Arborwear
Author Topic: Gutters and roof issues  (Read 1300 times)
Offline tareece
  • See all.. learn all..Live large
« on: April 12, 2017, 08:48:58 PM »
While cleaning out my gutters I noticed several of my 3-4 yr old metal roof screws backing out or all but out...
   This was more than a little unnerving but after researching a bit, it's pretty normal.
     Now it's figuring out what to do about it..
  New screws and silicone sealant?
   Ideas?
Todd Reece
Lover of many things. Experienced in most... expert in few
Offline Larry
Re: Gutters and roof issues
« Reply #1 on: April 12, 2017, 09:56:46 PM »
Exact same problem.  I called the roofer that put the metal on and he came out and just screwed them back down.  Its been a few years now and I have a few that have backed out again.  Not near as many as the first time.
My metal was screwed to OSB which according to the manufacture is an approved method.  I believe other wise.
Hope somebody has a fix.  I think I know what the real fix is and its going to be expensive.
Larry
Nine out of ten trees recommend wood for your building project.
Offline newoodguy78
« Reply #2 on: April 12, 2017, 11:34:25 PM »
Tareece
What kind of substrate do you have? I'm guessing osb or plywood.
They make what they call a nail replacement screw, they have a larger diameter shaft to the screw. They bite into more of the wood Unfortunately if the screws are only going into osb or plywood (unless it's 3/4) this backing out will be an ongoing problem. The only real fix is to take the roofing off run purlins of a minimum thickness of 1 inch and reapply the roofing.
 Or if there is access to the bottom side of the roof deck take the screws out and put blocks on the inside between the rafters and screw through the metal, sheathing and into the blocking. This requires two people that can work together very well because it tends to be very aggravating staying in sync. Unfortunately you have a problem that is not easy to fix for the long term.
Please do yourself a favor and don't use silicone on your roof it will only create further and bigger problems down the road. If you have to use a sealant in a tube use a polyurethane based type.
Offline Briankinley2004
« Reply #3 on: April 12, 2017, 11:52:19 PM »
If it's into a substrate the screws didn't penetrate try a longer screw. You can also use np1 or 3m5200 in the hole and put screw back in. It will be there til cows come home once it sets up. Especially the 5200. Just make sure oil is not on surfaces
« Reply #4 on: April 12, 2017, 11:54:24 PM »
Also there should be a stitch screw at the lap in first pic. If they didn't use tacky tape at seam now is a good time to add it
Offline sprucebunny
  • Gender: Female
« Reply #5 on: April 13, 2017, 06:05:47 AM »
My steel roof is screwed to 1" spruce strapping and some of the screws have backed out so I don't think it's entirely the fault of the substrate (" osb or plywood )
There's quite a bit of movement of the metal when outdoor temperatures change. The popping and clicking noises tell me so !!
A bigger diameter screw sounds like a good solution.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #6 on: April 13, 2017, 06:34:10 AM »
Put some only on the screws thread...
Loctite PL 510 Wood
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline LeeB
« Reply #7 on: April 13, 2017, 06:46:02 AM »
Check in the attic for water damage. Everywhere the screw is up is a place for water to get in. If there has been much water, the wood may be rotted and the screw may strip the hole. Went through this with the shop in my last house. I sure miss my shop.  :'(
Offline Czech_Made
« Reply #8 on: April 13, 2017, 07:01:47 AM »
Dang, better get up on the barn and check  >:(
Offline gspren
« Reply #9 on: April 13, 2017, 07:41:25 AM »
  The 5200 is a "marine" adhesive/sealant approved for below the waterline, good stuff, get a one ounce tube and try it, that will do a bunch of screws, after a tube is opened you can't normally save it for months.
Offline pineywoods
« Reply #10 on: April 13, 2017, 09:59:08 AM »
You can bet water is leaking around those backed out screws, rotting the wood around the screws. I have metal roofing on all my buildings. I didn't put the screw on the flat part, used 2 inch long screws on the ridge tops. Never had any problems with screws backing out. Another difference, do NOT predrill the holes for the screws, use the self tapping screws..Roofing suppliers all recommend putting the screws through the flat surface, say the rubber washers will stop leaking...Your photo says it all...
Offline scsmith42
    • Whispering Pines Farm
« Reply #11 on: April 13, 2017, 10:16:06 AM »
Todd, I had some loose screws on a barn that we roofed about 9 years ago, but nothing as loose as yours.
My foreman and I simply spent about 30 minutes on the roof snugging up every screw. I don't expect it to repeat.
Tom's 3638D Baker band mill
Offline moodnacreek
  • Sawin by the notches
« Reply #12 on: April 13, 2017, 12:55:34 PM »
The first thing you do concerning rib metal roofing is don't read the instructions. Next; do not buy long sheets and third; screw thru the highs . Most of what you see is wrong. Way up northoalong the boarder you will see some done right.  In very windy areas there may be reason to screw the lows at the edge.  Long sheets will jack the screws out. Screwing thru the lows means the seal has to be absolutely perfect and if they leak a tiny bit it will rust around the screw  hole . Screwed thru the highs does not have to seal.
Offline snowstorm
« Reply #13 on: April 13, 2017, 02:38:45 PM »
And the company that makes the steel roofing says only screw on the flat. Been there and done that. Mine didn't leak for 5 yes. Then replaced screws with longer ones. Then with a larger Dia. Still leaks a little
Offline Farmerjw
  • I'm so far behind I think I am in first place.
« Reply #14 on: April 13, 2017, 02:43:40 PM »
When we put our steel roof on the house they told me to screw roofs on the high ribs and walls on the flats.  Those screws would really upset me.
Premier Bovine Scatologist
Offline jwilly3879
« Reply #15 on: April 13, 2017, 04:58:37 PM »
I have worked on many metal roofs typically when the screws seem to back out it is due to condensation in the attic space. In the winter the condensation freezes on the screws that penetrate the sheathing forming little icicles. When it warms up the ice melts and the water is absorbed by the sheathing and will rot around the screw.
The roof on one side of a lakefront camp had the entire side loosen up to the point it would flap in the wind. On that one we removed the metal and moved it down 1 1/2" and re attached it using shorter screws (originally 2" screws through 5/8 ply). We also added ventilation to the attic. 10years have passed and the screws are still solid.
« Reply #16 on: April 14, 2017, 11:45:30 PM »
We normally stack all the sheets on the same run on ground. Then we pre drill all the sheets with a bit slightly larger than the screw diameter. This lets expansions occur without messing with screws and also assures screws are straight in appearance on the roof. Also helps with the screws not leaning trying to cut through the metal. None of this will help the o p though at least not on this roof
Offline jwilly3879
« Reply #17 on: April 15, 2017, 08:06:35 AM »
I predrill also, using double ended bits that I get at the auto body repair shop.
All the screws line up nicely when seen from the ground and they start much easier.
Offline newoodguy78
« Reply #18 on: April 15, 2017, 10:08:35 PM »
X3 on the pre drilling not only does it look better it makes starting the screws way easier
Anyboy used these gutters?
Started by bmill on General Board
Last post January 30, 2008, 09:04:07 AM
by Lud
where to find copper gutters
Started by Daver on General Board
Last post August 23, 2008, 08:08:57 AM
by Daver
roof'in people, is a metal covered hip roof practical?
Started by Modat22 on General Board
Last post December 15, 2005, 01:56:48 PM
by Phorester
Building a 6/12 roof over a 3/12 roof (need recommendations)
Started by CharlieCG36 on General Woodworking
Last post June 17, 2015, 10:53:31 PM
by Don_Papenburg
