Arborwear
Author Topic: Rust Spots On Western Red Cedar  (Read 1317 times)
Offline highleadtimber16
  • Learning Everyday
« on: March 22, 2017, 01:02:26 AM »
Hey everybody, I'm been fighting with rust on my boards for about 4 months now. I've been talking with woodmizer and they're just as baffled as I. It appears on some boards, and some not at all. I've changed water sources, made sure my blade isn't hitting the back of the guide rollers, looked for any source of steel flaking off, and can't figure it out. It only seems to happen on my WRC and Yellow Cedar, guessing the acidity doesn't help. It doesn't affect the fir. Each time I put a new blade on, I run the water and hold a stick on the blade while it's spinning, to clean the burrs. Hopefully someone has an idea as to what is going on. Thanks
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline fishpharmer
Re: Rust Spots On Western Red Cedar
« Reply #1 on: March 22, 2017, 06:52:53 AM »
Almost looks like mold.  I have no expert advice.  Maybe try distilled water with a mild base, like baking soda to offset the acid.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline Chop Shop
« Reply #2 on: March 22, 2017, 03:50:15 PM »
Rust and iron usually leave grey/bluish/black stain on the wood.
Are you sure its not bark?    If I saw cedar when its raining out and the sawdust from the bark (dark colored brown bits) are not rinsed off with the hose then I get the same marks.  Sometimes like little flecks of rusty brown all over to.
My circle mill doesnt do it because it makes chips, rather than dust.  But my lucas slabber will do that same thing since some of the dust is much finer.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #3 on: March 23, 2017, 12:15:09 AM »
Hmm ???. I've sawn a respectable amount of WRC with a Wood-Mizer and never seen anything like that. I use a 50-50 mix of windshield washer fluid in the spring and fall, and straight water in the summer. I tend to keep the blade lube running to keep the blade from heating up and losing tension. I use untreated water and around here it is classed as "moderately hard".
However, I'm just starting into a fairly major job sawing all WRC so I will keep a close eye out for anything similar.
It looks like your logs are peeled.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Don P
    • Calculator Index
« Reply #4 on: March 23, 2017, 08:24:02 AM »
Maybe try a little experiment? Oxalic acid will get rid of metal stains in oak, I'd bet it would do the same in cedar. To me a metal stain is black/grey but I think it would work or have an effect if that is from metal. If you can't find it straight at the paint store look at the label on various deck cleaners at the big box store.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #5 on: March 23, 2017, 09:11:06 AM »
 Rub a potato on rusted areas.
Google it...
To clean rust with a potato, cut it in half lengthwise or crosswise, depending on how large a surface area you want. Dip the cut end in dish soap or baking soda and firmly rub it over the rusted area. If the end of the potato gets slick, slice it off and dip the newly cut end
Love machine shop work
and Wood work shop work
And now a saw mill work
  • Learning Everyday
« Reply #6 on: May 14, 2017, 12:14:24 AM »
Thanks for the replies guys. My computer crashed, so I've only been able to go on the forum via iPhone till now. I'm still having some issues with rust. I changed my blade guide rollers and it seems somewhat better but still randomly occurring. It seems brand new blades are much better, than ones that have been returned from sharpening. I've tried two different sharpening sources, one cbn and one drag grinder and it didn't make a difference. I'm kind of stumped  :-\
And, yes Brucer you're correct, all my logs are debarked.
Offline Brucer
« Reply #7 on: May 14, 2017, 02:08:44 AM »
So in the past couple of months I've sawn about 15,000 BF of peeled WRC and I've seen nothing like the rust spots in your pictures. The logs are a mix of green (as in harvested a couple of days before we sawed them) and one or two years old. I really haven't a clue as to what's causing that ??? ???.
  • Learning Everyday
« Reply #8 on: May 14, 2017, 10:18:09 AM »
I've noticed that it doesn't effect my local cedar which is mostly second growth. It is very wet. This charlotte island old growth is much more acidic, and drier. I'm thinking this may have something to do with it? Brucer do you ever notice some marks on your first cut with a fresh blade, from metal shavings?
No one has really complained about the rust "just questioned it", but, it is driving me crazy.
Offline Kbeitz
    • My Hobbies
« Reply #9 on: May 14, 2017, 01:31:58 PM »
Check to see if the back of your blades is cutting into your wheel guides...
Offline Bigshooter
« Reply #10 on: May 14, 2017, 02:10:39 PM »
Just a thought but I had staining issues on my mill also. Took some time to diagnose but my problem was my blade scrapers were out of adjustment. This would lead to sawdust build up around the wheels. I use a fair amount of water when I'm milling. So the sawdust builds up and get wet it absorbs the different materials around it.
This can be rust, pitch, dirt from the log and so on. This sawdust is black in color and when it falls off and goes through the cut, you get a stain.
That's my story, I hope it helps.
Offline Brucer
« Reply #11 on: May 14, 2017, 10:55:49 PM »
... do you ever notice some marks on your first cut with a fresh blade, from metal shavings?
Nope.
None of the stuff I'm cutting is old-growth, either. That would suggest that part of the problem has to do with the old growth timber.
Offline Crossroads
  • lets make some sawdust
« Reply #12 on: May 16, 2017, 12:47:15 PM »
Is the stain on both sides of the cut equally? It kinda looks like it's sprinkled on from the top after the cut has been made? Could something be accumulating and shaking down from above?
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummings,
Offline Kbeitz
    • My Hobbies
« Reply #13 on: May 16, 2017, 01:50:37 PM »
Termites for above.....
Rust spots on Jointer
Started by Gipper on General Board
Last post June 27, 2007, 08:44:40 AM
by Engineer
Spots after applying Linseed Oil to Red Cedar Mantel
Started by DHUNTER on Drying and Processing
Last post May 27, 2014, 07:28:12 PM
by Den Socling
question
Western Cedar VS Eastern Cedar
Started by MULE_MAN on General Board
Last post February 28, 2005, 08:51:37 AM
by MULE_MAN
question
Western red cedar
Started by mts enterprises on General Board
Last post October 03, 2005, 03:17:50 PM
by Frank_Pender
