Arborwear
Author Topic: Dry White Pine with waves  (Read 1023 times)
Offline Dave989
  • Timber Beast Sawmilling
« on: April 15, 2017, 11:15:52 AM »
Hello there,
I have a Woodmizer LT 40.  I was cutting white pine yesterday for a costumer with a new blade, bimetal 7 degree turbo.  The one White pine log that is about a year from when it was cut, kept getting waves in it where the knots were.  Now I have had this issue before, but never this bad.  I kept milling slower and slower, it didn't seem to make a difference. The costumer was not happy at all, nor was I.  Any ideas as to why this was happening?
Check out our Facebook page Timber Beast Sawmilling.
Dave and Hannah
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Dry White Pine with waves
« Reply #1 on: April 15, 2017, 11:23:33 AM »
Jack up the pressure a tad...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Sawmill Man
« Reply #2 on: April 15, 2017, 12:12:24 PM »
If you are sure blade is sharp and tensioned correctly and drive belt is tight try increasing set.
"I could have sworn I went over that one with the metal detector".
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: April 15, 2017, 12:43:50 PM »
Dave,
   I'd try a 4 degree blade. I run them a lot in pine and spruce to prevent getting wave at the knots. The 7 & 10 degree blades will cut good in the soft wood till they hit the harder knot then they want to jump over (at least that has been my experience with my mill). Good luck.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #4 on: April 15, 2017, 02:10:16 PM »
Belt tension is critical under these conditions.
Offline ladylake
« Reply #5 on: April 15, 2017, 04:12:56 PM »
 Dry pine like to build up gum on the blade fast, check that.  Steve
Online Sixacresand
  • John and Nancy
« Reply #6 on: April 15, 2017, 08:37:44 PM »
Even with new 4 d blades I had drizzle diesel on the blade to get decent boards from dry or pitchy pine.  Also, as mentioned on FF many times, Start the CUT on the top end of the log.
Online Ga Mtn Man
  • Y'all can call me GMM
« Reply #7 on: April 16, 2017, 08:58:42 AM »
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Online Sixacresand
  • John and Nancy
« Reply #8 on: April 16, 2017, 01:22:37 PM »
Offline Brad_bb
    • My timberframe blog
« Reply #9 on: April 16, 2017, 09:53:56 PM »
Assuming your tension is at the factory setting, and you have a sharp blade....1)slow down and give it time to cut through the harder knot, and 2) read this  http://www.forestryforum.com/board/index.php/topic,95719.0.html
See if turning the log end for solves it.  Let us know.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #10 on: April 17, 2017, 05:55:56 AM »
Cutting to slow, Next time give her some the T, 7s have to eat as fast as you can.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
waves   oak like pine
Started by woodmills1 on Sawmills and Milling
Last post November 17, 2004, 03:47:00 AM
by FeltzE
Milling Pine with waves like the ocean.
Started by RacinRex on Sawmills and Milling
Last post November 06, 2004, 06:47:15 PM
by arj
Free Logs; White Pine & White Oak Sebago Maine
Started by JJ on Sawmills and Milling
Last post November 09, 2016, 10:53:53 AM
by JJ
Green and white mold on Eastern White Pine
Started by AnthonyW on Drying and Processing
Last post September 14, 2015, 09:15:28 PM
by AnthonyW
