Arborwear
Author Topic: 7 deg or 10 deg?  (Read 1188 times)
Offline Quebecnewf
7 deg or 10 deg?
« on: April 20, 2017, 01:05:05 PM »
Sure this has been asked before but here goes...
Going to buy a bunch of new blades . Going to try the Kasco . Read good things about them ..
I saw all softwood ( fir and spruce) have a 20!hp motor . For my new blades should I go with 7 deg or 10 deg.
Quebecnewf
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: 7 deg or 10 deg?
« Reply #1 on: April 20, 2017, 01:22:04 PM »
I would say 4 deg. for 20 hp.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline york
« Reply #2 on: April 20, 2017, 01:24:24 PM »
I stopped using 10 Bands about 3 yrs ago-Sofwood logs have hard limbs..
I mill a mix of W. Pine,Hemlock and Red Oak and use 7....
Albert
Offline WLC
« Reply #3 on: April 20, 2017, 01:57:45 PM »
New(ish) sawyer here.  My LT28 is 20hp and my WM dealer suggested the 7 bands for our wood species here.  Spruce and white birch.  Seem to cut good for me and don't bog the motor down unless you really push the feed rate.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline Bruno of NH
« Reply #4 on: April 20, 2017, 05:40:43 PM »
I have a 13 hp mill and use 7's and 4's now
7's cut great for me in soft wood and some hard wood
But use the 4's in the real tough stuff
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline ladylake
« Reply #5 on: April 20, 2017, 06:18:51 PM »
 4 will cut anything plus stay sharp longer.   Steve
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #6 on: April 20, 2017, 08:11:03 PM »
What have you used in the past?
Knots are surely an issue but seems like 4's in soft wood
just wouldn't perform as well as something with a little more angle
and the right set,
JMHO,
D
Offline Carson-saws
« Reply #7 on: April 20, 2017, 08:41:59 PM »
Jeff....is there a way to start a tally list, like the other type of lists for...say....the one for years of experience or the others like that.  The reason is the varieties of degree use for soft or hard wood choice that seems to fluctuate.  I think it would be interesting, for this thread anyway, to see who uses what for what at what degree and such.  Just a thought Sir.
Let the Forest be salvation long before it needs to be
Offline bags
  • Location: Up high in the Colorado Rockies, Westcliffe ,CO.
« Reply #8 on: April 20, 2017, 08:44:12 PM »
Mostly all I get to cut up here in the high country is Doug-Fir, Spruce, limber pine, Ponderosa and aspen. I've been cut'in with 10* Lenox blades with no problems. I'm gonna say I have less pitch build up on the blades with the 10's than the others. If your cut'in a good bit of the smaller Spruce that has a lot of knots, you may fair best with the 7* blades.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #9 on: April 20, 2017, 08:49:24 PM »
I've got 24 horses on my LT30.
After trying a bunch of brands and angles, the 7 degree bands are what I've standardized on.
But, if there's some wonderful bur oak that's calling out my name, I'll pull out my secret weapon: 4 degree bands - especially if it's below zero weather.
LT30G24
Ford 545 Series loaders
Stihl chainsaws
Offline Carson-saws
« Reply #10 on: April 20, 2017, 08:52:03 PM »
bags....I like Lenox as well.....This is another example of the degree of choice.  A tally list would be interesting....
Offline dgdrls
« Reply #11 on: April 20, 2017, 08:58:41 PM »
New thread and choose New Poll,  see if that works
you may have to make two, or work the question and responses a bit
D
Offline Cutting Edge
    • Rix-Saws CBN Wheels
« Reply #12 on: April 20, 2017, 09:10:38 PM »
 4 will cut anything ....
I agree with ladylake.  Especially with a 20hp engine
There is some good information later on in this thread:  http://www.forestryforum.com/board/index.php/topic,95291.0.html
The reason for including the link is specific to the discussion about gullet depth and the ability for the blade to remain stable.  The Kasco 4 deg has a much shallower gullet vs. the Kasco 7 deg.  You have to FEED blades with larger gullet capacity to get a good cut... which require a good bit of HP.
Nearly all my customers that have lower HP mills and have switched to the Kasco 4 deg have stayed with it because it performs extremely well, regardless of species.  Plus, they're able to produce a better product with much less issues more common with higher deg hook angle blades.
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blade Distributor
Ph- (304) 878-3343
Offline Carson-saws
« Reply #13 on: April 20, 2017, 10:12:00 PM »
I would think including the various H/P and which "blade of choice" depending on hard or soft.  Is that something that a member can set up as far as the poll? Or is that something the skilled and talented hands of Jeff can, would, will, should, will think about, ponder, about doing?
Offline DDW_OR
« Reply #14 on: April 20, 2017, 10:53:10 PM »
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Turbosaw 26EX, Hakmet Arbro 400 stroke harvester, BrushHound 30EX
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #15 on: April 20, 2017, 11:28:21 PM »
I've cut several hundred thousand board feet of Douglas-Fir with 10 blades -- no waves, no problems. I'm currently sawing Western Red Cedar, trying for maximum production of specific sizes, with 10 blades -- no waves, no problems. I've sawn small quantities of Lodgepole Pine, White Pine, and Ponderosa Pine with 10 blades -- no waves, no problems.
When I ran into some wide, dry White Spruce, I made waves. Serious waves. It was embarrassing (and the customer was not happy). I tried everything -- freshly sharpened blades, new blades from the box, checked the mill (and bladed) alignment, sawed slow, sawed fast -- nothing worked. So I called WM for advice and they suggested their new (at the time) 7 blades. I bought 3 to try, called the customer and told him to bring me some more Spruce cants, and zipped right through those cants without even a ripple :o :).
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline bandmiller2
« Reply #16 on: April 23, 2017, 07:11:50 AM »
I am solidly in the less is more camp when it comes to band hook. Most of the time I use around six degree hook. Its my understanding that 10 deg. bands feed a little easier on manually fed mills. In the beginning most mills were pushers and the 10's just carried over and became the standard. Frank C.
