Author Topic: log clearance height  (Read 1453 times)
Offline xlogger
« on: March 21, 2017, 07:10:30 AM »
On the Lucas Mills how much height do you have if you raise the slabbing blade as high as it goes to the ground?
Offline Lucas_USA
Re: log clearance height
« Reply #1 on: June 14, 2017, 10:13:45 AM »
Hi Xlogger,
Your maximum log size on the dedicated slabbers would be either 60 or 76 inches for the smaller two models. However on some logs you will need to block up the end frames to get the max cut. Ill grab a tape the next time I have one set up. I can tell you the DSM endframes are 5 or 6 inches higher than the swing mills endframes to accommodate the larger logs.
18,000 bdft of fire clearance
Started by TreeBones on Sawmills and Milling
Last post July 05, 2008, 02:24:12 AM
by TreeBones
Zero clearance insert function?
Started by Brad_bb on General Woodworking
Last post June 21, 2010, 12:24:26 PM
by OneWithWood
My take on a replenishable Zero clearance insert
Started by jamesamd on General Woodworking
Last post March 06, 2011, 07:49:11 PM
by Brad_bb
Clearance Light Lens
Started by Autocar on Forestry and Logging
Last post August 10, 2012, 10:11:18 PM
by thecfarm
