Author Topic: Woodland Mills HM126 tracking problem  (Read 3830 times)
Offline mitchstockdale
Re: Woodland Mills HM126 tracking problem
« Reply #40 on: August 12, 2019, 12:46:34 PM »
Correct. I知 guessing the red belt lasts longer. Sounds like good thing. They have made changes and improvements since I bought mine. Most times they致e been very good about providing these when I was in the warranty period.
done deal just gunna go with regular belts this time..thanks btulloh.
Do today what others wont, so you can do tomorrow what others cant.
Kubota MX5200 / Woodland Mills HM126 / Stihl MS361
Offline jbjbuild
« Reply #41 on: August 13, 2019, 07:20:07 AM »
Hi btulloh, I have the HM126 also, which blade from Kasco do you use.
Woodland Mills HM 126, John Deere 790
Online btulloh
« Reply #42 on: August 13, 2019, 09:44:56 AM »
I've been using the 7 degree Kasco's.  They seem to work well in SYP, ERC, as well as fresh WO and RO.  I want to try some 4 degree for harder stuff like oak that has been sitting for a while.  My mill came with the 9.5 hp Kohler.  I've sawed 26" WO on it, but certainly more power would be better.  Older oak logs (and hickory) are asking a lot of the 9.5 hp, but generally it's all gotten sawed - just takes a while.
FWIW, I run my guide blocks fairly loose - about a business card thickness spacing.  I set the rollers so they don't make contact with the blade when it's free running, but do make contact when it enters the cut.  Not saying that's the right way or the only way, but it works well for me.
HM126
Offline jbjbuild
« Reply #43 on: August 13, 2019, 10:03:17 AM »
Thanks! Ive been wanting to try some Kasco blades, but wasn't sure which one to choose with the 9.5 hp. I run my guide blocks the same, I cut up a business card and place one piece above the blade and below the blade and tighten up the guide blocks. I saw mostly Ash, Poplar, Oak & Walnut, so that blade should work well.
« Reply #44 on: September 03, 2019, 12:24:41 PM »
I change mine when they get worn and especially if the blade starts riding on the pulley surface.  They need changing more often than I would have thought.
I have used belts from NAPA and other auto parts stores and Woodland Mills and all seem to last about the same.  I have seen where other people installed brushes to keep the belts clean and I think this would help the overall situation but I haven't done it yet.
https://www.vbelts4less.com/  is a good place to order belts and I use it for lots of my belt purchases.  The pricing is good and I've been happy with the quality.  They have kevlar belts for lawn mowers that are particularly good and a good value.
Tracking has never been a big issue except with some Lennox blades that were not welded straight.  In general, I don't like the Lennos blades but have been very happy with Kasco's.
btulloh,
Got my regular belts from napa and put the follower belt on and man its quite sloppy... when tightening the tension handle the belt leaves the bandwheel by about 1/2" on the opposite side.  Got a B57 per the manual.  Is that what you use for your follower?
mitch
Online btulloh
« Reply #45 on: September 03, 2019, 12:56:19 PM »
I知 just using the regular B57s. They also have a gap of 1/2 or more on the side opposite the blade. This is normal and not an issue.
HM126
« Reply #46 on: September 05, 2019, 07:59:23 AM »
I got the mill running two nights ago with the new belts and all i can say is wow...its such a pleasure to track the blade now and the blade has a nice ring to it.  I would have never thought that worn out belts could cause such problems.  Replacing the belts not only solved my blade tracking issues but also solved 95% of my wavy lumber issues even with a dull blade.  This is the first "major" service I have done to my mill in 3 years owning it.  Just scratching the surface with learning this sawmill thing i guess..this forum does not cease to amaze me with the wealth of knowledge.
Online btulloh
« Reply #47 on: September 05, 2019, 08:59:15 AM »
Three years is a long time.  Glad you got it purring again and sawing straight.  You were probably running on the pulley surface and not the belt after that long.
I've probably been through 15 sets of belts in three years.
HM126
Woodland Mills tracking problems
Started by Southwood on Sawmills and Milling
Last post January 21, 2018, 10:28:41 AM
by HOLTeam
Woodland Mills HM126 mod
Started by Napowan on Sawmills and Milling
Last post May 17, 2016, 11:07:23 AM
by DeerMeadowFarm
New Woodland Mills HM126
Last post April 28, 2014, 10:58:51 AM
by Napowan
Started by jbjbuild on Woodland Mills
Last post January 21, 2018, 10:16:01 AM
by HOLTeam
