Arborwear
Author Topic: Logrite gets a new toy (I mean machine)  (Read 7606 times)
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Logrite gets a new toy (I mean machine)
« Reply #20 on: June 20, 2017, 02:54:37 PM »
Office dividing walls.
Add dark curtain to back side for welding curtains.
Line sidewalk with them.
Lots of ideas :)
I knew what I thought I meant.
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #21 on: June 20, 2017, 03:17:27 PM »
I have a guy who wants to lay them on his gravel driveway to help keep stones in place.  Not sure that's going to work.
Crusarius - I thought they would make a nice divider too.  Great minds must think a like.  ;D
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #22 on: June 20, 2017, 03:27:58 PM »
I have never seen a plasma cut sheet that clean. Very nice. Maybe I need to start using higher grade steel with my plasma?
Offline ljohnsaw
« Reply #23 on: June 20, 2017, 03:37:29 PM »
Those hooks hanging on the blue bin are right off the cutter?  No grinding?  WOW!
So did you take a bunch of cut hooks and lay them out various ways to determine what the most you could get out of a sheet?  Just wondering if you could arrange them like a stack of nested spoons only leaning over a bit.  Maybe like:
JJJJJJJJJJJJ
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #24 on: June 20, 2017, 03:52:59 PM »
Crusarius - those hooks have been plated.  If you have a hook from when we had someone else cut them, there is a divot where the machine starts and stops the cut.  Not any more though!! They come off our machine nice and smooth.
ljohnsaw - we use a program to figure out the best pattern for maximum yield
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #25 on: June 20, 2017, 03:54:33 PM »
Amazing what happens when you use the correct lead in and lead out :)
Offline thecfarm
« Reply #26 on: June 20, 2017, 09:29:06 PM »
I'm impressed!!!!
Offline John Mc
« Reply #27 on: June 22, 2017, 09:15:15 PM »
Hmmm... it just might make a good erosion control device - as long as you can keep the water from digging under the outside edge
Offline bucknwfl
« Reply #28 on: June 22, 2017, 10:39:19 PM »
It could be the next camo pattern, part of a new table /  leg design.  Hmmm
Buck
If it was easy everybody would be doing it
Offline DeerMeadowFarm
« Reply #29 on: June 23, 2017, 08:42:37 AM »
I know off-road DIY-ers are always buying gussets, tow hook mounts, etc. for their projects. Seems like you could cut dozens out of the areas between the hooks. Tons of them on e-bay:
PLEASE READ POSTING RULES! EBAY AND CRAIGSLIST LINKS NOT ALLOWED!!
How thick is the material?
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #30 on: June 23, 2017, 03:22:59 PM »
DeerMeadowFarm
3/8"
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #31 on: June 24, 2017, 07:31:27 AM »
It would make a cool fence /gate at the end of the Logrite driveway.
If it is true that we learn from our mistakes, I must be Brilliant!
« Reply #32 on: June 26, 2017, 11:04:37 AM »
DeerMeadowFarm
3/8"
I'd make a bunch of gussets, cylinder mounts, Chain key-hole slots etc. and sell them to DIY's. Just Google those or look on e-bay for the links I'm not allowed to post. If the machine is running anyway why not cuts stuff out of the scrap to sell?
Offline ljohnsaw
« Reply #33 on: June 26, 2017, 11:12:09 AM »
DeerMeadowFarm
3/8"
If you made keyhole plates with Logrite logos on them, I'd buy some! :)
John Sawicky
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #34 on: July 07, 2017, 10:22:07 AM »
I think the material is too thick for keyhole plates but thanks for the suggestion.
If you just want my logo we have nice wall mount bottle openers.  :D :D :D :D
 https://Logrite.com/store/Item/bottle-opener
Offline AnthonyW
  • Wannabe hobby sawyer
« Reply #35 on: November 21, 2017, 01:45:41 PM »
I was expecting the bottle opener to look like a cant hook. Nice Logrite logo on them, though.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #36 on: November 21, 2017, 01:56:53 PM »
that would be cool!
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #37 on: November 27, 2017, 12:32:48 PM »
 I have been unable to wear my Logrite bottle opener out but I keep trying.
The First 60 years of childhood is always the hardest.
Offline mike_belben
  • Pulp Friction
« Reply #38 on: April 19, 2018, 11:37:34 AM »
Just FYI, smith and wesson in spfld does outside forging and die sinking, heat treat, plating, black oxide and maybe powder coating. Possibly also wire edm and cnc work for outsiders.  I was there a decade and my father and brother still are so if you have any interest in contacts there just hollar and i can get names and numbers.
From other shops in springfield i also know independant die shop, 2 cnc shops, a cutter grinder and one water jet/knife sharpening shop.  Got another buddy at hypertherm if its of any help.
Those scraps between your nested parts are absolutely perfect for the thing weve been talking about.  Or cut out stars and half moons etc to make windchimes and such.  Put up random artsy shapes on etsy and they will sell to the craft crowd.
The leftover sheets should get painted and sold for industrial art, think andy warhol soup prints.  Charles Brush at indian orchard mills is the first guy who comes to mind for finding someone.  His 500,000SF mill is half machinists, half artists/photographers and a few art deco/industrial/furniture resto folks. He is the northeast epicenter of manufacturing meets art.  34-40 front street in springfield (indian orchard) mass.  Its where my shop was.
Revelation 3:20
ebay auction to support our forum. Logrite Log Arch from fstedy and Logrite!
Started by Jeff on Current Auctions and Auction Archives
Last post January 16, 2007, 07:37:49 AM
by neslrite
ProSawyer Mary's new Logrite Doyle Scale & Logrite gloves.
Started by Bibbyman on General Board
Last post February 10, 2006, 11:43:18 AM
by beenthere
best machine for me ?
Started by lebonski on Forestry and Logging
Last post November 30, 2016, 08:20:45 PM
by Northern Logger
Does anyone know anything about this machine
Started by Ernie on Drying and Processing
Last post July 09, 2005, 09:48:57 PM
by Ernie
