Author Topic: Woodland Mills HM126 tracking problem  (Read 3827 times)
Offline fishfighter
Re: Woodland Mills HM126 tracking problem
« Reply #20 on: March 17, 2017, 08:07:42 AM »
Well I finally figured out what the problem was. They sent me the new spring washers. Big improvement over the bushing. Sent it to me for free too. Wasn't the problem though. I took the belt off to look at it and it still looked new. Decided to say the hell with it and put the old one back on. Come to find out the new one that was on there was not quite the same belt. This was the belt they sent me in the parts kit. It was a little narrower and the V grooves were not quite as big as the old one. Put the old one back on, problem solved.
Good to hear this. My replacement belts that I buy local are Gates belts. Much better then the stock belts that came with the mill. In fact, when my mill was about a month old, I called them reporting that the stock belt was breaking up. They sent me a new set of Gate belts for free. Now that is service after the sale. ;D Some good people over there. ;D
Offline clintnelms
  • Woodmizer LT35HD
« Reply #21 on: March 17, 2017, 08:12:26 AM »
[/quote]
[/quote]
The service tech I spoke to recommend I use Gate belts also. Said they tend to hold up better.
Offline Savannahdan
  • Retired.
« Reply #22 on: March 17, 2017, 10:16:18 AM »
Whoops, wrong Woodland owner.  The park is near Metter and Swainsboro.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline clintnelms
  • Woodmizer LT35HD
« Reply #23 on: March 17, 2017, 10:27:36 AM »
I called this morning and told them what I found out was wrong and to thank them for sending me the washers and they're sending me a replacement belt for free and i didn't ask them to. You're right, they have fantastic customer service.
Offline mitchstockdale
« Reply #24 on: April 07, 2017, 08:23:14 AM »
Anyone ever had tracking issues? I know how to adjust the tracking. The problem I'm having is on the right drive wheel side. I can make a minor adjustment,  1/4 inch turn or even less, and the blade travels too far forward on that side. Adjust it again the opposite way and it travels too far back on the wheel. That's spinning by hand after torquing the tension to 35 ft lbs. Left non-drive wheel is tracking fine. I can't seem to find the sweet spot. Never had this problem in the past. No matter how little I turn the adjustment nuts it just won't track correctly. Any ideas? The mill is about a year or so old. I've probably milled less than 20 logs. Only went through 10 blades since I've had it so it's not been used a lot. I say that because I've wondered if it's a bad bearing wheel on that side, but seems like I haven't had enough usage for that yet. Spent all day on Saturday trying to get it adjusted and never could get it to track flush with the back of the wheel.
I had this similar issue when i first received my mill in the late fall...i was following the manual from their website which detailed 35ft-lbs torque so i was torquing the thing to 35ft-lbs but the newer mills with the spring washers only require 25ft-lbs of torque as per the manual that came with my mill and the sticker on the mill..oops !!!!....once i re-adjusted the torque to 25ft-lbs everthing ran nice.
Do today what others wont, so you can do tomorrow what others cant.
Kubota MX5200 / Woodland Mills HM126 / Stihl MS361
Offline clintnelms
  • Woodmizer LT35HD
« Reply #25 on: April 07, 2017, 09:20:08 AM »
I had the bushing at the time. Since then I've replaced it with the new spring washers. So far no problems.
Offline fishfighter
« Reply #26 on: April 07, 2017, 06:41:09 PM »
So, what is this spring or bushing you are talking about?
Offline clintnelms
  • Woodmizer LT35HD
« Reply #27 on: April 07, 2017, 09:46:48 PM »
The Mills prior to 2017 had a urethane bushing on the T handle that you torque for blade tension. The 2017 models come with 4 sets of spring washers instead of the bushing. Changes the torque from 35 lbs to 25 lbs. They'll send them to you for free if you call and ask for them. They did for me at least.
Offline mattyo5
  • Newish here!
« Reply #28 on: April 07, 2017, 09:53:26 PM »
Even though the belt was the ticket here..my bandwheel bearings went at 300 hours or so....so keep an eye on that and I'd be prepared to swap them around that time.  Check my youtube channel for the vids.
Woodland Mills HM126 Sawmill - modded
Husqvarna 385xp rebuilt and ported
Husqvarna 372xp rebuilt and ported
2x Husqvarna 350 ...rebuilt and ported
Hitachi CS33etdb top handle saw
Offline Steve67g
« Reply #29 on: August 11, 2019, 06:58:28 PM »
Don't know about Woodland mills, but have seen that problem other places. Bad bandwheel bearings. Try this...adjust to where it sorta tracks, then change the band tension a bit, either up or down. If the tracking changes, it's likely a bad bearing. Most mills use 2 in each bandwheel, one good and the other bad will cause lots of angst.
Thanks pineywoods. I'll try that. Never thought to adjust the tension and see if it moves. Talked to Woodland Mills this morning and he gave me a few suggestions to try. Gotta check the belt and make sure it's not worn down to where the blade is riding on the wheel itself. Don't think so though. Pretty sure I changed it not long ago. They're also sending me a new spring washer kit that replaces a silicon bushing for tension. More to come I guess.
Clint, what came in your spring washer kit?  Which direction does the cup go over the tension bar, facing in or facing out?  Do you use all 12 of them facing the same way?  Mine are over 5 years old, but the Mill caught on fire before I owned it.  I'm wondering if they are still good.  Insight?
Offline Steve67g
« Reply #30 on: August 11, 2019, 07:49:55 PM »
Clint, or maybe someone else can answer this.  I'm brand new & trying to figure out how this forum works, already asked once, but can't find my post.....anyway....!!!  When putting spring washers on the belt tension bar for my WM HM126, do they face in or out?  That is, cups facing in or out?  Do I use all 12 of them?  Just got this mill and it had been in a fire, so lots of rebuilding and learning.  Any insight is greatly appreciated.  Thanks in advance.
Offline thecfarm
« Reply #31 on: August 11, 2019, 08:45:48 PM »
@Steve67g welcome to the forum.
Click on to your user name,or go to your profile,it's on the Menu Bar,the one that starts out with Home Help Search,should be something that say show posts. Click onto that and it will show all of your posts. More things will open up after you have been a member for a while.
Offline Steve67g
« Reply #32 on: August 11, 2019, 08:51:10 PM »
« Reply #33 on: August 12, 2019, 10:02:44 AM »
How often are you HM126 owners changing your drive belts?
I am currently having the same problem as the original poster stated.
I changed my drive belt back in April with good results but have now noticed the blade is pretty much riding on the metal band wheel...one would think that a belt would maintain its crown and width longer than a couple months.  The belt i used was a BX79 from NAPA.  The red PU follower belt appears to be ok but I think I will be replacing both.  any suggestions on more cost effective options... $44 for the belts from woodland mill is fine but add $25 for shipping thats a bit much for two belts..
Online btulloh
« Reply #34 on: August 12, 2019, 10:10:44 AM »
I change mine when they get worn and especially if the blade starts riding on the pulley surface.  They need changing more often than I would have thought.
I have used belts from NAPA and other auto parts stores and Woodland Mills and all seem to last about the same.  I have seen where other people installed brushes to keep the belts clean and I think this would help the overall situation but I haven't done it yet.
https://www.vbelts4less.com/  is a good place to order belts and I use it for lots of my belt purchases.  The pricing is good and I've been happy with the quality.  They have kevlar belts for lawn mowers that are particularly good and a good value.
Tracking has never been a big issue except with some Lennox blades that were not welded straight.  In general, I don't like the Lennos blades but have been very happy with Kasco's.
HM126
« Reply #35 on: August 12, 2019, 10:19:02 AM »
do you still use the red pu follower or do you just run a plain black b57 v-belt? or have you bothered replacing that one?
Online btulloh
« Reply #36 on: August 12, 2019, 10:21:59 AM »
Not familiar with the red follower!  Must be a new thing.
The manual says to change both belts at the same time.  Ehhhhhhhh . . . Sometimes I do, sometimes I don't.  Just depends on what the idle belt looks like.
HM126
Offline fishfighter
« Reply #37 on: August 12, 2019, 11:33:43 AM »
Same here. ;D
« Reply #38 on: August 12, 2019, 12:21:38 PM »
I have a 2016 model year hm126 and it came with a red polyurethane belt on the follower wheel.... I am assuming you are using just plain old v-belts on your follower.?
Online btulloh
« Reply #39 on: August 12, 2019, 12:28:55 PM »
Correct. I’m guessing the red belt lasts longer. Sounds like good thing. They have made changes and improvements since I bought mine. Most times they’ve been very good about providing these when I was in the warranty period.
HM126
Woodland Mills tracking problems
Started by Southwood on Sawmills and Milling
Last post January 21, 2018, 10:28:41 AM
by HOLTeam
Woodland mills hm126
Started by 60lp on Woodland Mills
Last post December 22, 2013, 10:37:47 PM
by 60lp
Started by hech on Sawmills and Milling
Last post September 02, 2016, 08:30:27 PM
by Magicman
New Woodland Mills HM126
Started by jbjbuild on Woodland Mills
Last post January 21, 2018, 10:16:01 AM
by HOLTeam
