Author Topic: Sawmill camper?  (Read 12370 times)
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Sawmill camper?
« Reply #160 on: June 28, 2017, 10:25:09 AM »
I also had that problem with my hot water heater and found that the thermal coupler was not far enough into the flame and was therefore not getting hot enough. I adjusted (bent) it a little more into the fire and it worked fine.
1992 LT40HD
Offline OlJarhead
    • Dartplayer
Re: Sawmill camper?
« Reply #161 on: June 28, 2017, 10:33:53 AM »
Interesting.  This one is the same place as the original so I don't know if that's an issue or not.  It's also slightly different at the other end so I'm wondering if that might be the issue?
2016 LT40HD26 and Mahindra 5010 W/FEL
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Sawmill camper?
« Reply #162 on: June 28, 2017, 10:45:39 AM »
I forgot. that was my first issue as well. I had to bend my thermal couple into the flame.
If you want to make sure it works put a multimeter on the 2 wires and grab the end with your hand. You should immediately see a voltage increase.
I knew what I thought I meant.
Offline KirkD
Re: Sawmill camper?
« Reply #163 on: June 28, 2017, 11:54:09 AM »
If it stays lit with a butane lighter on the thermocoupler but goes out when you remove it you know it is not getting hot enough off the flame it is producing.
Wood-mizer LT40HD-G24 Year 1989
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Sawmill camper?
« Reply #164 on: June 28, 2017, 11:54:34 AM »
You might also need to crank down the propane regulator screw a turn or two.
Not all regulators are adjustable.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline OlJarhead
    • Dartplayer
Re: Sawmill camper?
« Reply #165 on: January 13, 2018, 10:12:58 AM »
Late last fall we sold the Angler 9D (for about double what we had in to it too!)  8)
Now we're waiting on our new Arctic Fox 990.  Yup, we went whole hog on this one.  Many reasons but chiefly among them was the wife.  Sure I wanted heat, ac, a generator (as much or more for the mill than the camper as I like to use air to blow it off etc during band changes), entertainment (at a minimum a stereo but I liked the idea of a TV as I found I was often left alone on the jobsite after the day was done with just my thoughts and a kindle.  Nothing wrong with that but after a long day milling I thought it might be nice to watch a little TV before collapsing for the night).
Also wanted a bigger bathroom that I might actually be able to use with the door closed and even shower in.  And we wanted an awning over the door at the least.
With the 990 we got all that and a lot more but the wife is very excited that she will be 'comfy' on the jobsite and can come with me on weekends when we go milling.
I call that a win win :D  And the 990 is a true 4 season camper with 56 gallons of fresh water so I can use it well into the fall and early winter and carry water for the mill :D
Offline OlJarhead
    • Dartplayer
Re: Sawmill camper?
« Reply #166 on: January 13, 2018, 10:14:35 AM »
I call this camper a 'luxury apartment on the back of your truck' LOL
Offline D6c
Re: Sawmill camper?
« Reply #167 on: January 13, 2018, 10:36:25 AM »
Dang, that's a nice slide in....I could pretty well live in that.
Offline Darrel
Re: Sawmill camper?
« Reply #168 on: January 13, 2018, 11:41:02 AM »
I like it, and Vera wants one too.
1992 LT40HD
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Sawmill camper?
« Reply #169 on: January 13, 2018, 08:06:28 PM »
Very nice one.  8)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Sawmill camper?
« Reply #170 on: January 13, 2018, 09:27:11 PM »
Arctic Fox is top of the line.  Congratulations on making a very wise choice.   8)
Offline fishfighter
Re: Sawmill camper?
« Reply #171 on: January 14, 2018, 06:38:03 AM »
Y'all going to enjoy that camper. It's a DanG shame I haven't used ours in almost three years. :(
Offline OlJarhead
    • Dartplayer
Re: Sawmill camper?
« Reply #172 on: January 15, 2018, 09:01:28 AM »
I looked a long time before finally deciding to go new and with AF but one thing was really clear:  like Subaru's, a used AF is darn near as expensive as a new one!  They appear to retain their value very well for a camper.
Also, they had the most headroom in the cab over bed than any other.  Sure, heavy and tall but very nice and the wife is exited about going milling with me now :D
Offline OlJarhead
    • Dartplayer
Re: Sawmill camper?
« Reply #173 on: March 30, 2018, 10:57:06 PM »
We did it :D
Offline NorcalMatt
Re: Sawmill camper?
« Reply #174 on: March 31, 2018, 12:07:59 AM »
Good looking rig!
Online mad murdock
Re: Sawmill camper?
« Reply #175 on: March 31, 2018, 12:08:24 AM »
 Now you are “cookin’ with gas”! 8)
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline OlJarhead
    • Dartplayer
Re: Sawmill camper?
« Reply #176 on: March 31, 2018, 06:20:41 AM »
Thanks guys :)  This thing is huge!  Amazing amount of room inside and a bit of a truck squisher but so far it handles it well and the 4080lbs rated Toyo's don't seem to mind it ;)
Now to get a new hitch and extension for it (ouch those aren't cheap!) so I can haul the mill behind it.
    • A&P Saw mill LLC
Re: Sawmill camper?
« Reply #177 on: March 31, 2018, 06:32:35 AM »
smiley_thumbsup
Sawing since 1987
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Sawmill camper?
« Reply #178 on: March 31, 2018, 08:57:14 AM »
going to need some add a leafs or some air bags.
Offline Resonator
  • Board Footage and Cord Woodage
Re: Sawmill camper?
« Reply #179 on: March 31, 2018, 09:16:35 AM »
Nice rig! Would be a good idea to measure your clearance height and write it down, just in case you need to know it.
Card carrying Wood-Mizer owner - 2017 LT28G19
Kubota MX5800 4WD HST, '07 Dodge Ram 2500 4WD 5.7 Hemi with 8'-2" Boss V-XT plow, a couple of Stihl chainsaws,
18 acres of trees, 7 guitars, and Class A CDL licence with about a million miles in a semi truck.
"Chasing the sawdust dream..."
living in a camper?
Started by bigred1951 on General Board
Last post June 13, 2013, 07:16:38 PM
by WH_Conley
New camper, any advice?
Started by Compensation on The Outdoor Board
Last post October 10, 2014, 10:07:10 PM
by Southside logger
Happy Camper would have done it better
Started by rimshot on Sawmills and Milling
Last post November 25, 2013, 05:08:53 PM
by rimshot
Un happy camper!!!!!!!!!!
Started by Woodhauler on Forestry and Logging
Last post March 07, 2013, 08:37:26 PM
by JDeere
