Author Topic: Woodland Mills HM126 tracking problem  (Read 3829 times)
Offline clintnelms
  • Woodmizer LT35HD
« on: March 12, 2017, 04:52:38 PM »
Anyone ever had tracking issues? I know how to adjust the tracking. The problem I'm having is on the right drive wheel side. I can make a minor adjustment,  1/4 inch turn or even less, and the blade travels too far forward on that side. Adjust it again the opposite way and it travels too far back on the wheel. That's spinning by hand after torquing the tension to 35 ft lbs. Left non-drive wheel is tracking fine. I can't seem to find the sweet spot. Never had this problem in the past. No matter how little I turn the adjustment nuts it just won't track correctly. Any ideas? The mill is about a year or so old. I've probably milled less than 20 logs. Only went through 10 blades since I've had it so it's not been used a lot. I say that because I've wondered if it's a bad bearing wheel on that side, but seems like I haven't had enough usage for that yet. Spent all day on Saturday trying to get it adjusted and never could get it to track flush with the back of the wheel.
Offline fishfighter
Re: Woodland Mills HM126 tracking problem
« Reply #1 on: March 12, 2017, 05:42:53 PM »
It could be a bad bearing. I have well over 250 hours on mine and haven't any problem. I would call them Mondays morning and ask them. I'm sure they will have an answer and help.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: March 12, 2017, 07:49:11 PM »
Bad blade or maybe you lost you'r crown.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline clintnelms
  • Woodmizer LT35HD
« Reply #3 on: March 12, 2017, 07:50:49 PM »
I tried a new blade and still same problem. What do you mean by crown?
Offline Kbeitz
    • My Hobbies
« Reply #4 on: March 12, 2017, 07:52:27 PM »
The top of your wheels that the blade ride on should be cupped outward.
Kinda like a little hill in the middle of the wheel.
Online btulloh
« Reply #5 on: March 12, 2017, 08:40:47 PM »
How's the belt on that side?  Might need replacing.  Check the drive belt and tension also.
HM126
Offline sawmilljoe
  • ill try sawing anything once
« Reply #6 on: March 12, 2017, 09:16:06 PM »
Sounds like a bad bearing change them should fix your problem
Offline Slingshot
« Reply #7 on: March 12, 2017, 09:17:13 PM »
Might try a slight adjustment on the vertical  tilt; If you haven't
 tried that.
Offline Briankinley2004
« Reply #8 on: March 12, 2017, 11:10:42 PM »
Did you move blade guides back to make sure they aren't pushing the blade off?
Offline clintnelms
  • Woodmizer LT35HD
« Reply #9 on: March 13, 2017, 08:48:41 AM »
Yes, made sure nothing was touching the blade.
Offline pineywoods
« Reply #10 on: March 13, 2017, 10:00:26 AM »
Don't know about Woodland mills, but have seen that problem other places. Bad bandwheel bearings. Try this...adjust to where it sorta tracks, then change the band tension a bit, either up or down. If the tracking changes, it's likely a bad bearing. Most mills use 2 in each bandwheel, one good and the other bad will cause lots of angst.
Offline clintnelms
  • Woodmizer LT35HD
« Reply #11 on: March 13, 2017, 10:08:06 AM »
Thanks pineywoods. I'll try that. Never thought to adjust the tension and see if it moves. Talked to Woodland Mills this morning and he gave me a few suggestions to try. Gotta check the belt and make sure it's not worn down to where the blade is riding on the wheel itself. Don't think so though. Pretty sure I changed it not long ago. They're also sending me a new spring washer kit that replaces a silicon bushing for tension. More to come I guess.
Offline fishfighter
« Reply #12 on: March 13, 2017, 11:28:48 AM »
By removing the drive belt, spinning the wheel, you might be able to feel if there is a bad bearing.
Offline clintnelms
  • Woodmizer LT35HD
« Reply #13 on: March 13, 2017, 11:58:38 AM »
I actually did do that, but it seemed to spin fine to me. Same as the other side.
Offline Kbeitz
    • My Hobbies
« Reply #14 on: March 13, 2017, 12:03:40 PM »
Sounds like on your machine the belt is your crown.
Offline clintnelms
  • Woodmizer LT35HD
« Reply #15 on: March 16, 2017, 06:45:55 PM »
Well I finally figured out what the problem was. They sent me the new spring washers. Big improvement over the bushing. Sent it to me for free too. Wasn't the problem though. I took the belt off to look at it and it still looked new. Decided to say the hell with it and put the old one back on. Come to find out the new one that was on there was not quite the same belt. This was the belt they sent me in the parts kit. It was a little narrower and the V grooves were not quite as big as the old one. Put the old one back on, problem solved.
Offline ChugiakTinkerer
« Reply #16 on: March 16, 2017, 07:40:36 PM »
Great to hear you got it worked out.
 Now how dos that saying go?  If it aint broke...  :)
Woodland Mills HM130
Offline clintnelms
  • Woodmizer LT35HD
« Reply #17 on: March 16, 2017, 09:18:31 PM »
After I got it fixed this afternoon I had a little time and sawed up a cant. I just got my blades back from a local guy I found that sharpens blades. He worked for woodmizer since 1991 sharpening and retired a year or so ago and does it on the side now. These blades cut better than they did brand new. I can't see any saw markes. Looks like the cant was sanded smooth. I was very impressed. At $7 a blade and about 10 miles up the road I'll be using him from now on for sure. He sure can talk though. Kept me there almost an hour when I picked them up just rambling about everything. Very nice guy though.
Offline Savannahdan
  • Retired.
« Reply #18 on: March 17, 2017, 07:33:31 AM »
Glad you got the problem taken care of.  Also, my chainsaw guy is talkative like your sharpening guy.  I plan on at least a 30-45 minute visit when I go to his shop.  Also, I need to visit George L. Smith State Park and check out the fishing.  PM me if you know of it and have some recommendations.
Dan
Happy St. Patrick's Day
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline clintnelms
  • Woodmizer LT35HD
« Reply #19 on: March 17, 2017, 08:02:36 AM »
Dan
Hey Dan. No sorry can't say I've ever been to that State Park. Where's it at?
Woodland Mills tracking problems
Started by Southwood on Sawmills and Milling
Last post January 21, 2018, 10:28:41 AM
by HOLTeam
Started by fuzzybear on Sawmills and Milling
Last post February 15, 2013, 07:19:10 AM
by thecfarm
Woodland mills hm126
Started by 60lp on Woodland Mills
Last post December 22, 2013, 10:37:47 PM
by 60lp
Started by hech on Sawmills and Milling
Last post September 02, 2016, 08:30:27 PM
by Magicman
