Arborwear
Author Topic: Throttle cable spring broke, 98 LT40 Super  (Read 341 times)
Offline LeeB
« on: March 17, 2017, 08:31:01 PM »
The spring on the end of my throttle cable broke off at the hook. It's been 6 or 7 years since I changed it last and I no longer remember where it hook on. Anybody able to help jog my memory
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Throttle cable spring broke, 98 LT40 Super
« Reply #1 on: March 17, 2017, 08:50:48 PM »
I cannot help Lee.  Since I replaced my engine and added the autoclutch everything is different.  Doesn't it show up in the manual?
Offline LeeB
« Reply #2 on: March 17, 2017, 09:12:49 PM »
I don't guess I have an engine manual. Nothing about it in the paperwork I have. I'll figure it out. t can only reach so many places.
Offline paul case
  • Original wearer of the PCM.
« Reply #3 on: March 18, 2017, 08:27:18 AM »
On the gas ones that I have dealt with it hooked to a strap with a hole bolted down to the upper slide pads on the mast. So that it pulled when the motor rocked over to engage.
PC
pc
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #4 on: March 18, 2017, 09:07:24 AM »
Hello the spring on a 98 Super with the Lombardini Diesel would hook at the clutch arm.
Hope this helps.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline LeeB
« Reply #5 on: March 18, 2017, 03:57:43 PM »
Appreciate the replies. I remembered last night after I had already ordered two new springs that I still had one from when the cable broke several years ago. I managed to find where it hooked to easy enough. Went ahead and tighened the drive belt while I had the guard off. Also found a solinoid in my spare parts box. Need to replace that too. Been bypassing it for a couple of months now.  :D
WM throttle cable spring question?
Started by Jim_Rogers on Sawmills and Milling
Last post March 22, 2011, 12:01:49 PM
by isawlogs
Last post February 27, 2014, 10:32:00 PM
by Okrafarmer
Spring on lt40 throttle
Started by Hale87 on Sawmills and Milling
Last post May 04, 2014, 10:40:50 PM
by backwoods sawyer
441 throttle cable
Started by yogi on Chainsaws
Last post March 30, 2013, 02:03:34 AM
by yogi
