Arborwear
Author Topic: Milling terminology  (Read 903 times)
Offline francismilker
  • Udderly happy!
Milling terminology
« on: March 17, 2017, 07:58:10 PM »
Is there somewhere here on FF that I can find a list of terminology definitions?
I've been making sawdust as a hobbyist for a while now and enjoy reading and learning from you all. However, sometimes I read a thread and with all the "flecks, flitches, slabs, and piths" I often have unanswered questions when I'm through reading.
 I grew up hearing that a log had sapwood and heartwood.
Around my place, if one cuts a tree down and the heart is getting spongy they refer to it as being "pithy".
Can you throw some help for a milling illiterate?🤓
"whatsoever thy hands finds to do; do it with thy might" Ecc. 9:10
WM LT-10supergo, MF-271 w/FEL, Honda 500 Foreman, Husq 550, Stihl 026, and lots of baling wire!
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Milling terminology
« Reply #1 on: March 17, 2017, 08:01:04 PM »
   Click on the Extras button on your FF toolbar and select the dictionary there, If not found post a specific question as to what something means. Welcome to the FF and good luck.
  • Udderly happy!
« Reply #2 on: March 18, 2017, 08:11:49 AM »
Thanks WV. I'll check it out!
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: March 18, 2017, 09:40:20 AM »
 An ordinary dictionary, well may be a good one, will often list different uses of words which include the ways we use them here on the forum.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #4 on: March 18, 2017, 11:00:40 AM »
Well, see, I think the wording will change depending on where you come from.  The spongy heartwood in my neck of the woods is called "punky".  The V in a tree trunk is a "crotch" here and a "fork" down south.  Just sayin'.  :)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: March 18, 2017, 09:28:04 PM »
Whatdayoumean??  :o  We have punky crotches here in the South too!!   :P
Offline paul case
  • Original wearer of the PCM.
« Reply #6 on: March 18, 2017, 09:32:19 PM »
That is better than spongy forks.
Wouldn't that be hard to eat with.
Speaking of eating....
PC
pc
« Reply #7 on: March 18, 2017, 10:20:47 PM »
I think you will find most of the larger pharmacies have treatment for that. :D
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #8 on: March 18, 2017, 10:30:15 PM »
 smiley_ignore smiley_ignore smiley_ignore
Where's the Spoon?
Offline Don P
    • Calculator Index
« Reply #9 on: March 18, 2017, 11:06:00 PM »
If it gets all doty that could lead to a wicked butt flare
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: March 19, 2017, 08:37:24 AM »
 whiteflag_smiley
Offline Ox
« Reply #11 on: March 19, 2017, 10:24:44 AM »
Well you guys just made my morning with your hilarious wit!  Thanks for that!  :D :D
Terminology!
Started by shampjm1 on Sawmills and Milling
Last post February 25, 2015, 08:21:58 PM
by Sixacresand
Help with terminology
Started by timber tramp on Chainsaws
Last post December 20, 2008, 09:12:54 AM
by Al_Smith
Terminology
Started by ARKANSAWYER on Sawmills and Milling
Last post February 18, 2006, 11:49:03 AM
by ARKANSAWYER
Terminology question...
Started by Builder-Bob on Timber Framing/Log construction
Last post December 11, 2012, 05:26:16 PM
by Builder-Bob
