Arborwear
Author Topic: lumber storage barn  (Read 3152 times)
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: lumber storage barn
« Reply #20 on: March 19, 2017, 12:42:42 AM »
That should keep moisture from condensing and dripping all over everything. Looking good!
1992 LT40HD
Offline GeneWengert-WoodDoc
« Reply #21 on: March 19, 2017, 08:16:46 AM »
One idea is to use a humidistat to control the heat.  Whenever the humidity is over about 40% RH, then the humidistat kicks on, turning on the heat.  Heating air lowers the RH.
Note that painting the roof a dark color will heat the roof and thereby minimize condensation and also provide some heat into the building to help lower the RH.  The average outside RH is around 65%, so a building needs to be about 20 F warmer than the morning's low temperature to achieve 8% EMC.  A small fan or two helps stir the air so conditions are uniform.  Otherwise, hot air rises and so the roof will have a lower RH than the floor.  In all cases, we do not want any source of moisture- wet lumber, roof leaks, soil moisture, open doors for very long, especially between 10PM and 10AM when outside RH is high.
Offline Joey Grimes
  • Quality is remembered long after price
« Reply #22 on: March 19, 2017, 01:23:47 PM »
The insulation is covered both sides with a black cover like tar paper I thought about painting it white so it would reflect light better are you saying it being black will help reduce condensation or the roof metal black?
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Offline Joey Grimes
« Reply #23 on: March 26, 2017, 10:36:12 PM »
More progress on insulation
Offline Joey Grimes
« Reply #24 on: April 14, 2017, 09:56:27 PM »
All the insulation is done and garage door installed I got finished with some of slab display and loaded 24' I thought that was enough but I think another 24' next week
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #25 on: April 14, 2017, 10:16:31 PM »
Looks nice.  God job.  On our slab rack I hung some yellow safety chain from the frame to keep the slabs from accidentally falling out and conking a customer or me on the head.  Much like the chain that holds welding cylinders in a welding cart.  The chain has some slack so the slabs can easily pulled out a little to see them, but it keeps them from falling out.
HobbyHardwoodAlabama.com
Offline Darrel
« Reply #26 on: April 15, 2017, 12:19:41 AM »
That's a nice looking whack of lumber well displayed. I like it.
1992 LT40HD
Offline xlogger
« Reply #27 on: April 15, 2017, 06:00:58 AM »
Joey, where did you get those pipes bolted to the wood to hold your slabs? I was thinking about building something like that but I like your deal better than what I was thinking about.
Offline thecfarm
« Reply #28 on: April 15, 2017, 06:03:05 AM »
That does look good.
Offline Joey Grimes
« Reply #29 on: April 15, 2017, 07:26:31 PM »
I ordered 3/4 floor flanges and screwed them to horizontal 2x4 and screwed in 24" 3/4 pipe nipples I ordered them from supply house online 40# nipples and #40 floor flanges cost $250 delivered
Offline Joey Grimes
« Reply #30 on: April 15, 2017, 07:29:13 PM »
I reconfigured a little today to accommodate shorter slabs
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #31 on: April 15, 2017, 10:16:09 PM »
Joey,
That is mighty fine, makes me green with envy. That is one of the nicest slab displays that I have ever seen.  Man, you are rockin'  8) 8).
Offline Deese
« Reply #32 on: April 17, 2017, 05:56:25 PM »
Man, you're doing what I dream of doing. Very Nice.  :)
'04 LT40HDD51
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
« Reply #33 on: April 17, 2017, 08:44:59 PM »
Joey,
You've done a phenomenal job on your building and slab rack.  Way to go!!!
Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Offline Joey Grimes
« Reply #34 on: May 18, 2017, 08:17:56 PM »
First of many mobile lumber displays
Offline WDH
« Reply #35 on: May 18, 2017, 08:50:38 PM »
That is doing it right.
Offline Darrel
« Reply #36 on: May 18, 2017, 08:58:21 PM »
I like it, I like it a lot.
1992 LT40HD
« Reply #37 on: May 18, 2017, 10:10:24 PM »
Looks great.  Better get the credit card machine warmed up for your customers.
Offline Joey Grimes
« Reply #38 on: May 25, 2017, 11:20:02 PM »
Another display done
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #39 on: May 26, 2017, 05:33:26 AM »
You guys with the light weight barns. Makes thing so easy down in the south. Up here in the north, we have to build strong, Snow is the thing. :D :D :D :snowball:
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Lumber Storage Fee?
Started by Brad_S. on Sawmills and Milling
Last post November 16, 2006, 05:56:25 PM
by Brad_S.
Lumber storage
Started by TexasTimbers on General Board
Last post March 05, 2007, 10:58:28 AM
by TexasTimbers
Storage of kd lumber
Started by Dugsaws on Drying and Processing
Last post March 07, 2004, 06:47:24 AM
by Brian_Bailey
ok or not ok for lumber storage
Started by raycon on Drying and Processing
Last post March 03, 2004, 03:31:42 PM
by AtLast
