Arborwear
Author Topic: WM sharpener  (Read 3243 times)
Offline xlogger
WM sharpener
« on: April 12, 2017, 07:05:00 AM »
I'm in the thinking process of getting a WM 250 sharpener. I've got a drag one now and not really happy with my results. Would like opinions on anyone who upgraded to one from a drag sharpener. I've pm Cuttingedge about wheels and fluid for it if I decide on one. I sharpen some blades last night and change the wheel on my drag to the white wheel to see if I get better results. If that don't work I'm ready for a change.
Offline EZ
  • Betya can't cut just one!
Re: WM sharpener
« Reply #1 on: April 12, 2017, 02:41:25 PM »
I sharpen litely twice, and sometimes if the band needs it I'll run it again.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: WM sharpener
« Reply #2 on: April 12, 2017, 07:53:27 PM »
Buy one of Richard's grinders and then tell me how you like it.  You can use mineral oil for lube on the cbn.
Boy, back in my day..
Offline gmmills
Re: WM sharpener
« Reply #3 on: April 12, 2017, 11:36:35 PM »
    I have upgraded from a drag style WM blade sharpener to a CBN grinder many years ago. I will never consider going back to a vitrified wheel drag style sharpener. Glad to here you are aware of the alternative CBN wheel manufacturers. I have been using Rixsaw CBN wheels for over 3 years now. Great durability and over all wheel life. A very high quality product. Not sure if you know there is now more than one manufacturer offering a oil cooled full profile CBN wheel sharpener. Ironically, I just took delivery of a new CBN sharpener this week. A CBN sharpener makes maintaining the exact tooth profile extremely easy.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline Peter Drouin
    • A&P Saw mill LLC
Re: WM sharpener
« Reply #4 on: April 13, 2017, 06:51:43 AM »
Go with a CBN,
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline xlogger
Re: WM sharpener
« Reply #5 on: April 15, 2017, 06:05:36 AM »
After changing my wheel over to one of the white wheels my blades are doing better. So for now I'll save that $2000 ;D.
Offline JD Picket
Re: WM sharpener
« Reply #6 on: April 15, 2017, 10:34:20 AM »
I'm kinda new to all this so I don't know who Richard is. Right now I'm in the shopping phase of looking for a sharpener. Just trying to find out what all of my options are.
JD
Offline xlogger
Re: WM sharpener
« Reply #7 on: April 15, 2017, 03:53:10 PM »
Richard is Cutting edge on the forum.
Offline xlogger
Re: WM sharpener
« Reply #8 on: April 24, 2017, 08:12:06 AM »
Question for ones that have a cbn sharpener. With the new cover that wm has do you still get much oil mist? The area that I would use one is not very ventilated.
Offline Percy
  • Resident trouble maker
Re: WM sharpener
« Reply #9 on: April 24, 2017, 10:30:00 AM »
I purchased aBM250 last year. Love it. I don't get much mist in my shack but I refuse to use that 150 dollars per pail oil that they say I should use. Been running Hydralic oil and it works great. Same wheel since I got it.
Offline xlogger
Re: WM sharpener
« Reply #10 on: April 24, 2017, 06:24:13 PM »
I order it today and got the wheel from Richard. Looking forward to have sharper blades I hope.
    • A&P Saw mill LLC
Re: WM sharpener
« Reply #11 on: April 25, 2017, 06:28:43 AM »
Good for you, 8) 8) The WM sharpener works well, When you see how good a job it does, you will never use a rock wheel again, Unless you want to skip it over water to see how far you can go. ;D
Sawing since 1987
Offline xlogger
Re: WM sharpener
« Reply #12 on: April 30, 2017, 04:25:01 PM »
it came in Friday now to put it up. I got a heavy built tv stand with drawers off craigslist to sit it on.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: WM sharpener
« Reply #13 on: April 30, 2017, 07:06:54 PM »
I've had the BMS250 for over a year now. It is a superior machine. To the previous LTAGA shop series grinder. Never had a drag grinder but I expect to that also.  I really like it.  It is refreshing to get a tool so well thought out.
Once you set the pusher for a given profile all you need to adjust is the blade height to get the same grind each time.  Each "star" on the blade height adjustment knob is about 7 thousandths in height.  So if you measure blade widths with a caliper, you can just sort them and make a calculated slight adjustment with the wheel to go from one to the next making each setup very easy.
You won't want to use this machine in an unventilated space, imo. It should be very easy to rig dryer vent hose and small fan to exhaust it outside if you want to use it in a fixed location.  I have mine on a Craftsman tool cart and just push it over to the edge of the garage and sharpen with the door open.  The housing contains spray but a fine mist still makes it outside.
ps. don't turn on the power with the pump and grinder motor turned on and the grinder head set in the up position.  You will find out why for yourself soon enough.  ;D
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline xlogger
Re: WM sharpener
« Reply #14 on: May 01, 2017, 05:44:05 AM »
The area where I was going to use it at is near the back of my shop about 30 ft from garage door. I was hoping that a fan behind it pushing air away would be good enough. A tool cart might be a good idea if this dosen't work.
Re: WM sharpener
« Reply #15 on: May 01, 2017, 04:25:38 PM »
I would think even a gentle air flow across the sharpener would move the mist away, that's what's happening at the garage door.
Offline xlogger
Re: WM sharpener
« Reply #16 on: May 02, 2017, 04:44:27 AM »
Any ideas where this parts go?  I didn't see anything about them in book.
Offline 4x4American
    • Website Link
Re: WM sharpener
« Reply #17 on: May 02, 2017, 05:10:50 AM »
The one on the left is a blade template thing it tells you what profile blade you have.  Not sure about the one on the right, almost looks like some kinda shield or viewing window or something
Offline Cutting Edge
    • Rix-Saws CBN Wheels
Re: WM sharpener
« Reply #18 on: May 02, 2017, 08:32:06 AM »
xlogger,
The black component is for aligning the motor arbor and clamp to ensure they are 90 deg. to each other and to also make sure the clamp/wheel surface meet at the correct geometry so the blade is being ground square in the vertical plane.
All (3) of the preset bolts must make contact with the front surface of the clamp.  Once aligned you should be good to go for a long time.  It is nice to check from time to time though.   ;)
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blade Distributor
Ph- (304) 878-3343
Offline xlogger
Re: WM sharpener
« Reply #19 on: May 02, 2017, 07:22:52 PM »
Thanks Richard, it looks like the motor is set at a 19 angle if I'm looking correct. I might give you call if that would ok.
WM pro series sharpener and Cooks sharpener with pics.
Started by customsawyer on Sawmills and Milling
Last post May 29, 2012, 08:45:10 PM
by Chuck White
Fix the LTAGA Sharpener or Buy a New CBN Sharpener?
Started by Mountain_d on Sawmills and Milling
Last post November 29, 2017, 05:36:04 AM
by Peter Drouin
Which Sharpener?
Started by woodhick on Sawmills and Milling
Last post September 08, 2006, 05:33:32 PM
by mike_van
New Sharpener
Started by Steve_M on Sawmills and Milling
Last post May 23, 2006, 10:37:23 PM
by BBTom
