Arborwear
Author Topic: Bandsaw Edger/vertical resaw??  (Read 401 times)
Offline etroup10
« on: April 19, 2017, 10:39:08 PM »
Have any of you guys ever seen or heard of someone building an edger using bandsaws instead of circular saws?? I was thinking it may work pretty well. An engine on both of the saws, have one of the saw head assemblies adjustable. I imagine blades would last pretty long due to only cutting 1-2" material most of the time, with little or no bark. There shouldn't be any chance for kick back. Also I think it could double up as a vertical resaw as well if you made the throat wide enough. I may price it out and see what it would cost. If it looks affordable I may try it. But I also have a lead on an edger that has sat outside for 10 years, so if the price is low enough on that I might just go that route.
EZ Boardwalk 40; Gafner Hydraloader; custom built edger, Massey Ferguson 50E, American Sawmill 20" Pony Planer; Husqvarna 55 Rancher
Offline red
  • we will never forget
Re: Bandsaw Edger/vertical resaw??
« Reply #1 on: April 20, 2017, 07:20:41 AM »
A resaw usually has a bandsaw blade but an edger has a circle blade.
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline etroup10
« Reply #2 on: April 20, 2017, 12:01:15 PM »
Yeah I know. Just contemplating the idea of building an edger with two vertical bandsaws that could also double up as a resaw
Offline Ron Wenrich
« Reply #3 on: April 20, 2017, 12:14:02 PM »
I look at it this way.  If it was a feasible idea, then the guys who know stuff about bandmills would already have built one.  Guys like Woodmizer, Baker, Cook, etc.  Those guys either don't make edgers, or make circle blade edgers.
The stationary saw wouldn't be much of a problem, as you can use a fence for one sided edging.  But, indexing a full machine may be the hard part.  You will also need some sort of feed rolls, and something to hold the board down.
Offline paul case
  • Original wearer of the PCM.
pc
Offline etroup10
« Reply #5 on: April 20, 2017, 12:26:37 PM »
Thanks!! That's pretty similar to what I had in mind, just heavier duty and more automated!
vertical resaw bandsaw?
Started by weisyboy on Sawmills and Milling
Last post February 16, 2011, 05:50:56 AM
by Meadows Miller
Yates American V54 Vertical Resaw
Started by Stagerig on For Sale
Last post March 31, 2014, 02:59:25 PM
by Stagerig
vertical edger
Started by semologger on Wanted
Last post February 20, 2012, 07:28:43 PM
by semologger
Edger & resaw ?s
Started by valley on Sawmills and Milling
Last post October 21, 2012, 11:56:29 PM
by LorenB
