Author Topic: Reverse Roll QS on a manual mill  (Read 761 times)
Online kelLOGg
« on: April 11, 2017, 08:55:06 AM »
Following Yellowhammer's QS method on my manual mill showed me I needed some tools in addition to my cam clamps and squaring arms to stabilize a cant on edge. The pics show what I ended up using.
I use a bottle jack w/ a sharp ring tack welded to the tip to bite into the cant to lift/rotate. Adjustable braces (1/2 - 13 threaded rod) are inserted to counter the sawing force caused by the blade. My squaring arms pivot and so are not very useful to hold the angle without a good bit of force against them.
Blocks clamped to the bunks hold the cant and define its pivot point.
The last piece is pretty small so sawing was done very slowly. I flipped the pieces and sawed off the bottom.
Tools needed are pretty simple. The scissor jack is used to push cant when needed.
Sorry, no pics of the lumber - they are stacked for drying.
Thanks again to Yellowhammer.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Reverse Roll QS on a manual mill
« Reply #1 on: April 11, 2017, 09:21:12 AM »
Now that is digging in and clawing the "goody" out of that log.   smiley_thumbsup
Offline Deese
« Reply #2 on: April 11, 2017, 10:58:25 AM »
kelLOGg, I read YH's thread explaining this. How interesting!
Is this the first log that you've done this way? Do you plan to continue this method on certain logs?
'04 LT40HDD51
Online kelLOGg
« Reply #3 on: April 11, 2017, 11:50:52 AM »
I have done about 3 logs (6 halves) this way and I plan to continue. It does take more time and there is a learning curve but the last log I did went much faster than the first. (I didn't time it). The little adjustable braces are surprisingly effective at stabilizing the cant during the cut but I am open to using blocks and maybe even the squaring arm; it all depends on the size/shape of the cant. To make sure the braces have bitten into the cant I release the jack letting the cant settle into the brace then reapply the jack pressure just a tad so it make contact with the cant.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #4 on: April 11, 2017, 12:09:13 PM »
 I like it! Simple and useful.
Magic Man, my mother used to use that term all the time.
...looking into a mostly empty soup pot, "There's plenty of goody left in there"
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #5 on: April 11, 2017, 11:10:05 PM »
Thats some serious ingenuity.  How did the boards turn out?
HobbyHardwoodAlabama.com
Online kelLOGg
« Reply #6 on: April 12, 2017, 07:03:24 AM »
Actually, I was a little disappointed in the ray fleck. I got more in the sapwood than the heart. I think it was due to the log (I know, but really ::)) - the small cracks began to curve as they went thru the heart toward the pith so there was no way a straight line saw path could be perpendicular to the growth rings in both the heart and sapwood. I should have cleaned up an end of a board and taken a pic.
Thanks for the feedback.
Bob
Reverse Roll Quarter Sawing
Started by YellowHammer on Sawmills and Milling
Last post July 01, 2019, 10:37:22 AM
by Darrel
Applying Reverse Roll Quartersawing to an Onion
Started by WDH on FOOD! FOOD! FOOD!
Last post July 25, 2018, 07:40:01 PM
by WDH
Manual mill versus hydraulic mill. ( Woodmizers)
Started by gator gar on Sawmills and Milling
Last post July 16, 2010, 09:38:59 AM
by paul case
WTB:Small manual mill
Started by tomkat001 on Wanted
Last post May 15, 2012, 10:37:43 PM
by AMB30518
