cleaning canning jars
Started by petefrom bearswamp, March 03, 2017, 07:27:25 PM
petefrom bearswamp
I can a fair amount of venison in mason jars.
I am the canner and Linda is the cleaner.
She has trouble getting the jars clean.
Any tips out there?
BTW we just finished a supper of Stroganoff using the canned meat
Pretty darned good.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
breederman
Have you tried rinsing in warm ,not hot water and then just putting them in the dishwasher ? I don't can meat ,but thats what I would try . I just throw mine in the dishwasher.
Together we got this !
Briankinley2004
Maybe try a bottle brush or something similar. We usually run ours through a sanitizer cycle on the dish washer
Gearbox
You could try Vinegar soak to get stains off . Then the dishwasher . If it will clean the holes in a shower head it should clean a jar .
newoodguy78
Gearbox do you use the vinegar full strength or do you dilute it down a bit?
21incher
We bought a Victorino canning jar brush at Runnings that really works good with a sink full of steaming water and dawn. It is a very stiff foam that leaves nothing behind. I cleaned about 600 jars with it last year and they all came out spotless. :)
Briankinley2004
You can also use iodophor. It is used to sterilize brewing bottles and is iodine base. Doesn't do well on plastic but for glass and stainless it's awesome and cheap
petefrom bearswamp
I'll have to google Runnings to see if there is one near me.
Wife put the last one thru the dishwasher and it came out pretty good.
She hasnt had that kind of luck before.
Where can I get iodophor?
Kubota 900 RTV
Dan_Shade
Iodophor is available from homebrew companies for beer and wine making.
If you know a dairy farmer, he may be able to get you some.
Please note that Iodophor is not a cleaner, it's a sanitizer.
If the jars are bad, maybe ammonia will cut everything loose.
I like the dishwasher to clean jars.
lots of dull bands and chains
I think I sell Idopher by the gallon at the hardware store I work at. It's by the other stuff for dairy framers too.
Corley5
Our water is very hard and without a water softener our dishwasher is not good for cleaning jars.  They're clean but not clear  ;) ;D
21incher
Quote from: petefrom bearswamp on March 05, 2017, 09:02:58 AM
The closest one to me is in Canadiaga but the brushes are available online for a couple dollars. :)
petefrom bearswamp
Kubota 900 RTV
Joe Hillmann
I use a bar brush mounted to a board that I put in the sink.  The brush stays still and you rotate the jar instead of the brush.
Just Me
Quote from: petefrom bearswamp on March 03, 2017, 07:27:25 PM
Any tips out there?
Pretty darned good.
Best breakfast I ever had was canned venison and gravy on pancakes. Way better than it sounds.
I use a toilet brush [new!]with the handle cut off in a cordless drill. I use the same cordless with a paint mixer, again, new to make mashed potatos. Cordless drills are a highly underrated kitchen tool. ;)
petefrom bearswamp
Kubota 900 RTV
