Arborwear
Author Topic: Gave chain Turner a overhaul  (Read 2723 times)
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« on: March 20, 2017, 12:15:35 AM »
My B-30 aka (TK B-20) 11 years of heavy logs finally was about to fail.
The tube has worn through and has a twist in it.
Time to reinforce and straighten
Cut out the worn area that chain wore through and added some 3/4"  plate
After getting original tube straight we added 3/8" x 4" plate to sides and new sprocket shafts and grease bushings. And Now we have a industrial chain Turner once again
Custom Commercial Sawmill - Whidbey Island, WA | Whidbey Woodworks and Custom Milling   06 B-20 Timberking 30hp gas.  Hud-son 60 Diesel wide cut bandmill    86 F-700 boom truck    JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline ladylake
Re: Gave chain Turner a overhaul
« Reply #1 on: March 20, 2017, 05:27:34 AM »
 I had to do the same thing a few years back, looks good.. After breaking the original no 60 chain too many times, I bought 10' of 60H chain for around $30 then welded U shaped pieces of metal every 5th link.  The 60h runs for years without any troubles plus I got 2 chains out of that 10'.  Steve
Offline Clover
  • I'm newish
« Reply #2 on: March 20, 2017, 10:20:40 AM »
Nice job on that turner. I've got a claw turner that I've built but there are times when I'm working alone and need that third hand hold the log. I'm starting to collect parts for a chain turner and your pictures have helped a lot.
Home made 30 hp sawmill all hydraulic, stihl 026, 170, pioneer 65, John Deere 955 with home made forks. And a whole slew of other tools
Offline ladylake
« Reply #3 on: March 20, 2017, 11:00:29 AM »
 Chain turners work great and should be easy to build..  Steve
Offline killamplanes
  • one man band
« Reply #4 on: March 20, 2017, 11:16:20 AM »
Feel free to give me ur shipping address, I will you send u mine. (Lol). I'm due for second rebuild. Good job..
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
  • one man band
« Reply #5 on: March 20, 2017, 11:18:39 AM »
The drive sprocket end is like putting a puzzle together. I never like puzzles >:(
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #6 on: March 20, 2017, 05:41:52 PM »
The curve part of a can't hook on the end of a cable works real good
for that.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline coppolajc10
« Reply #7 on: March 20, 2017, 06:06:57 PM »
Nice job redbeard!
Offline Clover
  • I'm newish
« Reply #8 on: March 20, 2017, 10:57:14 PM »
I think we need to start a chain turner subject. One with pictures of turners, from being built to installed, with everything in between
Offline FloridaMike
« Reply #9 on: March 20, 2017, 11:31:52 PM »
Great rebuild!  Pics are a great resource!  Good idea on the chain turner page Clover.
I'm in the early stages of designing and building my two.  I am thinking of running a common 1.5" shaft to turn the bottom sprockets and serve as the pivot point for both chain turners, driven by one high torque hyd. motor (direct driven from one of the ends of the common 8' shaft).  There would be independent hyd. cylinders to raise and lower each arm separately.  I plan to run #80 chain with #80 SK-1 Attachment Connecting Links installed every 5 to 6 links, with welded solid stock bridging the uprights.
Is there any reason the above setup wouldn't work well?  Maybe someone is already building a similar set up.
Mike
Offline Clover
  • I'm newish
« Reply #10 on: March 20, 2017, 11:41:12 PM »
Floridamike #80 chain is pretty heavy duty stuff. What about 60 or 60H? Am I understanding your post that the turners would be 8' apart? What would the requirement for that be?
I have a claw turner that can lift a house but sometimes I need an extra hand beside it to turn or hold the log for final positioning. Two turners close together could do the same thing as what I'm looking for. Although both chain would need to be independent of each other.
Offline FloridaMike
« Reply #11 on: March 20, 2017, 11:55:27 PM »
I'm thinking two turner arms would be better for longer logs.  At 8' apart, any point on a 24' log would be within 8' of a turner.  The arms would move up or down independently of each other, so one or both could be used as an additional holder/clamp.  Only the rotation of the chain's would be siamesed together.
Mike
Offline Kbeitz
    • My Hobbies
« Reply #12 on: March 21, 2017, 01:55:10 AM »
What about Agg chain for hay elevators ?
Offline ladylake
« Reply #13 on: March 21, 2017, 06:01:46 AM »
 60h lasts way better than 60.  If building one I'd go with the 80 but 60h would work.  Steve
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #14 on: March 21, 2017, 06:44:28 AM »
Nice job on the rebuild redbeard.  Looks good as new.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline ladylake
« Reply #15 on: March 21, 2017, 07:25:50 AM »
for that.
 After being spoiled be a chain turner, no way.  Steve
Online JB Griffin
« Reply #16 on: March 21, 2017, 07:48:10 PM »
If I was building one I would use 100 or 120 with lugs welded to every 3rd or 5th link.  And I might just do that to replace the joke that woodmizer calls a turner along with the hyd. feed upgrade and 6-10 gpm pump and pony motor, vertical backstops and on and on.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline Kbeitz
    • My Hobbies
« Reply #17 on: March 21, 2017, 08:44:06 PM »
You don't need to be welding lugs on your chain.
There is many different kind of lugs that can be bought
that hook right on the chain.  Sample....
Offline Clover
  • I'm newish
« Reply #18 on: March 21, 2017, 09:34:37 PM »
Kbeitz with that link you would have to use a chain breaker and break the chain every 4 or 5 links and add that in. You can buy the whole chain already made up with those links. But if you went with an 80 or bigger link you could weld right to it and probably a lot cheaper. I was thinking of welding schedule 80 pipe cut about 3/4" thick and cut again into a C shape.
Offline FloridaMike
« Reply #19 on: March 21, 2017, 11:52:20 PM »
Cost is the biggest factor in going above #80 chain size.  You can rebuild a #80 turner 4 or 5 times over for the cost of the #100/120 components.  I do think you can weld lugs directly to #80 or larger chain side plates, but I'm guessing solid square lugs will work better than half round pipe lugs.
For my low volume mill, I am going to roll the dice with a #80 chain/sprocket size.
Mike
B-20 Chain Log Turner
Started by chickenchaser on Sawmills and Milling
Last post September 21, 2013, 07:41:52 PM
by Tom the Sawyer
Woodmizer chain turner
Started by Faron on Sawmills and Milling
Last post April 29, 2005, 09:01:37 AM
by rs1626
TimberKing Chain Turner
Started by fstedy on Sawmills and Milling
Last post August 19, 2005, 12:24:56 PM
by fstedy
Chain Turner - homemade
Started by Puffergas on Sawmills and Milling
Last post July 06, 2009, 07:29:13 PM
by Puffergas
