Arborwear
Author Topic: ATV seed spreader  (Read 531 times)
Offline 47sawdust
ATV seed spreader
« on: April 12, 2017, 09:15:44 AM »
I would like to re-seed my pasture and I'm looking for an ATV spreader.I'd like to know what works for you.12 volt or pull behind?
 Thanks,Mick
Mick
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: ATV seed spreader
« Reply #1 on: April 12, 2017, 10:15:07 AM »
I have no idea which is best, but I use a 12v seeder/spreader.
Offline GAB
« Reply #2 on: April 12, 2017, 10:51:09 AM »
I'm no expert on this subject, however I would think that using a 12VDC spreader mounted on an ATV would be a better choice on more topographies.  Also it is difficult to get the same spread width with a unit where the rotor speed is determined by the speed of the spreader.
My brother used a 12VDC spreader mounted to the front rack to reseed a piece and when he got done had put down exactly half the seed he wanted to put in.  So he started over going the other way and did it again.
Gerald
Offline 47sawdust
« Reply #3 on: April 12, 2017, 11:24:14 AM »
MM and GAB,
 Thanks for your replies.I think the 12 volt unit will be a better choice as my fields are definitely not flat.I'm looking at a Buyer's ATVS15A at the moment.
Mick
Offline LeeB
« Reply #4 on: April 13, 2017, 10:34:36 AM »
I haven't tried but but was told dragging a cedar top behind you as you seed will cover the seeds just about the right depth.
ATV broadcast spreader?
Started by DonE911 on General Board
Last post November 17, 2005, 11:46:18 PM
by Jason_WI
Productive Manure Spreader
Started by Deadwood on General Board
Last post December 03, 2005, 08:30:03 PM
by wiam
seeder/spreader for my quad.
Started by Jeff on Alternative methods and solutions
Last post November 03, 2007, 08:51:48 PM
by WH_Conley
Seed Trees....
Started by Woodhog on Ask The Forester
Last post May 20, 2006, 02:18:40 PM
by SwampDonkey
