Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: Franklin 132 XL  (Read 2504 times)
Offline Ed_K
Re: Franklin 132 XL
« Reply #20 on: March 20, 2017, 06:02:54 PM »
 XMartin don't worry to much. I ran mine for 11 years that way, it ran smooth once it started, just used a lot of ether to start it. 🤔 I just didn't know any better back then.😊
Offline XMartin
Re: Franklin 132 XL
« Reply #21 on: March 21, 2017, 06:49:21 AM »
Ed_K,
  Tanks for the input!   I plan to buy it, change the fuel filters, and check for water in the fuel tank.
I've done  a lot of reading on this forum the last couple weeks, and one thing people agree on is that the Detroit is tough!  If clean fuel doesn't help, I will pull the covers off to see if there is a difference where the pistons end up on the down stroke, maybe I can tell if a rod is bent or not. I will also talk to my cousin's boys, who's dad had a Detroit in an Oliver tractor.  He bought it cheap because there was an issue with the engine.  They had guaranteed the block and head, he found a bent rod, and repaired it.  He ran it for 30 years after that, straight induction no blower, no turbo, it screamed ! I remember the awe when I saw 4 exhaust valves per cylinder, and the intake ports on the bottom of the sleeves!
Offline RHP Logging
Re: Franklin 132 XL
« Reply #22 on: March 21, 2017, 08:00:38 AM »
I had/have a Cummins in mine. The first engine was blowing oil out of the breather so bad to finish the winter I built a contraption out of tackle box that caught the oil(3-4 quarts an hour). After every hour I would shut the engine off, open a valve on my tackle box, and let the oil drain back into the pan. It turned out I had a broken ring on three out of four pistons. From the time I had the engine it always had a little exhaust blowing out of the breather. Then eventually an oil drip, then a full on oil stream. The broken rings had so much blowby that they built compression in the crankcase and pushed oil out wherever it could. The cylinders looked good but we're played out at the top. Everything else other then the broken rings looked fine.
Buckin in the woods
Offline XMartin
Re: Franklin 132 XL
« Reply #23 on: March 23, 2017, 09:32:18 PM »
Today is my wife's birthday!
My Franklin 132 forwarder was delivered today.  Happy birthday Mary!
We unloaded it into a plowed field, rough going. The dang thing smoked so bad it would have killed mosquitoes for miles if it was warm enough for them.  Watching the trucker operate the loader, I was thinking, "Wow, that is going to be something else to learn how to operate like the guys I have seen operate loaders before.  But before I start to play with that, I need to pull some covers off and investigate the whole machine.
The forecast here is rain for the better part of a week,so I will wait for drier weather before getting started and taking pictures to share.
Offline BargeMonkey
Re: Franklin 132 XL
« Reply #24 on: March 23, 2017, 10:20:57 PM »
Congratulations. 👍 the smoking part doesn't scare me, but I would determine the cause before it gets terminal and your dealing with something sticking out the side of the block. The Detroits are relatively cheap to work on, filters are easy. When you do start going thru it I would inspect the fittings and line going to your fuel filter bases, I had a piece of gunk in a 90 on mine and had fuel issues that stumped me for a while. You may just need blower seals, did you try and knock open the doors and check and see just how bad the rings looked ? You can have that engine out and laying on the floor in 4-5hrs, kits aren't bad to do and most places can check the head.
Offline XMartin
Re: Franklin 132 XL
« Reply #25 on: March 24, 2017, 07:08:16 AM »
Thanks Barge Monkey.
 It is raining today, and the forecast is for rain the next few days.  I am looking forward to getting started.  I will call the previous owner again, he said I could call with questions.  What oil he used, which fuel to use, what that other button on the dash is for....  The machine really needs some TLC.
Offline XMartin
Re: Franklin 132 XL
« Reply #26 on: March 25, 2017, 05:54:01 PM »
     Well, the rain let off today, I was able to explore my Franklin forwarder.
   The engine serial number is,  4D-33365.  The previous owner, "Larry" told me that at some point he switched the engine from a 353 to this 453. I found a link that said this is a 1978 year engine. It has a blower, but no turbo on it.  I need help figuring out what engine I  have here, is it a "Silver"?
  As Larry suggested, I drained the fuel tank, and pulled the fuel filters. The fuel looked a little milky, but if there was water in the tank it was all in suspension in the fuel, no visible water came out first.  The petcock on the filter housing did allow a few drops of water to drain out before the fuel.  I thought the fuel collected from the filters smelled like gasoline, can't figure that one out. Larry told me the engine was fine when he traded it, he thinks the smoke is from water in the fuel, I'll start with fresh stuff. I will pick up some fuel and filters Monday.
   I also discovered the master cylinder for the brakes is trash, the line runs down to the bottom of the transmission, I'm guessing whatever is down there isn't quite up to snuff either. Not my number one priority yet, but I think brakes would be nice to have. Apparently Larry didn't, the last paint job hasn't worn off the brake pedal.         Later.
   All the hoses are missing most of the rubber outside layer. $$$        Later.
   I need to find a manual for this thing.  The rear of the transmission has a swinging lever that looks like it may be a filler cap, except there is a substantial spring that holds it closed.
  The wiring looks like a rat nest, again, I can wait to sort that out.
  The muffler has some cracks in it, but looks like it can be welded.
   The Franklin has a top mounted loader, with braces running down to the front frame. On the back the top is bolted to the rest of the frame at about seat height, those hinges are all welded solid, not too concerned about that, not sure why I didn't notice that before I bought it but, it is what it is.
   Right now, I need to get the engine right.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: Franklin 132 XL
« Reply #27 on: March 25, 2017, 09:15:38 PM »
Did he move the radiator ahead to fit the 4-53 ???  My 132 has the 3-53 and there's not much room between the fan and the radiator :)
Offline bushmechanic
  • Someone else has it worse than you.
Re: Franklin 132 XL
« Reply #28 on: March 26, 2017, 07:07:31 AM »
If the serial number starts with a 4 then it's a four cylinder, a 3 is a 3 cylinder and so on. The model number will give you more on how it's configured. If that machine is smoking white heavy smoke and runs ok I would suspect an injector has failed. This would also give you the knock when it first started and went away. You can do an injector cut-out test but that may not tell you which cylinder has the issue, the only sure way is pull off the exhaust manifold and it will be the wet hole. Good luck with your "new" machine 8)
Offline tacks Y
Re: Franklin 132 XL
« Reply #29 on: March 26, 2017, 08:58:09 AM »
You can also start by feel, find the exhaust port that does not get as hot.
Offline XMartin
Re: Franklin 132 XL
« Reply #30 on: March 26, 2017, 09:04:37 AM »
Corley5,
He must have moved the radiator,  yesterday I noticed mounting holes in the frame where the front engine mounts must have been for the 353.
bushmechanic,
 I was looking at the option plate yesterday, the serial # is,  4D 33365  5043 7001.  Its raining again so I promised to go to a movie, I haven't been to one for about 20 years, not looking forward to it.  Once I get the new filters and fuel I'll fire it up and do the injector cut-out test.
tacks y,
I'm going to go over some posts again to review how to do the cut out test.  Someone mentioned using an IR thermometer to check for a cold cylinder.
Once again folks, thanks for the responses!
Offline XMartin
Re: Franklin 132 XL
« Reply #31 on: July 16, 2017, 12:09:33 PM »
I picked up my newly rebuilt engine.  Harold, at Leid Diesel told me that water had gotten into two cylinders and next time it was started it bent two rods, they gave me one with the sleeve. The rod bent enough to break out the bottom of the sleeve. Before I re-install the engine, I need to  finish replacing the bearings in the transmission and
  replace a brace between the frame rails at the mounting area for the blade, both sides are cracked, one side completely.
Offline nativewolf
Re: Franklin 132 XL
« Reply #32 on: July 16, 2017, 01:05:56 PM »
glad you are making progress with it.  Too bad about the fluid & the rods.
Re: Franklin 132 XL
« Reply #33 on: July 16, 2017, 02:10:04 PM »
That's a common problem when water gets down the exhaust pipe, goes right to the top of the pistons with the valves open. Soon as you crank the engine... bang bent rods. Should always cover you exhaust if it's being left for a while anyway. If its done right you will get some time out of the new engine. Good luck!
Offline coxy
Re: Franklin 132 XL
« Reply #34 on: July 16, 2017, 02:33:06 PM »
yep been there done that had my skidder for about 4 years nothing ever got in there then one night of heavy rain and must have been parked just right the next day she was done  :(
Is Franklin ....
Started by bkellyvtme on Forestry and Logging
Last post February 09, 2013, 10:29:56 AM
by smwwoody
Franklin 100?
Started by smwwoody on Forestry and Logging
Last post August 19, 2011, 08:28:05 PM
by Meadows Miller
franklin 405
Started by coxy on Forestry and Logging
Last post May 03, 2017, 05:24:23 PM
by kiko
Franklin 170
Started by just farming on Forestry and Logging
Last post January 10, 2018, 11:08:39 PM
by Southside logger
