Arborwear
Author Topic: quarter sawing for fleck  (Read 858 times)
Offline Florida boy
  • Young sawyer with my first mill
« on: March 17, 2017, 12:13:47 PM »
I have a 17' x 22-30" white oak log in the yard that I would like to mill up. I have a manual mp32 mill. I would like to quartersaw the log for furniture making and other wood working projects. I have quartersawn some white oak a few months ago but the logs were 10' or so. my question is should I cut the log in half to get the Ray fleck to stay in the whole board? I have a feeling that with 8" or so of taper that if I mill the log at 17' only part of each board will have the fleck. would it be easier to stay in the fleck better with 8' logs? the log has no knots and is very straight with tight growth rings. just don't want to buck it down unless I need to to get all the fleck I can. thanks.
Offline drobertson
Re: quarter sawing for fleck
« Reply #1 on: March 17, 2017, 12:19:20 PM »
If you have not seen the thread on reverse roll quarter sawing it would be worth your time to review it.
http://www.forestryforum.com/board/index.php/topic,93851.0.html
Offline Florida boy
« Reply #2 on: March 17, 2017, 12:58:23 PM »
yes I've read it very informative. some one even did it with a mp32. I plan on using that  method.
Offline btulloh
« Reply #3 on: March 17, 2017, 07:59:58 PM »
Are you planning to use full length 17's oak for a specific project?  It would be a lot easier to saw 8 footers unless you really need 17' lumber.
Offline Kcwoodbutcher
  • Startin' to get the hang of it
« Reply #4 on: March 17, 2017, 08:45:03 PM »
Most trees twist as they grow, so the longer the log the more twist you have. You can start a cut at 90 degrees to the rings but by the time you reach the end of the cut you're out of the fleck. Cut them in the shortest length appropriate for your project, within reason.
My job is to do everything nobody else felt like doing today
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #5 on: March 17, 2017, 11:28:11 PM »
The shorter the log, the less variables, and the easier to stay in the fleck.  I prefer 8 footers, although I have done longer.
HobbyHardwoodAlabama.com
Offline kelLOGg
  • Still learning more than I'm teaching
« Reply #6 on: March 18, 2017, 06:34:52 AM »
I am interested in your experience using the MP32 to RRQS. We have the same mill.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, screw driver
Offline scsmith42
    • Whispering Pines Farm
« Reply #7 on: March 18, 2017, 08:19:55 AM »
I would encourage you to cut the log into two logs, primarily due to yield loss.
Lumber yield from a log is typically determined by the small end diameter of the log.  If you cut the 17 footer into a pair of 8'6" logs, odds are that one log will have a larger small end diameter and yield more material.
From your comments about only having ray fleck visible in part of the board it sounds as if you are not centering the pith on the the log before making your opening cuts.  When quartersawing, if you don't center pith on both planes you will produce boards with fleck only on one end of the board.
To center the pith, simply raise your toe boards or wedge the small end of the log away from the deck until you have the same distance from the pith to your blade on each end of the log.
Tom's 3638D Baker band mill
Offline Florida boy
« Reply #8 on: March 18, 2017, 08:23:54 AM »
once i get to quartersawing  them I will for sure take lots of pics. on my mill I have the screw type clamps instead if the cam type. I will see how RRQS works with my style and report back.
    looks like most are in agreement. its probably best to buck the log in half.
Offline Florida boy
« Reply #9 on: March 18, 2017, 08:30:27 AM »
yes I just about always level the pith on the mill with any type of sawing.  but if u have a wondering or crooked pith you do the best you can. the first and only log I have quartersawn was pretty knarly. it was right before tthr tree forked and had a single pith on one end and a double pith in the other. the boards where I did get Ray fleck had them throughout the board. also it had some curly aspects in parts of the boards. just planed them up the other night. I'll post a few pics if I can.
Need advice 1/4 sawing 3"X12" beams for fleck
Started by flip on Sawmills and Milling
Last post January 04, 2006, 10:35:31 AM
by flip
Quarter sawing!
Started by PM on Sawmills and Milling
Last post December 27, 2007, 10:51:45 PM
by Dan_Shade
First quarter sawing
Started by MrMoo on Sawmills and Milling
Last post August 12, 2004, 07:33:30 PM
by Bibbyman
Quarter Sawing
Started by Russ on Sawmills and Milling
Last post April 18, 2005, 09:51:12 AM
by MrMoo
