Arborwear
Author Topic: Motor wiring.  (Read 1935 times)
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
Motor wiring.
« on: March 07, 2017, 03:55:11 PM »
Several years ago I made a trade of Web work for a rock saw. It was buried in my little storage barn since then. It came without a stand but included a new motor the fellow purchased to run it.  I'm in the process of building a stand, but now I need to know what way this motor turns in order to build a mount for it. Any body know the correct way to wire this?. The motor didn't include aNY sort of pothead.
Offline Den Socling
  • just wondering
    • PC Specialties
Re: Motor wiring.
« Reply #1 on: March 07, 2017, 04:13:28 PM »
Pothead? As in some smoker? As far as wiring, it's right there on the name plate.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Motor wiring.
« Reply #2 on: March 07, 2017, 04:19:21 PM »
I guess I mean wiring TO the motor, not sure where the hot nuetrl and ground go to.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Motor wiring.
« Reply #3 on: March 07, 2017, 04:42:03 PM »
"4" (where the blue wire is) and "1" which is right below 4.  It does not matter which incoming wire goes where.  If you want to you can connect the ground to the outside case.  There may be a lug, but probably not.  Sometimes there is a lug on the base itself.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Motor wiring.
« Reply #4 on: March 07, 2017, 04:45:52 PM »
I plan on wiring a switch to the front of the stand and wiring the motor to that.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Motor wiring.
« Reply #5 on: March 07, 2017, 04:48:00 PM »
Be sure to switch the black (hot) lead.
Offline ljohnsaw
Re: Motor wiring.
« Reply #6 on: March 07, 2017, 04:59:41 PM »
And, FYI, it is currently set to go CCW as looking from the pulley end.  Build your mount however you want and then set the direction of rotation that you need.  Nice motor - not all motors are (easily) reversible.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Motor wiring.
« Reply #7 on: March 07, 2017, 07:29:58 PM »
Most of the time on a motor like that you swap the blue and the brown
wire to change directions. I see that's not the case here. Looks like
you don't even have a brown wire.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline TimRB
Re: Motor wiring.
« Reply #8 on: March 07, 2017, 07:43:08 PM »
Offline Den Socling
  • just wondering
    • PC Specialties
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Motor wiring.
« Reply #10 on: March 08, 2017, 08:40:00 AM »
Messing around is what Im all about. I like to make stuff out of other stuff and come up with alternative solutions.  :)
Offline Dana
    • Green Leaf Farms
Re: Motor wiring.
« Reply #11 on: March 08, 2017, 10:27:53 AM »
The ground wire is the yellow and green wire in the 2nd photo. Usually it's located inside the enclosure like the other wires are but that will work as well.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Motor wiring.
« Reply #12 on: March 08, 2017, 04:08:10 PM »
Well, I needed to obtain a wing nut and a couple hinges. Motor mount complete.  Tighten the wing nut on the countersunk carriage bolt to tension, loosen it and lift motor to change belt speed.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Motor wiring.
« Reply #13 on: March 08, 2017, 05:39:16 PM »
I need to fab a guard yet for the motor/belts.
Offline ljohnsaw
Re: Motor wiring.
« Reply #14 on: March 08, 2017, 05:48:41 PM »
Nice.  But that is looking a bit fast for stone work.  Cutting maybe but the grinder I *think* you may want much, much slower.  What does Google say?
John Sawicky
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Motor wiring.
« Reply #15 on: March 08, 2017, 05:56:13 PM »
Looks like 1725, and this is  1725 motor. In the video it is running on the little pulley on the motor and the big pulley on the saw, so it should be much slower than that I would think.  Running on same size pulleys should give me 1725
Offline ljohnsaw
Re: Motor wiring.
« Reply #16 on: March 08, 2017, 06:14:22 PM »
OK, even for the grinding wheels?  I just noticed what looks like a ground wire on the rock sled.  I guess that guy was worried about getting fried?  I would hook this up to a GFI outlet to be safe.  My wet tile saw (DeWalt) has one built into the plug.
John Sawicky
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Motor wiring.
« Reply #17 on: March 08, 2017, 06:26:14 PM »
Not a ground wire. I'll replace that with something else. It is a cable that goes over a pulley and hooks to a weight hanging off the back. This makes the "power feed".
Offline ljohnsaw
Re: Motor wiring.
« Reply #18 on: March 08, 2017, 06:28:09 PM »
Ahhh, clever!
John Sawicky
Offline Kbeitz
    • My Hobbies
Re: Motor wiring.
« Reply #19 on: March 08, 2017, 06:46:02 PM »
Be careful if that's a white grinding stone. They are not made to spin fast.
Electric AC motor wiring questions
Started by bcraw98 on General Board
Last post October 21, 2006, 10:16:00 PM
by bcraw98
question
Need help wiring 1hp motor to a drum switch
Started by GF on General Board
Last post January 22, 2014, 09:08:06 AM
by GF
wheelchair motor wiring for auto feed
Started by revid on Sawmills and Milling
Last post June 23, 2016, 08:10:05 PM
by revid
12 volt motor question for the wiring gurus
Started by eastberkshirecustoms on Sawmills and Milling
Last post October 06, 2011, 09:41:32 PM
