Arborwear
Author Topic: no more big logs  (Read 2969 times)
Offline bandmiller2
Re: no more big logs
« Reply #40 on: March 18, 2017, 07:11:52 AM »
Each mill and sawyer has A upper limit to what can be handled and cut economically, write it down so you don't forget. Be resolute in refusing to cut larger logs. I can mill 30" on my homebuilt band mill if its a good straight log and will have nothing to do with larger ones especially ones with butt swell, same thing on length, absolute max 16'. Frank C.
Offline Sixacresand
  • John and Nancy
« Reply #41 on: March 20, 2017, 11:18:06 PM »
I got this 34" at the butt loaded today.  It was knot free, I set it up just right on the mill and it milled like a dream.
The loading arm quickly filled up and ran over with boards that will have to be edged.  A edger and two helpers to run it sure would be nice.
The shadow in the photo is as slow as I am.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #42 on: March 21, 2017, 07:30:59 AM »
That is a hoss.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #43 on: March 21, 2017, 08:55:24 AM »
Nice, you can really make production with those big'uns.
Offline Deese
« Reply #44 on: March 21, 2017, 09:05:42 AM »
That joker is huge.  :o
Sawed 4 years with EZ Boardwalk Jr 13hp. I now have a 2004 LT40HDD51. Cooks Cat Claw Sharpener, Cooks Single Tooth Setter, a bunch of chainsaws, and an old chocolate lab.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #45 on: March 26, 2017, 12:08:49 AM »
I am not portable and I have a forklift. I still charge more for thicker than 1.5'' and longer than 12'. Handling them long and thick boards/ slabs is a lot more work for us, as every piece of scrap and slab has to be cut down to go out the door. Many times we load long lumber back on a customers trailer inside.
It should pay more since it is more work.
PC
 you could use a lorry track.  stack lumber on a lorrytruck and then send it out the door and unload in yard
Boy, back in my day..
Wanted - small diamater low grade walnut logs and pallet logs ...
Started by Wes Lyon on Wanted
Last post August 12, 2006, 10:31:53 PM
by Wes Lyon
blue stain pine logs,aspen logs, Colorado
Started by logloper on Wanted
Last post February 23, 2010, 09:52:24 PM
by logloper
8 ft logs vs vs split logs for seasoning firewood
Started by Christopher7789 on Drying and Processing
Last post March 30, 2017, 10:45:58 PM
by GeneWengert-WoodDoc
Value of Logs
Started by travelr64 on Sawmills and Milling
Last post May 01, 2004, 07:46:07 AM
by travelr64
