Arborwear
Author Topic: Changing my sawmill setup  (Read 2567 times)
Offline Deese
« on: March 07, 2017, 11:30:56 AM »
I am searching for some good, practical suggestions on what I have attempted to describe below.
I am changing my sawmill setup to minimize the need for a tractor to unload/load logs. It's a 10 minute drive (on the old Massey) to my setup and this is becoming a real problem. Here are a few pictures for you to see how I was currently set up:
 I took the sawmill off the elevated platform, repositioned it on blocks closer to the ground, and added the 10' track extension this past Saturday. Now capable of sawing up to 22' length. I forgot to take pics of the mill with the extension added. The elevated log deck will be removed and from now on, the logs will be on the ground. Back the trailer into position, lift the end of the logs with a winch, and pull forward. Logs will land on 4x4's for easier maneuvering with Logrite cant hooks.
People are going to want 20'+ beams. It is just a matter of time and they are going to be heavy. So, I've got to figure out a simple and inexpensive way to remove heavy beams from the mill onto a trailer without the use of a FEL. I'm thinking of rolling the beam (using cant hooks) off the opposite side of the mill onto some 4x4's, then somehow lift it with pulleys to be loaded onto a trailer. My brother's JD has forks, but again, my goal is to be as self sufficient as possible. Buying a forklift is not an option for me at this point.
Any practical suggestions on the best way to do this?
EDIT: The attached pictures are not current. The trees on the offloading side of the mill have been removed, so there is plenty of space to do whatever is needed in that area.
'04 LT40HDD51
Offline Rougespear
  • Salmon Arm, British Columbia
Re: Changing my sawmill setup
« Reply #1 on: March 07, 2017, 11:36:06 AM »
Can a modified drag-back feature be made to work?  Ie: pull the timber off the end of the mill, perhaps up an inclined roller conveyor?
Custom built Cook's-style hydraulic bandmill.
Offline mad murdock
« Reply #2 on: March 07, 2017, 12:07:29 PM »
One of the primary reasons I chose the mill I did when I upgraded from a CSM(which I still have the Granberg mk III), was the consideration of not having to handle logs and such so much. This led me to the swingblade option, which is the easiest way to ditch the need for a FEL, Band mills have their place, IMO, but a swing blade offers so much more, IMO, worth the thought.  Milling without having to turn a log is a mighty fine notion! 8)
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline ChugiakTinkerer
« Reply #3 on: March 07, 2017, 12:25:26 PM »
I'd look into having some toe rollers and a 10' length of box roller track and just roll the beams straight off the end of the mill onto the trailer.  Something like this from Global Industrial has a capacity of 620 lbs per foot.
Edit: I see that's pretty much what Rougespear suggested.  If it's too much incline then the toe rollers can be raised higher (assuming you planned for that) to get the beam level with the end of the trailer.  A 22' beam of 8x8 would likely weigh what, around 600 lbs?  A few scissor jack toe rollers could raise it up enough to where you could roll it off the end onto the conveyor track.  Seems like it could work without too much investment in time or equipment.
Woodland Mills HM130
Offline Deese
« Reply #4 on: March 07, 2017, 02:04:57 PM »
Thanks fellas for your input. The toe rollers would be perfect if the track were higher off the ground (as shown in pics). However, the track is only a few inches off the ground. I'm thinking of some type of simple I Beam trolley setup. Maybe just one I Beam that overhangs part of the track, lift the wooden beam off the sawbed with a heavy duty strap (strapping in the center) and chain hoist, rotate the beam perpendicular to the I Beam support posts, push it until hanging over trailer, rotate beam parallel to trailer, lower onto trailer.
That should work, right?
EDIT: It won't work that way unless the I Beam was secured from above to allow the trolley so roll down the length of the I Beam.    smiley_dizzy
I found some good photos on the forum and I think I've got a game plan.
'04 LT40HDD51
Offline Gearbox
« Reply #5 on: March 07, 2017, 03:38:56 PM »
Think about this a 16 ft. beam raised up 8 inches in the center will be [ what ] at the end ? 16 to 20 inches . Enough to fit the trailer under . A roller clamped to the back of the trailer at deck high . Stab it with your Log Rite and roll it on .
Offline nativewolf
« Reply #6 on: March 07, 2017, 04:02:46 PM »
How is the new mill?  You promised some pictures of it cutting, when do we get to see some chips flying?  I've been thinking about them so very curious about your next few months cutting.
Liking Walnut
Offline 47sawdust
« Reply #7 on: March 07, 2017, 04:39:43 PM »
One of the reasons I went to the trouble of adding hyd.to my Lt30 was for the hyd. toe rollers for ease of handling large timbers by myself.The rollers and outfeed roller table were a big improvement.
 By lowering your mill you may have gained in one area(log loading)but you may have hindered the ability to add some toe rollers.Forum member Larry has pictures in his gallery of toe rollers he made that used a boat winch to raise and lower.I built a set for my previous mill and they worked well.i will try to find the link for you.
 A further thought is to build two additional bunks with a built in roller that could be lever actuated with a cam and detents to hold the roller in the desired position.Your lowered mill position would not hinder this operation.Just some backyard engineering to keep you out of trouble.
Mick
Offline ljohnsaw
« Reply #8 on: March 07, 2017, 04:53:34 PM »
I haven't completed it yet but I'm making a trolley that rides on my mill track (similar to the head) with a electric winch (or a hand crank).  Lift the log or beam, run it down to the end of the track.  Half the beam would be hanging over your trailer.  Have some rollers on the trailer, drop the beam and re-pick at the far end and slide it the rest of the way on.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline mad murdock
« Reply #9 on: March 07, 2017, 05:48:42 PM »
[/quote]
[/quote]
We have been inundated with snow, cold, rain and also my 8-5 M-F work getting in the way.  I have the mill assembled and am working through some saw issues, as I am using my 075 to power the mill.  Havent gotten any chips cut yet, if the 075 wont cooperate, I will just get a 395XP and put on it. Plenty of power, and actually a bit more than the 075 according to specs.  I will post some pics as soon as I get it throwing chips, should be within the next week, I hope ???
« Reply #10 on: March 07, 2017, 05:53:47 PM »
A winch on the trailer pulling the beam off the end of the mill should have no problems pulling the beam up an inclined conveyer track.  Especially if you have a toe roller or two.  With the mill bed sitting on the ground you could raise the end of the beam with a jack and insert a roller underneath that rests on the mill.  It would probably take a little backyard engineering and may be no easier than the trolley that ljohnsaw is building.  What is the height difference from mill bed to trailer bed?
Offline paul case
  • Original wearer of the PCM.
« Reply #11 on: March 07, 2017, 06:59:04 PM »
I used a hand crank winch with a pulley up and behind the mill to pull the ties off the back end. It worked good and I didnt try to lift the whole cant but just one end of it. That keeps it from swinging around without my help. smiley_swinging_board I guess that way if you put your pulley far enough and high enough that it would load them in someones trailer as well.
pc
Offline kelLOGg
  • Still learning more than I'm teaching
« Reply #12 on: March 07, 2017, 08:40:31 PM »
I added 4 rollers to aid in moving heavy lumber to a trailer. I generally I work alone so I tried to make it easier on me. It's not a complete solution but I rarely have to lift as much as I once did.
I pick up the beam w/ the onboard winch loader and slip rollers under it. A 4th roller is height-adjustable to match the level on the trailer. I can either push by hand or use the sawhead. See pics.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, screw driver
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #13 on: March 08, 2017, 12:53:56 AM »
I really love you'r little railroad track railing. I wonder where
someone could buy track like that ?
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline kelLOGg
« Reply #14 on: March 08, 2017, 06:50:27 AM »
Are you referring to the track the rollers roll on? If so, it's just 1 x 1 x 1/4 angle iron tack welded to the main beams.
Offline Kbeitz
    • My Hobbies
« Reply #15 on: March 08, 2017, 07:45:56 AM »
In your first picture it looks like small RR- track. The top
of the track looks like 1/2 flat.
Offline fishfighter
« Reply #16 on: March 08, 2017, 08:18:57 AM »
Some really great ideas in this thread. I was planning on installing a Ibeam/trolley system overhead.
Well, it looks like this is better idea. :D Once I get the saw mill shed close to finish, I was planning on added extra track. Heck, I might add 15' extra and add two trolley lifts and also a Ibeam overhead to help flip/move logs.
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #17 on: March 08, 2017, 08:44:34 AM »
If you want to go with the toe board roller idea, you could always lower your trailer to bed height.  Excavate a hole for the trailer to drop in at the end of your sawmill.  You can slide off the end of the mill onto the trailer.  Be sure to allow for drainage so you don't have a swamp to deal with.  I think some roller conveyors would be your easiest option.  You can handle some fairly large beams once you get them on wheels.
Wudman
Offline 47sawdust
« Reply #18 on: March 08, 2017, 12:46:43 PM »
Kellogg,
 I think your idea is great.Simple and effective.You must have been a good teacher.
Mick
Offline Deese
« Reply #19 on: March 09, 2017, 11:30:37 AM »
Thanks everyone for the tips. Very thought provoking. I like several of the ideas and all seem like they would work.
A friend of mine has some heavy 10" wide H Beams that I can have for free. Just a few miles down the road. I am thinking I may take him up on his offer and try to make use of them. Going to look at them this weekend.
Also, I want to do some sawing at night after work. That's the only way I can catch up. Got around 60 logs on the ground and more on the way. All of these are to be sawn into 2x's, so lighting is more important than moving beams at this current time.
My setup is around 200' from the closest power source.
I just want something quick and easy to set up to begin with, and maybe run a trench later on down the road.
So, would 200' of regular duty (13-Amp) extension cord power 2 or 3 LED work lights? How many lumens should I aim for?
Thinking of mounting them high in the few trees that are still surrounding the mill.
I found some 5000 lumen work lights for around $90 each.  :P
'04 LT40HDD51
Sawmill Setup
Started by Billbob on Sawmills and Milling
Last post December 04, 2013, 04:11:43 PM
by rimshot
Sawmill Setup
Started by Rougespear on Sawmills and Milling
Last post May 09, 2015, 05:42:57 PM
by justallan1
Sawmill Setup
Started by idaho04 on Sawmills and Milling
Last post June 06, 2007, 10:00:16 PM
by pineywoods
sawmill setup??
Started by willmyers0169 on Sawmills and Milling
Last post May 22, 2015, 07:33:29 AM
by warren46
