Arborwear
Author Topic: Chattering band-Kasco  (Read 3078 times)
Offline Deere80
« on: March 21, 2017, 08:05:49 AM »
what would make the cut look like this?  2 weeks ago I installed Cooks roller guides and now I am getting rough cuts, I am using .045 7 degree Kasco bands that are new out of the box and have tried more than one so that isn't the problem.  If I speed up it will not give me the gouge marks but I am pushing it so hard that when I hit a knot it gives me a wave with a brand new band and if the board is wide I cant push hard because I do not have the horsepower to go fast.  Do I not have enough down pressure on the rollers??  I have them set at 1/4" down pressure.
Wood-Mizer LT35HD
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Chattering band-Kasco
« Reply #1 on: March 21, 2017, 08:08:14 AM »
I'm kinda new at this but I would like to make a guess that you have
one or two teeth out of set.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline ladylake
« Reply #2 on: March 21, 2017, 08:35:31 AM »
 I'd try tightening or loosening the tension, is your blade level with the deck before adding down pressure.  Steve
Offline Mt406
« Reply #3 on: March 21, 2017, 09:19:20 AM »
I get the same pattern.
My mill is a LT 35  25 hp
It seams to happen to me on wide cuts over 8 in.
I am thinking (for all that's worth) it has to do with blade tension and speed.
most of my wood is for ranch's they don't care much about looks they want cheap.
when its finish wood I go with a 4 it gives me a smooth cut and cuts knots best for me
Scott
Offline pineywoods
« Reply #4 on: March 21, 2017, 09:36:35 AM »
Most common cause for that washboard pattern is a slipping drive belt. Band wheel belt worn down to where the blade rides on the metal of the bandwheel will also cause that. The blade gets a good bite into the wood and slows down or even temporarily stops, then pulls loose from the wood and resumes speed..
Offline Deere80
« Reply #5 on: March 21, 2017, 09:45:07 AM »
I have a new drive belt installed ten hours ago that i checked last night and is tight.  If that is the case Pineywoods why would it be a lot worse when I go slow and when I increase my feed speed it is a lot better.  Wouldn't it slip more if i am pushing the blade harder into the material?
Wood-Mizer LT35HD
Offline Mt406
« Reply #6 on: March 21, 2017, 09:51:39 AM »
Piney
That is a good thought My mill has only 100 hrs and I adjusted the drive belt when it was recommended I will check it.
On my mill it only seams to happen with 7s.
If I am remembering right I think the WM dealer said I didn't have the HP to run 7s or was he talking about the turbo 7.
Offline Cutting Edge
    • Rix-Saws CBN Wheels
« Reply #7 on: March 21, 2017, 10:52:50 AM »
what would make the cut look like this?   If I speed up it will not give me the gouge marks but I am pushing it so hard that when I hit a knot it gives me a wave with a brand new band and if the board is wide I cant push hard because I do not have the horsepower to go fast.
This is a common problem with smaller mills trying to run to aggressive of a hook angle.  The engine does not have a sufficient torque curve to keep the blade at a consistent speed and blade speed drops, harmonics set in/take over... IMO
Most small mills are already running on the low side of the blade speed to compensate for the lack of engine HP and a VERY narrow torque band in relationship to RPM's.  Combine that with sawdust spilling past the gullet due to a small particle size and inconsistent feed rates, the problem begins to compound itself.  Hence, poor cut quality.
As ladylake suggested... Make sure tension is proper.  Adding down pressure may help but it will only cover up the root cause IMO.  There are many mills of this class running 3/16"-1/4" down pressure making excellent lumber provided the best suited blade is being used.
If tension is right, a small reduction in the amount of set may prove to be the best solution to help stabilize the blade in the cut.  If you have the ability, resharpening at a 4 deg hook angle will probably produce the biggest improvement.
 I didn't have the HP to run 7s ....
In my experience and feedback from customers, this is a prime example of why a 4 deg blade works best on these type mills and why I always recommend it to most customers under 25hp.
Hope this helps.
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blade Distributor
Ph- (304) 878-3343
Offline Deere80
« Reply #8 on: March 21, 2017, 11:07:13 AM »
So if that is the case Cutting Edge why did I not see this ever with a 10 degree band then?
Wood-Mizer LT35HD
« Reply #9 on: March 21, 2017, 11:56:30 AM »
The 7 deg. blade has a taller tooth/deeper gullet, which in turn, takes away from the beam strength of the blade.  And at lower speeds (surface ft per minute), makes it more susceptible to harmonics.
Maybe the best way to put it in different terms would be how a vehicle acts when a tire is out of balance and at certain speeds it will make the vehicle shake and if that speed is maintained it will get progressively worse (sometimes violently).  Increase speed and the feeling of the vibration goes away.  Similar to how you described increasing feed rate and the chatter marks went away... but lacked the power needed to maintain a smoother cut.
Vibration causes harmonics.  This could be from the engine, the belts, band wheel out of balance, flat spot on guide roller, etc.  or a combination.  Regardless, this can/does get transferred to the blade.  The blade is flexible and has little chance of resisting these forces.
If you compare the 10 deg profile to the 7 degree, the difference is very noticeable.  The Kasco 10 deg and 4 deg have the same tooth height/gullet depth and back angle, only difference is the hook angle.
Ph- (304) 878-3343
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #10 on: March 21, 2017, 12:38:39 PM »
Harmonics.  When I see this I change the tension in the blade and it goes away.
Not saying the others are wrong, cause what they're saying is right too.  This is simply what I do.  :)
Offline york
« Reply #11 on: March 21, 2017, 12:47:34 PM »
Grab a hold of your band guide`s and see if they are not moving-they need to be rigid,try without band tension...
Albert
Offline Deere80
« Reply #12 on: March 21, 2017, 02:02:50 PM »
York,  you saying the roller guides?  to see if I have a bad bearing or loose bolt not holding it steady?
Wood-Mizer LT35HD
Offline york
« Reply #13 on: March 21, 2017, 02:57:58 PM »
Yes,they need to be rock solid,no movement,no vibration...
Albert
Offline Deere80
« Reply #14 on: March 22, 2017, 07:56:56 AM »
Well last night I went and tightened my drive belt, checked the rollers to make sure they were solid, and adjusted one of them a little because it was off  on the level of the blade.  Cut a log and it was better but still get the chatter marks a little so will just have to play with it some more to try and fix it.
Wood-Mizer LT35HD
Offline slider
  • sawyer,trucker,tree service
« Reply #15 on: March 22, 2017, 08:23:34 AM »
Deere80 i am with Cutting Edge on this one.I saw a lot of knotty pine.I don't get the chatter you are getting with my lt 70 but i did with my old lt 40.I did however change to the 4 degree bands and i don't get near as much wave as before.The lt 40 was 24 hp and the lt 70 is 62 hp.Hope this helps.
al glenn
Offline gmmills
« Reply #16 on: March 23, 2017, 11:22:42 PM »
   You do not have enough horsepower on your mill to run a 7 deg blade. You can adjust you mill until you are utterly frustrated and will not correct the problem.  Cannot emphasize this enough, any mill with under 25 HP should be running a 4 deg blade as an all around blade. Low hp mills are not capable of maintaining optimum blade speed, narrow torque band, to be able use a blade of higher hook angle. Being able to maintain blade speed is paramount to sawing accurately while achieving peak productivity for your mills hp rating. Get yourself some 4 deg blades.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #17 on: March 24, 2017, 12:07:58 AM »
Harmonics and at least one tooth out of set.  The harmonics is simply a blade that vibrates excessively and gouges wood.  Caused by what everybody has said.  It's easy to detect, look at the band when it spinning, you'll see vibration before it ever hits the log.
HobbyHardwoodAlabama.com
Offline Kbeitz
    • My Hobbies
« Reply #18 on: March 24, 2017, 06:12:30 AM »
I cut ash in the fall last year with 7 deg. blades with a 13 hp Honda.
I just bought a box of 4 deg. blades and have not tried them yet so
I don't know how much difference that I'm going to see. But I don't
think I had any problem with the 7's like everyone said I would with
only 13 hp. I will report on how much difference that I find.
Offline fishfighter
« Reply #19 on: March 24, 2017, 07:11:46 AM »
I have to disagree with this. I have the same mill the OP has. I use 7drg Kasco blades and I don't have the problem he is having. I find those 7 drg blades are three times better then 10 drg. ;D
OP, did you have this problem before changing out your guides?
OP, check your throttle linkage to make sure your engine is running at full speed. Mine had slipped in the past.
This is some oak fresh felled and I sawed this morning using Kasco 7 blades. No marks.
Kasco Saw II B Band Length
Started by kczbest on Sawmills and Milling
Last post August 06, 2008, 02:11:41 PM
by kczbest
LT40 mill problem, chattering blade in wide cuts
Started by Kelvin on Sawmills and Milling
Last post March 07, 2009, 09:34:34 AM
by pineywoods
Kasco
Started by goose63 on Sawmills and Milling
Last post August 31, 2015, 06:23:00 AM
by xlogger
Kasco owner here
Started by Bill in U.P. on Sawmills and Milling
Last post December 23, 2006, 10:23:45 PM
by pasbuild
