Arborwear
Author Topic: Building An Oven  (Read 4764 times)
Offline D L Bahler
  • Hopp Schwyz!
    • Traditional Swiss Carpentry
Re: Building An Oven
« Reply #40 on: March 12, 2017, 12:47:37 AM »
I put up the first arch tonight. I experimented around a bit to determine exactly how I want to support the arches, etc.
The picture here are actually of an early trial. It worked well enough, but I decided I wanted a more secure means of support so I took it down and redid it.
I ended up placing a brick to bridge the gap between the arch feet and the outer walls, since none of the other methods seemed to be satisfactory in this case.
Also not seen here iss an important step when laying up dry arches that I forgot (my battery died so I don't have any pictures of the final arch) That is to rub the top of the arch with dirt (or in this case, dirt mixed with some sand) or mortar or whatever is handy to fill in the gaps and imperfections. (The other option is to be incredibly precise grinding the angles on your bricks, but that's VERY difficult. If you rub a little something over it all to fill in the gaps you have a little room for error)
If you don't do this, the arch will have a tendency to go lopsided or even collapse.
If it wasn't currently below freezing, I would have rubbed it over with mud instead, but that will have to wait until later.
You can see the slip form I'm using to put the arches together. I'm taking advantage of the sloped floor. The two 2x4's rest on a sheet of plywood in the rear of the oven and on a 2x4 in the front (accounting for the 1 1/2" of difference in height) When I want to remove the form from under a completed arch, I knock out the support 2x4 in front which allows the arch support to fall down and be removed. THe first arch is the most difficult to do this way, since the 2x4's don't drop down any in the very rear.
A few notes on making the arches for those following with interest of making their own oven:
It's easiest to grind the angle on just one side of the brick. Then alternate each brick as you lay it in (so the angle ground sides butt up against each other, unground sides butt, etc). It's hard to keep 2 faces flat when you grind the bricks down like this (I'm using a diamond grinding wheel, it makes a lot of dust but is pretty slick.)
If you don't think you can do a good job grinding, you can just lay them in without grinding, and pack refractory mortar in the wedged opening. The disadvantage of this is you have to wait for the mortar to set before you can move on to the next arch.
Just to reiterate, when you lay an arch dry and before you remove the form, rub it with dirt or fine sand (or a mixture of both) a smear it over with a slip or mortar mixture of some kind to fill in gaps and imperfections. Unless you make a check gauge and carefully craft each individual brick there are going to be imperfections and inconsistencies (or if you're lucky, you could get your hands on some arch or wedge bricks and then this step is unnecessary). When the support is removed the arch will seek to balance its forces within itself. If imperfections are present, it will average them out meaning the arch will go lopsided, and it will be 'wobbly' which means it might fall apart eventually. If the imperfections are too bad, it will fall apart right away. So filling in the gaps thoroughly makes it stable.
If I remove the template and the arch moves AT ALL, then I'm going to take it apart and redo it.
You really only need (and want) a flat segmental arch for an oven. This arch has 7" of rise over a 49" width, it's based on a 48" radius circle. That's actually more rise than I need for stability, I could get by with like 3 inches of rise to support the structure if I wanted to, but I chose to build an oven with shorter walls and a higher arch mostly because it looks better (even though nobody but me will hardly ever see the arches once it's all done)
The taller you make an arch, the harder it is to support.
Actually wehn I was taking one of my trial arches apart, a brick or two removed it fell down and the tops of the remaining bridges wedged themselves together to form a very strong and stable arch that had maybe 1" or so of rise.
When assembling the arches, make sure to firmly seat each brick as you lay it in, otherwise the arch will shift when you remove the supports. I take my masonry hammer and tap each brick several times until it seems to be firmly seated on the brick below it. Also take care to align each brick in every other direction as you seat it. Once the key is in place, and especially once the form is removed, it is very hard to adjust and move anything.
For these arches, I'm trying to make my keys to where they will drop in about halfway, and then need tapped in with the hammer the rest of the way. This way any slack that's left in the arch is taken out. This also will lift the arch above the form a little bit, which in turn means the top edges are being forced open (or the bottom edges being forced together) aim for consistency in how much the key drops in before being driven and how much wedge they have in them, otherwise your arches will not line up with each other.
Offline ChugiakTinkerer
« Reply #41 on: March 12, 2017, 01:41:16 AM »
This is a fascinating project.  Thanks so much for the many pictures and the detailed description.
Woodland Mills HM130
Offline D L Bahler
  • Hopp Schwyz!
« Reply #42 on: March 12, 2017, 10:25:50 PM »
Here are some pictures of the arch that I kept. You can see the support for the arch cleats, and the dirt and sand I smeared in the top
Offline D L Bahler
  • Hopp Schwyz!
« Reply #43 on: March 17, 2017, 10:27:46 PM »
It's been a little while since I've been able to get any work done on the oven, but the day I found some time to pick up another load of bricks and to get to work on a couple more arches. The first Arch I laid today needed to have the vent holes for the smoke cut into it, so I just ground release in a couple sets of mating bricks to form the smoke holes. Other than that it's just business as usual.
Offline ljohnsaw
« Reply #44 on: March 17, 2017, 10:58:45 PM »
I was starting to have withdrawal symptoms waiting for the next installment! :D
That is going to be a lot of force on those outside walls, when are you going to put the reinforcement rods in place?  Also, only those two little smoke holes?  Or will another arch have more?
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline D L Bahler
  • Hopp Schwyz!
« Reply #45 on: March 18, 2017, 05:24:42 PM »
Putting in tie rods is the next step. Im just putting them in as I get to them, so they won't be in my way as I work through the oven body.
Regarding the smoke holes,
They're large enough for what I need, there won't be a tremendously large fire in there, no more than a couple pieces of wood at once and not much volume of smoke as you burn it hot an burn off the flammable gasses in the smoke.
Offline D L Bahler
  • Hopp Schwyz!
« Reply #46 on: March 18, 2017, 05:26:37 PM »
Also the dry arches don't put more force on the walls than they are able to withstand, at least in the short term. The force lands fairly low on the brick walls, and the sheer strength of the mortar, though not high, is enough. Also the construction does ensure that the thrust is distributed fairly well into the outside wall
Offline D L Bahler
  • Hopp Schwyz!
« Reply #47 on: March 24, 2017, 03:08:22 PM »
Early Monday morning, a bad storm (not on the forecast at all) rolled in and dumped several inches of rain. I hadn't bothered to cover the under-construction oven, as the weather was forecasted clear all weak. The rain washed the sand behind the arch support, allowing the arches to push them side and collapse. The suddenness of all of it allowed the arches to slide into outer wall with enough force to knock it over. SO progress has been delayed as I repair the outer wall of the structure.
From now on, I'll be sure to cover it even if no rain is in the forecast. IT is march in Indiana, after all.
The arches are particularly vulnerable  when under construction. There is not very much holding them up at this point, and add to that that arches of this type are somewhat unstable without any load upon them.
Offline Czech_Made
« Reply #48 on: March 27, 2017, 06:38:35 AM »
Sorry to hear about your misfortune.
Offline Fallguy
« Reply #49 on: April 22, 2017, 10:08:52 AM »
I was telling my future daughter in law about your project and she was very interested. Have you had time to get back on the project yet?
Offline D L Bahler
  • Hopp Schwyz!
« Reply #50 on: May 09, 2017, 10:56:15 AM »
Hey, sorry for not replying sooner. Combination of busyness and travel, havent been on the forums a whole lot lately
The oven is not quite done yet, but hopefully I'll find the time to get to it soon. It's rained so much here lately that it's been hard to get too much done
Offline Fallguy
« Reply #51 on: July 22, 2017, 08:23:40 AM »
Do I smell bread? My daughter in law to be asked about your project the other day.
Double wall oven cabinet and oven installation?
Started by Warbird on General Woodworking
Last post January 22, 2013, 12:23:34 PM
by Warbird
Oven dry
Started by hackberry jake on Drying and Processing
Last post November 06, 2012, 08:25:51 AM
by Al_Smith
Turkey in the oven
Started by bandmiller2 on Sawmills and Milling
Last post December 25, 2013, 09:05:51 AM
by Chuck White
Da Brownies are in da oven!
Started by neslrite on General Board
Last post July 29, 2009, 08:35:48 AM
by Burlkraft
