Author Topic: Log weight  (Read 610 times)
Offline bandmiller2
Log weight
« on: May 04, 2017, 08:35:09 PM »
Just read Dave's question on log weight. Why not put a pipe tee and hydraulic pressure gauge on the spool valve. After some fancy figuring or calibration with several loads a fella should know the weight of objects lifted. Frank C.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Log weight
« Reply #1 on: May 04, 2017, 08:43:45 PM »
All the gravel pits are setup with scales in the loaders around here. They load you and give you a ticket right in the pit.
Offline fishfighter
Re: Log weight
« Reply #2 on: May 04, 2017, 09:00:34 PM »
Why not just use the tool box. Close enough for me. ;D
Online KirkD
Re: Log weight
« Reply #3 on: May 04, 2017, 09:33:46 PM »
Might work for some but I have been hauling loads of Douglas Fir and one big Incense Cedar and ran the trailer across a scale and the Douglas fir logs were about 60% more than it said it should be and maybe more than that. On the cedar judging by what it took t get it off the trailer I was not able to scale it. I will move the mill to where it landed to mill it.
Wood-mizer LT40HD-G24 Year 1989
Offline bandmiller2
Re: Log weight
« Reply #4 on: May 05, 2017, 07:08:53 AM »
Log weight can vary wildly due to density and water content, charts and programs give you a ballpark figure at best. Each application of a gauge would require some calibration, but then its a simple matter to know weight. Frank C.
Vehicle weight and towing weight limits
Started by Keith_A on General Board
Last post May 13, 2002, 07:26:52 PM
by Gordon
wireless
Tj 230 weight
Started by smwwoody on Forestry and Logging
Last post June 01, 2011, 01:18:05 PM
by 240b
What do you use as weight
Started by TeenSwinger on Drying and Processing
Last post December 17, 2006, 08:43:37 PM
by metalspinner
Log weight?
Started by tacks Y on Sawmills and Milling
Last post June 11, 2018, 07:46:35 AM
by DPatton
