Arborwear
Author Topic: saw collar question  (Read 384 times)
Offline rpg52
saw collar question
« on: April 16, 2017, 06:09:44 PM »
Long story, but I'll make it short - the saw collars on my Belsaw M-14 were exposed to rain for a long time and got rusted.  To re-machine them, do I need to take off the mandrel?  Or, can I remove the "fast" collar by heating the collar and cooling the arbor?  How much taper should there be on the bearing surface?  I see the numbers .002 to .003 mentioned in Lunstrum.  Is that what I should try for?  Thanks!
Belsaw circle mill, in progress.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: saw collar question
« Reply #1 on: April 16, 2017, 06:38:52 PM »
The best way is to machine them right on the saw.
I took a cross slide off a lathe and bolted it down to the floor
right next to the collars. Machined them right in place.
The will make up for any shaft wobble.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline moodnacreek
  • Sawin by the notches
« Reply #2 on: April 16, 2017, 07:52:09 PM »
I agree but if the bearings are not in perfect shape it should come apart to replace them. If so don't clean shaft under bearings because it's probably under size all ready. In this case I use 609 locktite.
Offline moodnacreek
« Reply #3 on: April 16, 2017, 08:12:51 PM »
Also, don't remove the fast collar, I did that once and when we shrunk it back on it never held [it spun]  , Doug
Offline dustyhat
« Reply #4 on: April 16, 2017, 10:22:00 PM »
i have always tried for 2 thousands on the collars. seems to work out good.
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Collar tie Question
Started by Gilman on Timber Framing/Log construction
Last post March 06, 2008, 08:26:27 PM
by Gilman
question
Collar Tie Question
Started by Joel Eisner on Timber Framing/Log construction
Last post December 08, 2005, 04:32:06 PM
by Joel Eisner
saw collar
Started by 1wkinsley on Sawmills and Milling
Last post November 23, 2015, 10:37:19 PM
by 4x4American
saw collar
Started by jdeere540a on Sawmills and Milling
Last post June 02, 2016, 10:22:29 PM
by Ron Wenrich
