Arborwear
Author Topic: Older iron.  (Read 2329 times)
Offline BargeMonkey
Older iron.
« on: March 03, 2017, 11:10:54 PM »
 Im hoping how I word this is allowed, if you want this loader donate a few hundred to the FF and I will load it on your trailer. I hate scrapping stuff that someone else can use, we drove it off the trailer and yanked the engine for another machine, it had a very odd cummins engine. Maybe one of you guys has one out back that needs a cylinder or axle ??? it's got a date with the crusher in 30-60 days, tires all hold air, I'm sure a Detroit would fall right in it. Zip code is 12076. We are going thru the yard shortly and I figured maybe this would help someone who needed parts / a project / and donate to the FF ???
Offline longtime lurker
Re: Older iron.
« Reply #1 on: March 04, 2017, 03:13:39 AM »
What is it? An A series Michigan?
Not that it matters, it looks like it'd fit right in here at antiques-r-us, home of equipment that grosses its market value on a weekly basis. Give her a screamin' demon, a dulux rebuild, and a scrub canopy cum rops and she'd be a beast.
Someone better give it a home, if the freight bill don't kill me Mary will.
Offline coxy
Re: Older iron.
« Reply #2 on: March 04, 2017, 03:53:35 AM »
hey barge are they eaton rears if they are you could call some one down my way you had dealings with last year  :D :D :) 8) not going to say any names but you know who I'm talking about  8) 8)
Offline Gearbox
Re: Older iron.
« Reply #3 on: March 04, 2017, 07:03:04 AM »
Did that have a C series Cummins . They made them up to 180 HP with a supercharger .
Offline bushmechanic
  • Someone else has it worse than you.
Re: Older iron.
« Reply #4 on: March 04, 2017, 07:09:27 AM »
 I believe those diff's are the larger Rockwell's like used in the 404 Timberjack's and some of the early Timberjack forwarders.
Offline ehp
  • logger/chainsaw hack
    • ehpsaws.com
Re: Older iron.
« Reply #5 on: March 04, 2017, 10:13:15 AM »
I put a 471 in one of these and the guy is still running it , machine works pretty good
Offline jdeere540a
Re: Older iron.
« Reply #6 on: March 04, 2017, 01:24:23 PM »
That looks like a hough payloader model ho. We had one just like it until my grandfather foolishly scraped it every thing worked on it i used it in my wood yard a lot until I came to work one day and it was gone. Ours had a jn6bi Cummings around 160 hp naturaly asperated they had a really cool sound.
Offline BargeMonkey
Re: Older iron.
« Reply #7 on: March 04, 2017, 09:50:50 PM »
 This one drove itself off the trailer, loader worked, brakes where a little off. Yeah it had an obscure older cummins engine, same engine that's in our Pettibone crane unfortunately. Engine went out of the crane last yr and the cost to convert to a Detroit or swap engines was discussed, we found this one and did the swap.
 Unfortunately we got that machine under kind of bad circumstances, it came from a boat yard in Rye NY, it spent it entire life picking yachts and never went more than 600 ft. The owner was killed in 9-11, the yard changed hands and we got the machine. She is HEAVY, goes about 93ft high and will pick a triaxle up 😂.
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
Re: Older iron.
« Reply #8 on: March 05, 2017, 09:00:28 AM »
No snow there in Scary county eh?
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Puffergas
    • Puffergas
Re: Older iron.
« Reply #9 on: March 05, 2017, 12:59:23 PM »
Oh man.. I could find an engine around here for that loader but the trucking to Erie, PA would eat up $2k fast plus $300 to the FF. Almost worth it. Or I could drive up with an engine for the crane, hang the loader from the hook and drive home..  ☺
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline BargeMonkey
Re: Older iron.
« Reply #10 on: March 05, 2017, 09:05:57 PM »
That picture was from Christmas day, I was dumping firewood logs off to friends of ours where she sits. Couple inches on the ground right now. You get in certain spots in the woods you can find 1-2+ ft still.
Offline BargeMonkey
Re: Older iron.
« Reply #11 on: March 05, 2017, 09:08:21 PM »
Engines already been transplanted from the loader to the crane. The old block lays in the loader for scrap purposes. Those cummins are super weird, never seen a rod hooked to the crank with U-bolts before, almost what it looked like. That loader would fit on a small equipment trailer, could even take the wheels off and put on a heavy car trailer.
Offline Gearbox
Re: Older iron.
« Reply #12 on: March 06, 2017, 06:07:32 AM »
I rebuilt the one in my dump . Cummins made them from 120 to 180 . turn them 2500 in a truck . Mine put a hole in the oil pan when it went . saved the block and rebuilt it .
Offline Puffergas
    • Puffergas
Re: Older iron.
« Reply #13 on: March 06, 2017, 08:00:19 PM »
Does it have the dog house? Rear steering?
Offline mike_belben
  • Pulp Friction
Re: Older iron.
« Reply #14 on: March 19, 2017, 02:38:35 AM »
The axles under that pettibone crane are worth about $2-3k.  Actually just the outers 4 corners.  Low end monster truck guys graft them onto rockwell f106 housings.  Those are probably "pie pans"  .. Nickname for 20ton pettibone planetaries.
Revelation 3:20
Offline BargeMonkey
Re: Older iron.
« Reply #15 on: March 20, 2017, 12:10:32 AM »
I can take a couple pictures, I believe it is rear steer. I watched it get parked in the yard and disected for the engine. 😂 it's been there 1yr and soon it's going to the scrap yard.
Offline mike_belben
  • Pulp Friction
Re: Older iron.
« Reply #16 on: March 20, 2017, 01:13:41 AM »
Straight front axle, rear steer axle.  Make a decent skidder project
Revelation 3:20
transhydraulic in transmission of older Iron Mule
Started by quietrangr on Forestry and Logging
Last post November 04, 2011, 08:15:52 PM
by quietrangr
Stihl 066 = old iron = good iron
Started by rebocardo on Chainsaws
Last post July 24, 2008, 03:02:14 PM
by rebocardo
as I get older
Started by hiya on General Board
Last post June 25, 2006, 03:23:58 PM
by sawguy21
as I get older...... Is it just me....?
Started by jjmk98k on General Board
Last post March 30, 2005, 02:47:32 PM
by breederman
