AM »
I was going to offer the same suggestion.  Thanks for being the "bad guy",  thecfarm.   :)
Really enjoying following your re-build, Clover.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Clover
  • I'm newish
« Reply #15 on: March 05, 2017, 08:25:07 AM »
That's much better c-farm, no bad guys here LOL. I noticed yesterday that if I didn't leave a comment between each photo that they become very hard to look at.
Nothing better than learning something new everyday  :P
Offline Rougespear
« Reply #16 on: March 05, 2017, 12:26:27 PM »
Clover: how are you addressing downward creep of the hyd motor?  In similar setups to yours, I have seen a 30:1 gearbox used to help hold the weight of the head from creeping downward.  Even in a closed circuit, there can minute amounts of oil weeping past seals and such that may allow the height to fall... just a thought.  I really like your setup!
Offline york
« Reply #17 on: March 05, 2017, 12:47:15 PM »
I agree,should use an right angle drive,with an 30 to 1 ratio-that is what cook uses on there mills,theirs is made by Cleveland ...When your oil get hot,you will get saw head creep...Your setup now look`s too fast...Reason i know the ratio,i have the Cleveland rt/angle gear drive..
Albert
Offline Clover
  • I'm newish
« Reply #18 on: March 05, 2017, 06:06:35 PM »
Thanks for the input gentlemen. I'm not one to try and reinvent the wheel, but when it comes to hydraulics I do have a working understanding of them.
Right angle drives do have some advantages as they allow you to eliminate the chain drive at the motor and to also use a smaller less powerful motor to raise the head. They also remove all side load on a motor. Most smaller high speed motors can't take any side load, mine is capable of high side loads at low rpm's.  A hydraulic motor turning 750 rpm's will only be turning 25 rpm's with a 30-1 gear reducer. My motor is 23.3 cubic inches. With my power pack that works out to 25 rpm's (if my memory is correct) with a further reduction at the final chain drive. This will be VERY powerful and have plenty of holding power. As for creep that's anyone's guess until it's actually in operation. I'm not thinking it's going to be a big problem for a 15-20 second cut. In the event it is I will add in a pilot check valve. The description follows
"Use to lock a hydraulic cylinder in one direction. It will hold up a load and prevent it from drifting down. Also prevents the load from falling if a hose fails. Place in between the directional control valve and cylinder. When the control valve is in neutral and the check closes the cylinder will be locked in position."
As for speed the directional valves also work as flow control allowing me to send a little or a lot of oil to control the travel speed.
I hope this clears my madness up a little. I'm not one to slap parts together and hope for the best. It's usually a few hours thinking stuff through to get it right the first time.
Offline ljohnsaw
« Reply #19 on: March 05, 2017, 07:57:28 PM »
...In the event it is I will add in a pilot check valve. The description follows
So how does this pilot check valve allow you to actually lower the head when you want to?  Does it have an internal relief valve so when you have high pressure it allows it to pass?  Really curious about that.
Also, depending on how you are "inserting" your pictures...  If you use the "Insert image into post" button way at the bottom of the Gallery view page, you will get an automatic two html Break characters < br > at the beginning and I usually delete the first one to save space on my posting.
Home made sawmill
Started by Michaeljp86 on Sawmills and Milling
Last post April 23, 2006, 07:47:46 AM
by mike_van
old canadian sawmill, home made.
Started by weisyboy on Sawmills and Milling
Last post February 24, 2011, 09:55:02 AM
by isawlogs
home made sawmill blade tracking adjustment
Started by steve phillips on Sawmills and Milling
Last post February 08, 2012, 09:14:21 AM
by steve phillips
Didn't re-invent the wheel, but made some mods to my LT-10
Started by francismilker on Sawmills and Milling
Last post March 23, 2013, 08:10:34 PM
by francismilker
