Arborwear
Author Topic: Need recommendation for clear exterior finish  (Read 1067 times)
Offline Engineer
« on: March 08, 2017, 03:51:21 PM »
At my place of work, we are building a 36' x 36' timber framed pavilion out of local white pine.  My history with timber frames is of unfinished wood, both in my own house and for a pavilion that was done for the local Rotary Club a few years back.  However, we want to put a clear, penetrating finish on this frame, and I have no idea what to use.  I'm avoiding the big-box-store stuff such as Thompson's Water Seal; I don't think it has any value.  The very-high-end stuff, such as Land Ark or Sikkens, is hard to get.  I'm looking for suggestions or recommendations as to what I can use for a finish that will penetrate the timbers, not look like or act like a film finish, and has some preservative qualities.
Offline ChugiakTinkerer
Re: Need recommendation for clear exterior finish
« Reply #1 on: March 08, 2017, 04:57:43 PM »
Here's a recent discussion along those lines: http://www.forestryforum.com/board/index.php/topic,92415.0.html
Woodland Mills HM130
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #2 on: March 08, 2017, 06:00:55 PM »
Engineer , Look at the Messmers line of exterior oils . You will find them at the World Of Stain online. Rob
Offline Brad_bb
    • My timberframe blog
« Reply #3 on: March 08, 2017, 07:32:09 PM »
Permachink has good products.  They make them for log homes to stand up to UV and weather.
https://www.permachink.com/
Offline robmelby
« Reply #4 on: March 08, 2017, 08:23:57 PM »
 Allback boiled linseed oil. Made in Sweden and sold through swede paints in Canada. A natural old time finish.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #5 on: March 09, 2017, 10:45:23 AM »
The very-high-end stuff, such as Land Ark .......is hard to get.
I did a simple google search and found this "how to order page" for Land Ark:
https://www.landarkwoodfinish.com/page1.php
Didn't seem to be to hard to find.
Jim Rogers
Offline scsmith42
    • Whispering Pines Farm
« Reply #6 on: March 09, 2017, 09:39:22 PM »
I order the Land Ark products by the pail and by the drum all the time, and like them a lot. Contact Heritage Natural Finishes in Colorado. They usually ship within a day or do.
Tom's 3638D Baker band mill
Online Don P
    • Calculator Index
« Reply #7 on: March 09, 2017, 10:38:40 PM »
Does anyone have experience with carpenter bees and white pine with any of these?
Offline Heartwood
  • Will Beemer
    • Heartwood School
« Reply #8 on: March 10, 2017, 08:21:43 AM »
I'm not sure LandArk is still reliably available, but now many timber framers buy the same renamed Heritage product through here: http://www.heritagenaturalfinishes.com/. They have an exterior product.
Offline scsmith42
« Reply #9 on: March 10, 2017, 06:33:04 PM »
LandArk went bankrupt during the recession.  The owner of the formula teamed up with one of his distributors - Heritage Natural Finishes - and now all of the original LandArk products are available from Heritage under a different name.
Offline autumnpeterson
  • Gender: Female
    • Heritage Natural Finishes, LLC
« Reply #10 on: April 07, 2017, 03:17:24 PM »
Hi, Land Ark is now called Heritage Natural Finishes and is super easy to get. The guy who used to do it in the SE is no longer making it, but you can call or order online and they ship it in a day and they send free samples. A traditional oil finish is best for the durability and breathability of your frame. You want to avoid surface only treatments that are varnish-like for many reasons! PM me for more info.
A.Peterson
  • Gender: Female
« Reply #11 on: April 07, 2017, 03:20:28 PM »
You can pre-treat your wood for insects including boring beetles, etc. with any products that contain Borates. There are several on the market, TimBor, BoraCare, etc. or you can buy a cheap box of Borax in the laundry section of the grocery store, mix it with water and apply. Once it's dry you can oil over the top. (It can sometimes leave a little white residue, so just brush that off before you oil).
A.Peterson
Offline Stoneyacrefarm
  • Farmer/Service manager
« Reply #12 on: April 08, 2017, 11:17:20 PM »
We used a product called Q8 log oil on our log cabin with great success.
Work hard. Be rewarded.
Offline ljohnsaw
« Reply #13 on: April 08, 2017, 11:25:40 PM »
What is the coverage rate for oil finishes?  And would spraying be a viable option?  I will have very high ceilings - or should I plan on oiling before installing?
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
  • roborob
    • tule peak timber
« Reply #14 on: April 09, 2017, 10:19:57 AM »
I used a cheap weed sprayer on my ceilings and then threw it out when I was done.
oil finish for exterior use
Started by btulloh on General Woodworking
Last post January 18, 2016, 11:26:29 AM
by tule peak timber
exterior clear sanding sealer?
Started by limbrat on General Woodworking
Last post February 07, 2013, 08:53:20 PM
by limbrat
What should we finish the exterior of the log cabin with
Started by Stan P on Timber Framing/Log construction
Last post March 25, 2008, 12:40:21 AM
by Mad Professor
Finish for exterior of Log Cabin
Last post July 14, 2009, 11:11:39 PM
by woodbowl
