Arborwear
Author Topic: Scragg, definition?  (Read 622 times)
Offline Holmes
  • 1840 house
Scragg, definition?
« on: March 15, 2017, 08:17:41 AM »
 What does scragg mean?  Scragg wood, scragg mill.?
Think like a farmer.
Offline paul case
  • Original wearer of the PCM.
Re: Scragg, definition?
« Reply #1 on: March 15, 2017, 11:04:25 AM »
PC
pc
Offline Holmes
  • 1840 house
« Reply #2 on: March 21, 2017, 11:39:26 PM »
 I looked up scragg and it is defined as ugly, scrawny, unkempt, . A scragg mill would be an ugly wood mill, usually short logs.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #3 on: March 22, 2017, 10:04:01 AM »
Seems they are also often used for small diameter recovery.  Not a lot of value there, so the $ is in volume.
Offline Den Socling
  • just wondering
    • PC Specialties
« Reply #4 on: March 22, 2017, 03:24:20 PM »
I was a consultant a long time ago for a company that built themselves a PLC controlled scragg mill. The PLC would set the distance between a gang of blades to get as much as possible out of a log. They were after 3" Red Oak newels. The dogs would pick up the log and run it through the blades. In a matter of seconds, the entire log would fall apart as flitches. It was pretty cool.
Before the scragg was an automatic bucking saw. It would grab a log, a big chainsaw would come down and the job was done.
After the scragg was a line of rip saws. This mill was cutting squares.
After the rip saws was a bunch of chop saws.
Standing in the control room watching the operation running was pretty impressive.
Under the floor that held this operation was another system that handled the strips and sawdust. They would recover small squares from the strips.
In the end, the company went bust. Chinese would do it cheaper and Red Oak went out of style.
Offline Cedarman
    • Cedarusa
« Reply #5 on: March 23, 2017, 07:50:11 AM »
We use a band scragg on cedar 11" and down to 5" x 6' to 11' long with majority being 8'.  Cedar is hard to center properly and takes about as long as loading and sawing.  The best was when we were sawing 6" x 8' into 4x4.  We sawed 90 logs  sorted to 6" in 50 minutes.  Load log, center, end dog, through blades, back, rotate 90 degrees, reset blades to 4", back through blades, release end dog, back carriage and reload.  All done in 45 seconds.  4x4 stacked,  slabs either down belt to hog or through multihead for more lumber recovery.
Many scraggs are 2 bladed with a sharp chain and logs go continuously through the logs.  Then through another blade to make a 3 sided cant that goes through another gang of saws.  Many variations depending on what is needed out of the logs.
Definition?
Started by Ronnie on Sawmills and Milling
Last post August 06, 2011, 04:06:44 PM
by SwampDonkey
smiley
A new definition for rocks
Started by Fraxinus on General Board
Last post March 31, 2005, 06:21:32 PM
by thecfarm
Definition Of a Sawmill
Started by ANVILMAN on General Board
Last post October 10, 2010, 11:49:36 PM
by Okrafarmer
question
shingle vs shake :definition?
Started by james on Sawmills and Milling
Last post April 16, 2009, 06:40:38 PM
by karl
